Dailydubs Samba Member
Joined: June 10, 2017 Posts: 2 Location: Columbus, Ga
Posted: Fri Jan 19, 2018 9:25 am Post subject: Any info on this style fan shroud? |
Hello I'm hoping someone can identify this fan shroud? Is it available through a supplier or a custom piece? Any help would be appreciated.
_________________ For all your Aircooled Parts & Accesories visit us @
www.dailydubsvw.com |
AlteWagen Troll
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Fri Jan 19, 2018 9:38 am Post subject: Re: Any info on this style fan shroud? |
That looks like a custom piece. ..I believe the builder rolled some tubing to match the 36hp fan shroud profile, cut the tubing in half and then welded it to the flat profile. ..it's not hard to do, it will be a tedious time consuming mod...from what I see he did an excellent job. ..I might try that some day. ...very cool |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Fri Jan 19, 2018 9:48 am Post subject: Re: Any info on this style fan shroud? |
It's a modified aftermarket 36hp dog house shroud.... It's custom. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Jan 19, 2018 9:54 am Post subject: Re: Any info on this style fan shroud? |
Thanks for the quick replies. Im am going to attempt this soon and I will post pics of the outcome. If it turns out well we might offer a limited run of them on our website. _________________ For all your Aircooled Parts & Accesories visit us @
nextgen Samba Member
Joined: August 19, 2004 Posts: 6029 Location: CONGERS, N.Y.
Posted: Fri Jan 19, 2018 2:13 pm Post subject: Re: Any info on this style fan shroud? |
I like the way it looks!!! Working with fanhousings with Cali Style taught me even small changes make a difference either better or worse. If it was one of the better, meaning close to OEM and no vanes were removed or moved, OK good start. I would think the height would be the same as stock due to it fitting in the car. If not it would be higher or lower. Stock tops are flat. Does round flow air better, Surely you loose some area , by cutting corners, a pun.. but serious. '
Keep in mind the 36 hp fanhousing with a doghouse was not stock to begin with . Works great, that is what I use in manual.
A T-4 is very forgiving and runs cooler then a T-1 due to the 1/3 larger heads dissipating heat, so you have less worry about some non OEM mods.
A T-1 fanhousing is right on the fence when it comes to cooling . Not plugging a hole here or there makes a difference.\
Hay if not problem found with a rise in temp great.
So what do we know besides it looks great.
Would I sell a bunch and wait to see if I get a law suit, not me. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Fri Jan 19, 2018 4:42 pm Post subject: Re: Any info on this style fan shroud? |
One hopes the internals were kept so the vanes are still there and doing their job. I would guess someone that particular would have done so! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Fri Jan 19, 2018 6:22 pm Post subject: Re: Any info on this style fan shroud? |
That is an awesome looking show car engine, but I would guess it would run very hot and overheat in an actual street driven car. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Fri Jan 19, 2018 6:31 pm Post subject: Re: Any info on this style fan shroud? |
vwracerdave wrote: |
That is an awesome looking show car engine, but I would guess it would run very hot and overheat in an actual street driven car. |
What do you see, or don't see that is telling you it will over heat? _________________ Good Luck
Al |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Fri Jan 19, 2018 6:42 pm Post subject: Re: Any info on this style fan shroud? |
I could swear I remember seeing a handful of these at the Sacto BOR years ago. IIRC they were not modified stock shrouds. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
Posted: Fri Jan 19, 2018 9:42 pm Post subject: Re: Any info on this style fan shroud? |
ach60 wrote: |
What do you see, or don't see that is telling you it will over heat? |
Shroud, power pulley, oil filter & lines location. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sat Jan 20, 2018 5:58 am Post subject: Re: Any info on this style fan shroud? |
Looks great - almost art deco...Very clean...Interesting choice of colors, but it works very well. Asside from the power pulley, i don't see anything that is really an issue myself - Yeah - oil lines are a little closer to the header than I would like, but have sen a lot of cars like that. And it has a doghouse, which helps.
to the designer/builder. _________________ D-Dubya Manx clone - 63 Short pan,1914.
dsrtfox Samba Member
Posted: Sat Jan 20, 2018 12:10 pm Post subject: Re: Any info on this style fan shroud? |
It doesn't look like he necessarily cut the flat top off, he could have just welded the curve over it... |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Sat Jan 20, 2018 12:25 pm Post subject: Re: Any info on this style fan shroud? |
Donīt think its a power pulley, but the oil filter location is hopefully just for show.
T |
Posted: Sun Jan 21, 2018 9:10 am Post subject: Re: Any info on this style fan shroud? |
That's a common place to mount an external filter. There are numerous companies making brackets to mount them like that.
Nothing about that screams that it would overheat. The whole "if it's not a stock shroud outs gonna overheat" bs needs to gtfo. _________________ Eric Allred
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sun Jan 21, 2018 12:37 pm Post subject: Re: Any info on this style fan shroud? |
Eaallred wrote: |
Nothing about that screams that it would overheat. The whole "if it's not a stock shroud outs gonna overheat" bs needs to gtfo. |
It was also a common thing to mount your oil cooler infront of the fan shroud opening. I'm with Dave. Lets take an aluminum bracket attached to one of the hottest areas of the engine, mount an aluminum filter mount to it, and place our AN aluminum fittings inches away from the header.... I had a 20 degree oil temp drop by simply installing a Mallory spark plug wire heat shield over a set of braided lines around the header on a filter mount in the fender well. I've run 36hp doghouse shrouds on performance engines for probably 20 years without issue, so I'm with you on the cooling set up doesn't have to be 100% stock, but those filter mounts are just plain stupid. Its fine if the shroud has had the curve added to the top of a functional shroud, but if its completely open inside, good luck. Also good luck getting a deck lid spring to clear it. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Sun Jan 21, 2018 4:01 pm Post subject: Re: Any info on this style fan shroud? |
Eaallred wrote: |
I could swear I remember seeing a handful of these at the Sacto BOR years ago. IIRC they were not modified stock shrouds. |
Yep, I believe "Fresno James" made them, bike fender on a 36hp shroud. _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
s.e.charles Samba Member
