Koeppler Samba Member
Joined: April 21, 2011 Posts: 481 Location: Aging gracefully
Posted: Fri Jan 19, 2018 6:22 am Post subject: Best Early Bay Stock Aftermarket Exhaust? |
NOS exhaust systems for the early bay aren't easy to find! It looks like later ones are more common. I want to know who makes/sells a good and reliable or at least a relatively good and reliable (compared to OG) aftermarket exhaust for a stock 1600 SP motor.
If this is one for the "stupid question thread" please move! |
Manfred58sc Samba Member
Posted: Fri Jan 19, 2018 10:43 am Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
https://www2.cip1.com/ProductDetails.asp?ProductCode=C13-3300
It fits OK and lasts for about 5-6 years. Tucks up nice in the limited space. Ad your own "heat ports" by carefully removing them form an OG muffler. Minor modification will make them work. The "extractor" types with bolt on mufflers rust out very quickly. _________________ Fat chick owner/operator |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Randy in Maine Samba Member
Posted: Mon Jan 22, 2018 11:27 am Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
I assume you are looking for one that also heats up the center mounted carb. Is that correct? |
Posted: Mon Jan 22, 2018 1:17 pm Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
Yes, I'm looking for one with good pre-heat and no internal restrictions like I've read about some other stock exhausts having! |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2535 Location: Ocean Beach in Beautiful BLUE California
Posted: Mon Jan 22, 2018 2:16 pm Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
I have the one Toolbox receommended from Autohaus. It has been on 5-6 years now and is in good shape. (And I life very close to the ocean.). The resonators only hast about two years for me, though. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
Posted: Tue Jan 23, 2018 10:52 am Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
Get the Dansk. It is not NOS quality, but about as close as you're gonna get.
They are somewhat of a PITA, but overall the best bang for your buck. |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Tue Jan 23, 2018 10:59 am Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
https://www.thesamba.com/vw/classifieds/detail.php?id=2078334
I only buy the old Leistritz when i can.
I had a Dansk on a beetle years ago. It was fine but it wasnt a perfect lineup in the ports. That could be a different story now. |
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1289 Location: roseville, ca
Posted: Wed Jan 24, 2018 7:20 am Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
I had a Dansk for about 2-3 years before it started falling apart. Reasonable fit, decent price. |
Posted: Wed Jan 24, 2018 12:27 pm Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
Is the Dansk pretty much what everyone carries these days for stock mufflers? The ones at Wolfsburg West, aircooled.net, Bus Depot, etc. all pretty much have that generic stock look. |
djdh68dlux Samba Member
Joined: February 24, 2005 Posts: 770 Location: I.E., SoCal
Posted: Thu Jan 25, 2018 3:46 pm Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
About 5-6 years ago I bought an Ernst German exhaust from BusDepot. At the time they (BusDepot) were claiming that Ernst was the OEM supplier. I know that Ernst is no longer making them, but have also since learned that Leistritz was the actual OEM. So not really sure who was OEM or not, but the German Ernst exhaust I bought is still holding up nicely. Never had a Dansk, so can't comment on quality/longevity. _________________ 1968 Deluxe "Clipper L" Type 2
Looking for a VW club in Southern California? Check out Inland Valley Volkswagens: www.ivvw.org |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Jan 25, 2018 3:50 pm Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
Koeppler wrote: |
The "internal restriction" actually winds up being a 1200 tailpipe and bung. If you can weld, get a late Type 3 one piece tail pipe, and a hole cutter to make the TP bung hole (did you see what I did there? ) large enough to weld the Type 3 pipe into. Use ultra high temp VHT ceramic primer and paint to seal it all up and prevent the muffler from insta- rusting.
Forgot- I had to get an ext. made for the muffler end of the Type 3 TP to get it to work. Here it is with the original 1200 "choker" on top of it.
Forgive the Neanderthal welds.
Finished product with adapted Porsche 911 type tail pipe cover to make it go faster:
_________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Busdepot Samba Member
Posted: Fri Jan 26, 2018 9:18 am Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
With the Leistritz and Ernst gone (and NOS ones getting rustier and harder to find), the Dansk is the best bet out there. The only other stock setups are coming out of China and are pretty bad, and the aftermarket ones I've seen are nowhere near the quality of the Dansk. We sell a complete kit that includes everything you need - muffler, tailpipe, hardware, gaskets, etc. - http://www.busdepot.com/211251053ec _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
Posted: Fri Jan 26, 2018 3:36 pm Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
Tram wrote: |
to make the TP bung hole (did you see what I did there? ) |
Nice Cornholio reference! _________________ 1968 Deluxe "Clipper L" Type 2
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Fri Jan 26, 2018 3:53 pm Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
Busdepot wrote: |
With the Leistritz and Ernst gone (and NOS ones getting rustier and harder to find), the Dansk is the best bet out there. The only other stock setups are coming out of China and are pretty bad, and the aftermarket ones I've seen are nowhere near the quality of the Dansk. We sell a complete kit that includes everything you need - muffler, tailpipe, hardware, gaskets, etc. - http://www.busdepot.com/211251053ec |
That’s a slick looking damper/tailpipe combo. I hope it mutes as well as the original style.
Either way, it looks better than the split window tailpipe grafted onto a bay muffler catching curbs and parking bumpers at every opportunity..... not that Every parts supplier wasn’t shipping those to every bay window customer for the last ten years or anything....
www.airschooled.com |
HarryFD Samba Member
Joined: February 24, 2012 Posts: 751 Location: Portland, OR
Posted: Fri Jan 26, 2018 9:44 pm Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
Busdepot wrote: |
Question. Dansk Muffler? _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
Xevin Samba Member
Posted: Fri Jan 26, 2018 10:35 pm Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
djdh68dlux wrote: |
Tram wrote: |
Nice Cornholio reference! |
Settle down Beavis _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Sat Jan 27, 2018 6:05 am Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
HarryFD wrote: |
Busdepot wrote: |
Question. Dansk Muffler? |
Yeah, the whole kit is from Dansk. It is a European market kit that we import ourselves. I don't believe it's sold in the U.S. _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Jan 27, 2018 9:46 am Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
Busdepot wrote: |
HarryFD wrote: |
Busdepot wrote: |
Yeah, the whole kit is from Dansk. It is a European market kit that we import ourselves. I don't believe it's sold in the U.S. |
Glad I got my Ernst from you when I did. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Sat Jan 27, 2018 12:28 pm Post subject: Re: Best Early Bay Stock Aftermarket Exhaust? |
Yeah, the Ernst is history. The European market Dansk is the best out there now. Once Dansk stops making them it will be cheap Chinese or nothing. _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
