vvolfbus Samba Member
Joined: October 05, 2017 Posts: 62 Location: Breckenridge, Colorado
Posted: Fri Jan 19, 2018 12:09 pm Post subject: Every Auxiliary Battery thread is full of dead images! |
Hello friendly Samba community,
I am trying to get my 78 Bus ready for winter camping and want to start by adding an auxiliary battery. I've spent about three hours reading threads on here trying to find clear, step by step directions, with a list of needed parts.
Those that seem promising are full of dead images and disagreements in the comments about the steps taken by the lead post. Is there a tutorial anywhere out there (I checked Ratwell, Air-cooled, and lots of Google searching) that has a clear instructional for Type 2s with a list of parts that a beginner can understand?
Thank you for your help!
Nicole |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Jan 19, 2018 2:27 pm Post subject: Re: Every Auxiliary Battery thread is full of dead images! |
Nichole, I am a huge fan of simple. I bought one of these to hook up an aux battery on a customer's Riviera:
Red is where your regular battery hooks up. Black is to your switched ignition power- e.g., activates and closes the bridge between the two big terminals with the key on only. Blue goes to the + side of your aux battery. I used a heavy duty marine battery in this case.
The function of the solenoid is such that with the key off whatever you are running on the aux battery cannot drain the starting battery. Easy peasy and dead simple. Cheap too... $23 on Amazon. Buy an extra just in case.
https://www.amazon.com/Tow-Ready-118665-Isolation-Solenoid/dp/B004R36U8M
Note that in order to function this needs to be mounted to body metal to ground. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Fri Jan 19, 2018 3:14 pm Post subject: Re: Every Auxiliary Battery thread is full of dead images! |
The simplest setup is how Westfalia did it originally for deluxe campmobiles.
Get yourself a 40 amp bosch style relay and wire it up they way Westfalia did it.
If you're unfamiliar with how a relay works. It's basically an automatic on/off switch. So when you start up the bus the blue alternator wire gets power, then opens the relay and connects the two batteries in parallel allowing both to be charged from the alternator. _________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Fri Jan 19, 2018 3:17 pm Post subject: Re: Every Auxiliary Battery thread is full of dead images! |
Bullshit. I am a paying customer of Photobucket and I think all of my images are fine. Like here
https://www.thesamba.com/vw/forum/viewtopic.php?t=682069&highlight=aux+battery _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Jan 19, 2018 3:30 pm Post subject: Re: Every Auxiliary Battery thread is full of dead images! |
So you paid the Bucket Mafia their tribute, eh? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Fri Jan 19, 2018 4:04 pm Post subject: Re: Every Auxiliary Battery thread is full of dead images! |
Tram wrote: |
So you paid the Bucket Mafia their tribute, eh? |
I wouldn’t put it that way. I realized about 8 years ago that I was going to need more space so I started paying them something like $40 for two years. Right now I think I have roughly 6 months left before I need to do anything. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Fri Jan 19, 2018 7:07 pm Post subject: Re: Every Auxiliary Battery thread is full of dead images! |
STop reading the threads , 95% of which are poor workmanship , and get a good book on wiring like Don Casey’s Book on marine wiring
Expertise is not a quantity that lends itself to collectivism , and wiring requires expertise. _________________ .ssS! |
Posted: Fri Jan 19, 2018 8:04 pm Post subject: Re: Every Auxiliary Battery thread is full of dead images! |
Actually, West Marine has some good tech articles for free on their website. At least 2 or 3. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
