Zinc plate, black oxide or painted for various parts of 57 Oval?
TSLAVO
TSLAVO is offline
PostPosted: Mon Jan 22, 2018 1:45 am    Post subject: Zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
I am trying to consolidate all small parts and complete the finishing at once to save time and cost. Are they zinc plated (silver), black oxide, painted black or other colors? Appreciate help on any of below..
1) Crankshaft pully bolt
2) Generator pully nut & dished washer
3) Generater strap
4) 0il strainer cover
5) coil bracket
6) oil bath clamp
7) front inspection cover
8| Front Chasis inspection plate
9) chasis to body plate/washer
10) Axle beam upper pad mounting plate
11) Stop plate /Spring (shift rod)
12) wheel backing plate
13) brake drum
14) Tie Rod
15) Steering box drop arm
16) front axle
17) Spring plate
18| Spring plate cover
19) Shift rod inside chasis
20) window lift channel
21) felt channel support rail
22) window regulator
23) door armrest bracket
24) arm rest support post
25) door lock remote with arm
26) door lock machanism
27) speedometer cable tube
28| Rear seat rail
29) Seats frame
30) headliner bow
31) Running board
32) signal switch arm
33) Gas tank clamp
34) deck lid lock catch
35) hood lock pin and catch
36) headlight inner bracket (euro type)
37| Battery strap
38| Transmission carrier
39) bumper bracket
40) bumper enforcement plate
41) rear of bumper
42) rear of bumper guard
splitjunkie
splitjunkie is offline
PostPosted: Mon Jan 22, 2018 8:48 am    Post subject: Re: zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
I can tell you this. The entire front suspension was assembled of unpainted parts all the way to the brake drums and bearing covers and steering box. The shocks were the only thing that were already painted. Once the entire front end was assembled it was painted as one assembly. They painted over the fasteners, rubber seals and shock absorbers.
Chris
splitjunkie
PostPosted: Mon Jan 22, 2018 8:59 am    Post subject: Re: zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
TSLAVO wrote:
I am trying to consolidate all small parts and complete the furnishing at once to save time and cost. Are they zinc plated (silver), black oxide, painted black or other colors? Appreciate help on any of below..
1) Crankshaft pully bolt unpainted, unplated
2) Generator pully nut & dished washer dished washer black paint
3) Generater strap zinc plate
4) 0il strainer cover black paint
5) coil bracket zinc plate
6) oil bath clamp zinc plate
7) front inspection cover black paint
8| Front Chasis inspection plate black paint
10) Axle beam upper pad mounting plate zinc plate
12) wheel backing plate black paint outside only
13) brake drum black paint outside only
14) Tie Rod black paint
15) Steering box drop arm black paint
16) front axle black paint
17) Spring plate
18| Spring plate cover black paint
19) Shift rod inside chasis unplated
20) window lift channel black paint
21) felt channel support rail black paint
22) window regulator unplated
23) door armrest bracket black paint
26) door lock machanism zinc plate
27) speedometer cable tube body color. Assembled to the body when painted
28| Rear seat rail
29) Seats frame
30) headliner bow zinc plate
31) Running board black paint
33) Gas tank clamp
34) deck lid lock catch zinc plate
37| Battery strap black paint
38| Transmission carrier black paint
39) bumper bracket black paint for oval era
40) bumper enforcement plate black paint for oval era
41) rear of bumper silver
Here is most of it but some does depend on what era the car is.
Chris
TSLAVO
TSLAVO is offline
PostPosted: Mon Jan 22, 2018 9:03 pm    Post subject: Re: zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
17) Spring plate
28| Rear seat rail
29) Seats frame
33) Gas tank clamp
Thanks Chris for answering most of them. I have put the answer in bold for easier reading. I am referring to 57 oval as the subject line say.
Surprisingly there isn't anything in black oxide.
