airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12686 Location: on a bike ride somewhere
Posted: Tue Jan 16, 2018 8:40 pm Post subject: J. Wizemann GmbH Lifters? |
Hi folks,
Two years ago I was bitten with a cam and lifter compatibility in my stock bus engine, and I'm building another one while I run out the clock on the current engine.
This time around I'm going with a new case since a cam bearing is spun in the current case, and I DO NOT WANT to deal with cam/lifter compatibility issues again.
I found these in my garage. What are they? What is the coating? And what camshafts will be perfectly matched to them for optimal life? (100k miles or more.)
Thanks,
Robbie
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
modok Samba Member
Joined: October 30, 2009 Posts: 26740 Location: Colorado Springs
Posted: Tue Jan 16, 2018 9:29 pm Post subject: Re: J. Wizemann GmbH Lifters? |
They were one of the better lifters available in the olden times.
Not the lightest at all, but good material and heat treat and so forth.
Probably will work well on a older cam or ep-12 cam blank. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Tue Jan 16, 2018 9:55 pm Post subject: Re: J. Wizemann GmbH Lifters? |
I have them in my 2180 and had them Parkerized.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Jan 16, 2018 10:19 pm Post subject: Re: J. Wizemann GmbH Lifters? |
Glen, would the camshaft have to be Parkerized as well?
modok wrote: |
modok, what does an ep-12 blank consist of? Would a company like Web be able to cut a new cam of that material for me? I am not interested in a performance grind.
Thanks!
modok Samba Member
Posted: Tue Jan 16, 2018 10:35 pm Post subject: Re: J. Wizemann GmbH Lifters? |
asiab3 wrote: |
Thanks!
Robbie |
the ep-12 was the most common cam blank in recent history. I THINK web or engle would do that if you ask, probably.
OR you just go with what they have, and use the lifters they say you should use.
If you want the cam and lifters to be just like they were in 197x or whatever,
Then sell these lifters and get reground original cam and lifters.
Probably will be an even trade. Some sucker will pay a hundred bucks for those heavy old lifters |
Posted: Tue Jan 16, 2018 10:43 pm Post subject: Re: J. Wizemann GmbH Lifters? |
Sounds like a possible plan.
I have a access to a wide variety of W. German OG cams with the various gear pitches I’d like to use. Would this be a decent match? I prefer the factory stock cam profile for this engine.
modok Samba Member
Posted: Tue Jan 16, 2018 11:09 pm Post subject: Re: J. Wizemann GmbH Lifters? |
asiab3 wrote: |
I have a access to a wide variety of W. German OG cams with the various gear pitches I’d like to use. Would this be a decent match? |
Probably. A harder lifter on a softer cam is FAR better gamble than the reverse.
Strange you can even find an NOS cam, but, I guess the same time capsule that had the lifters |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Wed Jan 17, 2018 12:35 pm Post subject: Re: J. Wizemann GmbH Lifters? |
asiab3 wrote: |
Robbie |
Wizemann (pronounced Vitza-mann) lifters were one of the main German stock lifters back when Beetles were new. They should work fine with any NOS OEM Type 1 cam.
I have also used them with aftermarket cams (Engle) and have another set waiting for my 1500 cc rebuild. Nice find! _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Udo.B. Samba Member
Joined: May 05, 2005 Posts: 224 Location: Iserlohn/Germany
Posted: Wed Jan 17, 2018 2:35 pm Post subject: Re: J. Wizemann GmbH Lifters? |
asiab3 wrote: |
Hi folks,
Thanks,
Robbie
. You can be lucky . Use them like they are, no matter what cam you have Regards udo _________________ www.udobeckertuning.de |
slalombuggy Samba Member
Posted: Wed Jan 17, 2018 5:22 pm Post subject: Re: J. Wizemann GmbH Lifters? |
I had them in my 1776, 25 years they are still going strong for the new owner. I used them with an Engle cam
brad |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4338 Location: Los Angeles, CA 90016
Posted: Wed Jan 17, 2018 7:18 pm Post subject: Re: J. Wizemann GmbH Lifters? |
Sell em for $80-$100 to a N.O.S. parts hoarder and buy some $40 Moresa lifters. |
Posted: Fri Jan 19, 2018 12:16 pm Post subject: Re: J. Wizemann GmbH Lifters? |
Brad and Udo, thanks for the confirmation. I'm feeling good about these!
bugguy1967 wrote: |
I AM that NOS parts hoarder… But I put 20k a year on my bus so my stash will be put to good use!
Thanks again,
Udo.B. Samba Member
Posted: Tue Jan 23, 2018 11:39 am Post subject: Re: J. Wizemann GmbH Lifters? |
Good choice - you will find no others that last longer . Except mine if you need others some time _________________ www.udobeckertuning.de |
Glenn Mr. 010
Posted: Tue Jan 23, 2018 11:44 am Post subject: Re: J. Wizemann GmbH Lifters? |
Thanks, both of you!
