How to fix bad body work
morgan8899
morgan8899 is offline
PostPosted: Fri Jan 19, 2018 8:07 am    Post subject: How to fix bad body work Reply with quote
How should I fix this surprise? I uncovered it after sand blasting. I was thinking I should cut it out, flatten it, then weld it back in. Or even replace with new metal.
sputnick60
sputnick60 is offline
PostPosted: Fri Jan 19, 2018 8:29 am    Post subject: Re: How to fix bad body work Reply with quote
You have my commiserations.
You can search in the samba classified advertisement for the metal you need
There is lot there that might work fo you. It just depends on how you measure value.
https://www.thesamba.com/vw/classifieds/search.php...ton=Search
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
crazy tarzan
crazy tarzan is offline
PostPosted: Fri Jan 19, 2018 9:22 am    Post subject: Re: How to fix bad body work Reply with quote
I'd cut that out and weld new in.
That's going to take a lot of work to reshape and fix. Welding in new is only going to take the work welding causes.
CiderGuy
CiderGuy is offline
PostPosted: Fri Jan 19, 2018 9:28 am    Post subject: Re: How to fix bad body work Reply with quote
I agree I think its your only option. Never cut anything until you have the replacement panel in hand.
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything
c21darrel
c21darrel is offline
PostPosted: Fri Jan 19, 2018 12:56 pm    Post subject: Re: How to fix bad body work Reply with quote
Ouch.
Agree, you gotta cut and replace.
GhiaBuild
1967 DC build
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Jan 19, 2018 1:05 pm    Post subject: Re: How to fix bad body work Reply with quote
Or buy another shell & let someone else have they joy of repairing that.
Mellow Yellow 74
Mellow Yellow 74 is offline
PostPosted: Fri Jan 19, 2018 3:31 pm    Post subject: Re: How to fix bad body work Reply with quote
You could remove that quarter panel and repair a lot of that damage using a hammer and dolly but it would still have all the slide hammer holes you would need to weld up. However this would be a lot of work and if you are going to the trouble of removing and replacing the quarter you would be better off finding a decent used quarter panel.
1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon)
Evil_Fiz
Evil_Fiz is offline
PostPosted: Sat Jan 20, 2018 9:39 am    Post subject: Re: How to fix bad body work Reply with quote
Goo d point but it also presents a good practice opportunity if you don't yet poses metal working skills. Replace the quarter as suggested and then use the removed piece for practice. Once straight, you could sell it or "part it forward."
“…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted
Loren
Loren is offline
PostPosted: Sat Jan 20, 2018 10:37 am    Post subject: Re: How to fix bad body work Reply with quote
What year is your Ghia? I have a 63 quarter panel that needs work, but it might work for your project and I don't want much for it. It includes the inner fender too. PM me if you are interested.
kingkarmann
kingkarmann is offline
PostPosted: Sat Jan 20, 2018 1:40 pm    Post subject: Re: How to fix bad body work Reply with quote
Is there a "before" photo by chance?
"Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"?
morgan8899
PostPosted: Sat Jan 20, 2018 9:26 pm    Post subject: Re: How to fix bad body work Reply with quote
Thank you all for your reply's. I attempted using a stud welder and pulling, but there is way to much damage to continue. I will be cutting that section out later this month I'll let you know how that works
kman
kman is offline
PostPosted: Sun Jan 21, 2018 1:38 pm    Post subject: Re: How to fix bad body work Reply with quote
I'd fix it only cause I'm that stubborn. Cut the entire panel out. Use a sandbag and sheet metal bossing mallets back and forth with hammer/dolly work. Test fit often after repairing the interior panel. You will have to do some heat shrinking. Welding up the holes will do some of that. Keep at it till you get there. Or buy a new panel but it's all metal in the end.
71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead
morgan8899
PostPosted: Thu Oct 18, 2018 12:43 pm    Post subject: Re: How to fix bad body work Reply with quote
I purchased a replacement panel from a shop in CA and welded in the replacement.
Mellow Yellow 74
PostPosted: Thu Oct 18, 2018 1:13 pm    Post subject: Re: How to fix bad body work Reply with quote
Looks much better
1962 Karmann Ghia
kiwighia68
kiwighia68 is offline
PostPosted: Thu Oct 18, 2018 1:23 pm    Post subject: Re: How to fix bad body work Reply with quote
Contact Dan Storgaard (NWGHIAGUY) if I remember correctly) for good replacement panels. He's not to far from you and utterly reliable and his parts are affordable.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
morgan8899
PostPosted: Fri Oct 19, 2018 7:52 pm    Post subject: Re: How to fix bad body work Reply with quote
Thank you. i’ll keep that info handy. All of the patch panel work is finished. It’s time for leading and bondo to smooth it out.
carguytroy
carguytroy is offline
PostPosted: Sat Oct 20, 2018 6:10 pm    Post subject: Re: How to fix bad body work Reply with quote
Looks great. Done a lot of metal work on a 66 Mustang I had. Have a 67 Convert that needs a ton too. Great job!
jeffrey8164 Premium Member
jeffrey8164 is offline
PostPosted: Sat Oct 20, 2018 7:21 pm    Post subject: Re: How to fix bad body work Reply with quote
I want a welder!
It seems as if I could do cool stuff with a welder.
But then I’d need a torch with a bunch of different attachments, a plasma cutter, a pneumatic nipper, a break and probably a lathe too.
Anything I’m forgetting? Oh! A hammer and dolly set.
Volkswagen!
(Compression 8.7:1)
Evil_Fiz
Evil_Fiz is offline
PostPosted: Sun Oct 21, 2018 7:32 am    Post subject: Re: How to fix bad body work Reply with quote
jeffrey8164 wrote:
...Anything I’m forgetting? Oh! A hammer and dolly set.
... and an english wheel, planishing hammer, bead roller, bossing hammer, shrinking stump, leather sand bag, shriner-stretcher, slapper spoons, vice mount shaping dollies, fixturing jigs, dead flap and level welding table, drill press, band saw, and a 24 x 30 workshop to spread-out in.
Emil
kiwighia68
PostPosted: Sun Oct 21, 2018 8:45 am    Post subject: Re: How to fix bad body work Reply with quote
Well I have one of these, so I’m almost there. Brick wall ]
Volkswagen!
(Compression 8.7:1)