AlteWagen
Troll
AlteWagen is offline
PostPosted: Mon Jan 22, 2018 11:04 pm    Post subject: Re: zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
Aren't the fender bolts black oxide?
Official Dual Carb Thread
62ItalianRagtop
62ItalianRagtop is offline
PostPosted: Tue Jan 23, 2018 12:22 am    Post subject: Re: zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
Interesting Shocked
So under the black of shock absorber is there another paint color ?
If should you restore a front axle would you follow this procedure ?
LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/
splitjunkie
PostPosted: Tue Jan 23, 2018 8:36 am    Post subject: Re: zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
Yes they are. I don't think he had them on his list.
Chris
splitjunkie
PostPosted: Tue Jan 23, 2018 9:02 am    Post subject: Re: zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
62ItalianRagtop wrote:
Interesting Shocked
Yes they were already painted by the supplier before they were assembled to the front end and then painted again when they painted the entire front end.
Chris
PostPosted: Tue Jan 23, 2018 9:26 am    Post subject: Re: Zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
I added this thread to the Oval FAQ as a reference so feel free to post up any other finish information as well, even if it's not in the list above.
Thanks to the people who have added information.
TSLAVO
TSLAVO is offline
PostPosted: Thu Jan 25, 2018 12:58 am    Post subject: Re: Zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
Without having further answer for the rest of the items. I am trying to find it myself. Immediately i thought of Bruce's 13k miles oval.
https://www.thesamba.com/vw/gallery/pix/1398713.jpg
Generator pully nut looks like unpainted and unplated
Crankshaft pully bolt - painted black?
https://www.thesamba.com/vw/gallery/pix/1398693.jpg
Turn signal arm - zinc plated
https://www.thesamba.com/vw/gallery/pix/1398694.jpg
Rear seat rails - painted black
https://www.thesamba.com/vw/gallery/pix/1398769.jpg
Seat frame - painted beige, should be L75
I also notice finish for items that i didnt put in my list
https://www.thesamba.com/vw/gallery/pix/1398708.jpg
tinware are in gloss paint and coil supplied by Bosch is in semi-gloss finish. Chris mentioned it in other thread before.
https://www.thesamba.com/vw/gallery/pix/1398695.jpg
reserve level for fuel tab - painted black
https://www.thesamba.com/vw/gallery/pix/1398752.jpg
Shift gear, steering coloumn, emergency brake level all painted beige - L75
interestingly shift gear cover is painted black.
tinware fastener - zinc plated or unplated??
https://www.thesamba.com/vw/gallery/pix/1398730.jpg
rear seat support bar - painted beige L75
I also notice Last Trimph's 57 oval, hood lock pin catch is either painted black or black oxide. unfortunately all photos in his thread became dead photo link. I have saved some of the photos previously.
Dan22
Dan22 is offline
PostPosted: Sat Apr 25, 2020 11:25 am    Post subject: Re: Zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
Reviving older thread but relevant to all who continue restorations!
My case: 55 oval.
What type of coating?
1. Throttle tube
2. Throttle spring
3. Throttle spring cover, and clip thingy
4. Lug nuts
5. Rear axle nut
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
BulliBill
BulliBill is online now
PostPosted: Mon Nov 30, 2020 11:24 am    Post subject: Re: zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
17) Spring plate
28| Rear seat rail
29) Seats frame
33) Gas tank clamp
As mentioned above in #39, the front and rear bumper brackets are painted black (matte). I'm not certain what is being referred to by #40 bumper enforcement plate above, but on my un-molested/un-restored June of 1955 Oval Sunroof, the four support tubes that pass thru the fenders to support the USA spec front and rear bumper guard/over-rider tubes are also painted matte black. I think they became painted silver a bit later on...
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
finster
finster is offline
PostPosted: Mon Nov 30, 2020 12:22 pm    Post subject: Re: Zinc plate, black oxide or painted for various parts of 57 Oval? Reply with quote
I think #40 refers to this part ...
