surfbus23 Samba Member
Posted: Fri Jan 19, 2018 11:11 am Post subject: Re: Steering Coupling Flange Splines |
As long as I have peoples' attention can someone help me out with where the horn ground attaches on the underside of a late bay. I only took a picture of the top broken piece and can't remember where the bottom goes and can't search up a picture.
Posted: Fri Jan 19, 2018 12:22 pm Post subject: Re: Steering Coupling Flange Splines |
I think I'm just supposed to mate the top and bottom per this:
Posted: Fri Jan 19, 2018 1:49 pm Post subject: Re: Steering Coupling Flange Splines |
Yeap, that is all you need to do. |
Posted: Fri Jan 19, 2018 5:53 pm Post subject: Re: Steering Coupling Flange Splines |
Alright. Got that all fixed up. Looks pretty good and safe. Re: the Jesus Bolt can anyone confirm a torque of 14ft-lb?
Bentley shows an entry for "flange to steering worm" but this is only up to 72. It's sort on entries in from 72. I'm thinking maybe this is just the extra entries though and these other ones are still good. |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Jan 19, 2018 6:59 pm Post subject: Re: Steering Coupling Flange Splines |
I think the flange is used on several years so the torque requirements should be the same. OG is a castellated nut with cotter pin, but I used a nylon lock nut on mine.
Aloha
tp |
Posted: Fri Jan 19, 2018 7:10 pm Post subject: Re: Steering Coupling Flange Splines |
Tom Powell wrote: |
Aloha
tp |
Sweet. Thanks! For some reason my OG nuts and bolts from a 72 were in amazing shape. They still had the original galvanized coating intact, which for anywhere on the bus is amazing, but for the that location confuses me. Went with the cotter pin because it seemed fun but also still safe. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Sat Jan 20, 2018 11:38 am Post subject: Re: Steering Coupling Flange Splines |
I have seen a few copper plated bolts in some of these through the years as I think Wildthings mentioned.
While copper has no sacrificial anode qualities per-se to steel in open air....its a great anti-seize lubricant in this highly rust prone location. Same reasoning behind copper plated nuts on exhaust studs and mufflers.
It does bear thinking about...that this part and its bolt would be ideal candidates for a simple zinc plating. Ray |
Terminatez Samba Member
Joined: June 07, 2015 Posts: 340 Location: Sun Valley, CA
Posted: Sat Jan 20, 2018 11:46 am Post subject: Re: Steering Coupling Flange Splines |
So, what would be the correct bolt/grade to use before getting a visit from Jesus? _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
I don't think I've ever seen an engine in worse shape. |
Posted: Sat Jan 20, 2018 12:28 pm Post subject: Re: Steering Coupling Flange Splines |
Terminatez wrote: |
So, what would be the correct bolt/grade to use before getting a visit from Jesus? |
I know. I'm all worried now too. Mine was a 10.9. Kept the bolt replaced the self-locking nut with a 10.9 zinc plated one. Torqued down to 14ft-lb. Seems about the correct thing to do from what I can find. |
Posted: Sat Jan 20, 2018 12:31 pm Post subject: Re: Steering Coupling Flange Splines |
Terminatez wrote: |
Its not so much the grade of the bolt....its the type of lock nut. You would be hard pressed to generate enough turning force break a basic class 8.8 bolt here unless you hit a curb at 50 mph...and then in that case this bolt is the least of your problem
I have no idea what the bus part number for this bolt is but the one on my 412...which looks to be virtually identical is 111 415 421 A.
Its an M8 x 37mm length. It uses a self locking nut. On my car...it used one of those original metal tab style locking nuts. Since this area sees no heat...I see no reason why a metric nylock nut would not work.
Typically when those old school style metal insert locking nuts were used...the bolt was a class 10.9 to keep from tearing up the bolt. I will have to check though. Ray |
Posted: Sat Jan 20, 2018 1:44 pm Post subject: Re: Steering Coupling Flange Splines |
Hi Ray,
I'm curious. I don't know much about lock nuts. I went with one of these https://www.fastenal.com/products/details/90681 which are the oval shaped lock nuts. How do these compare to a Nylock version?
Thanks! |
Posted: Sat Jan 20, 2018 2:01 pm Post subject: Re: Steering Coupling Flange Splines |
IMO:
If the lock nut fails, you will not immediately lose steering. The clamp will no longer be tight and the flange will move/rotate slightly on the shaft. The bolt will still be in the groove and the symptoms will be slop not failure.
Aloha
tp |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Jan 20, 2018 4:25 pm Post subject: Re: Steering Coupling Flange Splines |
More of my opinion...
The shitty spines you are seeing on the flange are the result of the harder steel steering box shaft's splines indenting into the softer flange metal. You are looking at ghosts... it's not supposed to carefully index like a true male and female spline arrangement. The one set of splines on the male shaft provides a nice grip to that flange when you tighten it. It's ribbed for her pleasure. That's correct that the new female flange is smooth. |
Posted: Sat Jan 20, 2018 4:57 pm Post subject: Re: Steering Coupling Flange Splines |
The correct torque for an M8 10.9 bolt is about 24 ft*lbs. With a lock nut, especially a distorted thread locknut you will use up some of the torque just forcing the bolt through the locknut, so if you don't go high enough you will not be getting sufficient pinch in the clamp to prevent relative movement of the mating parts. I really prefer Loctite for such uses even if I might still use a locknut. Clean the bolt and nut well, spray with cleaner and blow dry, and then apply Loctite and torque to spec for the 10.9 bolt or higher grade bolt you should be using.
Note that you can probably find 10.9/12.9 Nylocks either at your local hardware or at a place like Fastenal. Buy a whole box if need be, you will eventually use them. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
surfbus23 wrote: |
For the record, the horn ground wire normally routes to the inside of the steering coupler disc, right through the middle of the hole. It passes easily under the flanges.
Colin _________________ www.itinerant-air-cooled.com |
Posted: Sat Jan 20, 2018 6:21 pm Post subject: Re: Steering Coupling Flange Splines |
I hate the distorted style lock nuts like those. Unless the bolt is much harder than the nut....about 8 out of 10 times.....the distorted lock nut bungs up the threads of the bolt.
This is one of the few places in the entire car where a nylon insert locknut is ideal.
I also would rather use locktite here. And....on my car....and I realize its not a bus....but VW put some of that white goo on the threads to lock them. Locktite would be just as well. Ray |
Posted: Sat Jan 20, 2018 6:36 pm Post subject: Re: Steering Coupling Flange Splines |
Thanks for the info. When you guys mention locktite, are you talking about the blue thread locker? _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
Posted: Sat Jan 20, 2018 10:01 pm Post subject: Re: Steering Coupling Flange Splines |
Terminatez wrote: |
Thanks for the info. When you guys mention locktite, are you talking about the blue thread locker? |
Yes....use the blue 242. It worka fine. Though the red is more aggressive....its just not necessary and requires heat of about 500+ to break loose. Ray |
