ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Thu Jan 18, 2018 12:31 am Post subject: Registering a foreign vehicle in California (post 1976)? |
In my search for a dual cab I've expanded my search to outside of the country but I have no idea what I would be in for.
Has anyone registered a foreign vehicle in California that was newer than the 1976 smog exemption? How difficult was the process? What if the vehicle isn't in running condition or doesn't have the original or correct motor? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
parker007 Samba Member
Joined: December 21, 2011 Posts: 132 Location: california
Posted: Thu Jan 18, 2018 12:50 am Post subject: Re: Registering a foreign vehicle in California (post 1976)? |
you just said all things that make not possible. after 76 have to be ca smog legal. get oregon plate hahaahah |
Posted: Thu Jan 18, 2018 2:40 am Post subject: Re: Registering a foreign vehicle in California (post 1976)? |
parker007 wrote: |
Is it possible to get it registered but as non opp? I'm guessing I could convert it to electric if I needed to. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Thu Jan 18, 2018 4:26 am Post subject: Re: Registering a foreign vehicle in California (post 1976)? |
California isn't going to make this easy, you really need to find the right person to talk to with the state. That said, it is my understanding that you have to make an imported vehicle meet the pollution requirements it had to meet when it left the factory, but that if there were no requirements for a particular vehicle then you are SOL. |
LazyLightning75 Samba Member
Joined: August 02, 2016 Posts: 115 Location: Carmichael, CA
Posted: Thu Jan 18, 2018 1:56 pm Post subject: Re: Registering a foreign vehicle in California (post 1976)? |
I second what Wildthings said...go directly to the source of information and call the CA DMV. I think you can also submit questions to them by email. When I was considering buying a bus without a title, I called the CA DMV. Took forever to get to the right person, and she was grumpy as all get out when I did reach her, but she gave me some great advice and outlined the whole process on how it could be done (although she recommended against it). I was super polite and eventually she loosened up, but it was worth the hassle. Wish I still had that phone number to pass along to you. Good luck and when you call, have your list of questions ready for them! _________________ 1975 Riviera 1.8L FI |
SGKent Samba Member
Posted: Thu Jan 18, 2018 2:05 pm Post subject: Re: Registering a foreign vehicle in California (post 1976)? |
California will be the port of entry so it will have to meet these requirements:
https://www.arb.ca.gov/html/master_faqs/vehicle_faqs/greymarket_cars_faq.htm _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jan 18, 2018 3:40 pm Post subject: Re: Registering a foreign vehicle in California (post 1976)? |
If I read that right then that means I could put a cheap type 1 motor in it so long as it passes the smog test, right? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Thu Jan 18, 2018 3:58 pm Post subject: Re: Registering a foreign vehicle in California (post 1976)? |
ivwshane wrote: |
If I read that right then that means I could put a cheap type 1 motor in it so long as it passes the smog test, right? |
There is nothing cheap about a well built Type 1 motor, to get one that will even come close to lasting as long as a Type 4 you will be paying the same if not more. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Thu Jan 18, 2018 10:18 pm Post subject: Re: Registering a foreign vehicle in California (post 1976)? |
ivwshane wrote: |
I don't think that will pass the visual inspection part. _________________ .ssS! |
