Jrm1080 Samba Member
Joined: December 21, 2012 Posts: 104 Location: Phoenix, Az
Posted: Sat Jan 20, 2018 1:29 pm Post subject: How do I remove this radio? |
‘67 Type I Saphire AM radio. I’m sending it for repair but I don’t want to break anything getting it out.
_________________ -Constant over thinker
-Figuring it out as I go. (With lots of Samba inquiries)
•’67 Type I mostly original semi daily driver (temperature permitting 🔥☀️)
•’74 Type I work in progress. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9663 Location: Oregon
Posted: Sat Jan 20, 2018 1:35 pm Post subject: Re: How do I remove this radio? |
Pull the knobs off the front and you will see the nuts that hold the radio and the face plate in the dash.
Make note of where the wiring is connected in the trunk. Be careful removing the antenna cable. You can pull the connector off if it's stuck.
In the trunk remove the nut that is strapped to the back of the radio chassis and loosen the bolt above it at the windshield wiper motor. Swing the bracket out of the way and gently slide the radio out of the opening. Be careful not to scratch the radio. It appears to be in good nick.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sat Jan 20, 2018 2:36 pm Post subject: Re: How do I remove this radio? |
67rustavenger wrote: |
Good Luck. |
So just grab the knobs and pull? I tried that earlier but they seemed pretty snug so I figured I’d ask before I broke something. _________________ -Constant over thinker
scubaseas Samba Member
Joined: May 24, 2013 Posts: 442 Location: ME & Texas, in a Bus or on a boat somewhere
Posted: Sat Jan 20, 2018 2:44 pm Post subject: Re: How do I remove this radio? |
Quote: |
So just grab the knobs and pull? I tried that earlier but they seemed pretty snug so I figured I’d ask before I broke something. |
Yes. Pull straight back. Someone may have glued them on. Best of luck. _________________ Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired |
rcroane Samba Member
Joined: January 03, 2013 Posts: 1996 Location: Springfield, Virginia
Posted: Sat Jan 20, 2018 2:45 pm Post subject: Re: How do I remove this radio? |
Yes, they should pull straight off. They've probably been on there for 50 years, so not surprised they are snug. _________________ '65 Sunroof Bug |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sat Jan 20, 2018 4:08 pm Post subject: Re: How do I remove this radio? |
And don’t throw the radio away- it is now a collector item for anyone who wants a period correct Sapphire radio, for their car or for their collection. Check the classifieds on this site to see what people are asking for that model. _________________ Plate of shrimp |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Jan 20, 2018 5:55 pm Post subject: Re: How do I remove this radio? |
Disconnect ground wire to your battery first!
If you can listen to that radio with the ignition off- be safe. Electrical fires claim more VWs than divorces.
If you cannot pull the knobs off- try this: make a loop with a long shoelace, slip it behind the knob, and twist until it is a tight braid from end to end. Pull the two ends and- voila'- knobs are off. Two hands pull straighter than one. _________________
EverettB wrote: |
FU#5 |
bluebus86 Banned
Posted: Sat Jan 20, 2018 7:13 pm Post subject: Re: How do I remove this radio? |
of course check for set screws on the knobs, usually not present, but every now and then someone slips on a knob with a set screw. Happened on my 63 Bus.
good luck9 _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Sat Jan 20, 2018 10:35 pm Post subject: Re: How do I remove this radio? |
panicman wrote: |
And don’t throw the radio away- it is now a collector item for anyone who wants a period correct Sapphire radio, for their car or for their collection. Check the classifieds on this site to see what people are asking for that model. |
No danger of that my friend. I’m getting it restored. 😉 _________________ -Constant over thinker
