surfbus23 Samba Member
Posted: Thu Jan 18, 2018 5:37 pm Post subject: Steering Coupling Flange Splines |
Wondering how much "teeth" the steering coupler flange is supposed to have? The splines on the part that goes to gearbox look good, but doesn't appear to have any on the flange. Thinking it's supposed to be like this so you can adjust it, but don't know. Here's the best picture I could take.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jan 18, 2018 6:08 pm Post subject: Re: Steering Coupling Flange Splines |
Something's wrong with that, it should have the same spines as all the rest of the parts, that one is trash. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jan 18, 2018 7:00 pm Post subject: Re: Steering Coupling Flange Splines |
Dang. No surprise I guess. Interesting that this got so trashed and the splines on the gearbox are still in great shape. |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Thu Jan 18, 2018 9:22 pm Post subject: Re: Steering Coupling Flange Splines |
Here's what a new one looks like.
_________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
Posted: Thu Jan 18, 2018 9:31 pm Post subject: Re: Steering Coupling Flange Splines |
Hmm... doesn't look so different then. Anyone else looked at theirs recently and can add input if this part should have splines or not? |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Thu Jan 18, 2018 9:36 pm Post subject: Re: Steering Coupling Flange Splines |
Since the coupling flange is held on via the clamp pinch bolt, I don't think splines would be appropriate there. Mine doesn't have splines,
and I'm glad of it. _________________ '67 bug: seized by the authorities
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Thu Jan 18, 2018 10:12 pm Post subject: Re: Steering Coupling Flange Splines |
Here's a photo of the steering box for a '69 camper and the input shaft has splines. Therefore I would ASSuME the coupling has splines. What year bus does the OP have? There is a groove for the pinch bolt. Caveat: The steering box part number has two different suffixes and the location of the groove differs by 90º. If you put in a steering box with the wrong suffix the steering wheel spokes will be vertical instead of horizontal. BTDT.
Aloha
tp |
Posted: Thu Jan 18, 2018 10:40 pm Post subject: Re: Steering Coupling Flange Splines |
It's a 79, so the gearbox did change. I think it must be OK because how would only the splines on the flange be worn off and the others look great. I'd just never seen one before and wanted to take the Samba pulse. |
Posted: Thu Jan 18, 2018 11:07 pm Post subject: Re: Steering Coupling Flange Splines |
WTF indeed, now I'll have to go look at a few to confirm _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Fri Jan 19, 2018 8:40 am Post subject: Re: Steering Coupling Flange Splines |
What is important here is that you have the correct grade bolt in good condition tightened to the correct torque. This is not a place to try and get by with the incorrect grade bolt or one that has been damaged in any way. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Fri Jan 19, 2018 9:10 am Post subject: Re: Steering Coupling Flange Splines |
Does the steering box output shaft not have a notch or recess where the pinch bolt crosses from one side to the other?
I realize I work on other cars.....but my 411 and 412 steering boxes have the same thin splines on the output shaft and NO splines inside the yoke.....and they are not needed. Once the pinch bolt is installed and crosses the recess in the output shaft.....its locked.
Like this?
Ray |
SGKent Samba Member
Posted: Fri Jan 19, 2018 9:28 am Post subject: Re: Steering Coupling Flange Splines |
the flange has no splines. It is held with clamping force. Early bays had a cotter pin thru the bolt to avoid it coming loose. Late bays have special lock nut. The bolt goes thru the flat in the worm gear shaft to keep it from ever tuning 360 if the clamp broke or the bolt came loose. Same set up as the swing arm but the swing arm has no splines like the worm gear. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jan 19, 2018 9:41 am Post subject: Re: Steering Coupling Flange Splines |
[quote="raygreenwood"]Does the steering box output shaft not have a notch or recess where the pinch bolt crosses from one side to the other?
Quote: |
It does. Of interest with the notch is that mine has a copper bolt. Anyone else notice that? |
SGKent Samba Member
Posted: Fri Jan 19, 2018 9:57 am Post subject: Re: Steering Coupling Flange Splines |
[quote="surfbus23"]
raygreenwood wrote: |
I have seen copper plated and color plated steel bolts in that spot before. It is a Jesus bolt. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jan 19, 2018 10:21 am Post subject: Re: Steering Coupling Flange Splines |
[quote="SGKent"]
surfbus23 wrote: |
I have seen copper plated and color plated steel bolts in that spot before. It is a Jesus bolt. |
Does a Jesus bolt mean it can't break? |
Posted: Fri Jan 19, 2018 10:52 am Post subject: Re: Steering Coupling Flange Splines |
Jesus nut/bolt
https://en.m.wikipedia.org/wiki/Jesus_nut
Pretty much most pinch bolts that cross through a recess like in my pictures.....used for ball joint rotating pins on many strut vehicles and shock/strut attachment on many water cooled vehicles.....for the same reason they are used on this part.
If that bolt breaks or falls out......Jesus is coming for you....or you better be "right" with your Jesus.....because your steering control has just evaporated!
Ray |
Posted: Fri Jan 19, 2018 10:57 am Post subject: Re: Steering Coupling Flange Splines |
... If that bolt breaks or falls out......Jesus is coming for you....or you better be "right" with your Jesus.....because your steering control has just evaporated!
Ray |
You nailed it.
Aloha
tp |
