Bailey75 Samba Member
Joined: November 12, 2017 Posts: 7 Location: Australia
Posted: Tue Jan 16, 2018 7:08 pm Post subject: Super beetle problems! Please help |
My 1975 super beetle is having some issues
I just returned from a month trip overseas. Left my beetle locked up in the garage whilst I was gone. After pulling the beetle out of the garage, there was a puddle under my car. I first assumed it was oil. But then it dried up throughout the day and didn’t leave a mark. 24 hours later after only driving 50km or so. I park up. The next morning I go out to my car to start a new day and there is a huge puddle of oil sat under my car. The largest oil puddle I’ve ever seen. Any suggestions and ways to fix this?
Second problem. My fuel gauge. I have had problems with this since the day I bought my beetle. I filled up my tank completely yesterday. Drove 50km and now my fuel gauge says I am on practically empty. I was used to it not showing the correct amount of fuel. But this amount seemed a bit drastic.
Any help would be much appreciated. I am new to the Volkswagen scene. So I don’t know a whole lot. Thank you in advance |
Xevin Samba Member
Posted: Tue Jan 16, 2018 7:25 pm Post subject: Re: Super beetle problems! Please help |
What’s the oil reading on the dipstick after you noticed oil puddle. Car been running hot last time you drove it? Did you have oil leak on to your heater boxes? Good compression in all four cylinders? What kind of movement when you thrust pulley back and forth? _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
flyboat Samba Member
Posted: Tue Jan 16, 2018 7:45 pm Post subject: Re: Super beetle problems! Please help |
These engines are notorious for taking in water. While sitting up in a garage, if the temps and humidity vary alot, the engine will get water in it. Sometimes alot more than you would imagine. Run the car til its warm and check the oil. If the oil is milky, this could be part of the problem. If this has happened it would explain why the first puddle disappeared.
Popping off a valve cover will reveal water too as it will look like snot all over your pieces parts. _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
mukluk Samba Member
Joined: October 18, 2012 Posts: 6985 Location: Clyde, TX
Posted: Tue Jan 16, 2018 8:56 pm Post subject: Re: Super beetle problems! Please help |
With the combination of an oil leak and apparent loss of a good portion of the fuel in the tank, my major concern would be to check that the fuel pump isn't ruptured and dumping all that fuel into the crankcase. Pull the dipstick and check that the level isn't showing high and that the oil doesn't smell strongly of gasoline. _________________ 1960 Ragtop w/Semaphores "Inga" |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11739 Location: Redding, CA
Posted: Tue Jan 16, 2018 8:58 pm Post subject: Re: Super beetle problems! Please help |
Are you sure the puddles weren’t gasoline? This would perhaps account for your fuel gauge showing so little after filling up and not traveling that far. Do you smell gas?
Check oil level before you start the engine again. If you did lose a huge amount of oil, it would be prudent to check the level of it. Add oil if necessary, of course; then get your head under the engine and see if you can pinpoint the leak.
Check inner side of oil cap for milky moisture.
I can’t imagine where all the water came from unless your garage has a big roof leak—assuming you don’t live in a rain forest, that is.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Danwvw Samba Member
Posted: Tue Jan 16, 2018 9:02 pm Post subject: Re: Super beetle problems! Please help |
Give the top the carb a good tapping. I think the float needle valve is sticking after setting all that time and it's now not closing off good so the engine sucking a lot of gas and it's going into the oil and then overflowing. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1600 Location: Central Pennsylvania
Posted: Tue Jan 16, 2018 9:13 pm Post subject: Re: Super beetle problems! Please help |
If your fuel gage reads empty - maybe your tank *is* empty. Do you know how to disconnect the sending unit on top of the gas tank? Pull up the carpet and take out those five little bolts. Then look inside with a flashlight. If the tank is empty, then your fuel gauge is fine but you have one of the problems above (carb or fuel pump). Don't drive until you fix this! _________________ '91 Vanagon Westfalia
'70 Beetle Convertible
'71 Super Beetle Semi-Automatic: https://www.thesamba.com/vw/forum/viewtopic.php?t=714131&highlight=
'65 Ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=762478&highlight= |
