So I found a barn door
ALLWAGONS
ALLWAGONS is offline
PostPosted: Mon Jan 22, 2018 9:02 pm    Post subject: So I found a barn door Reply with quote
I recently came across this rust free barndoor for sale. I am definitely picking it up. It is missing some parts but owner stated they are all inside the car. Had to take a spy shot as he didn't want any pics taken. It is an 11 window. I am not new to busses as I own a '60 15 wind and an early '64 21 wind bus. But I am mostly a type 3 guy.
NON INFLUENCER APPROVED
PostPosted: Mon Jan 22, 2018 9:48 pm    Post subject: Re: So I found a barn door Reply with quote
Cool! Get it.
FYI, it looks like the nose might be clipped, it has the wiper arm depressions of a later Bus.
Barndoor with no large dip in the metal
ALLWAGONS
PostPosted: Mon Jan 22, 2018 9:50 pm    Post subject: Re: So I found a barn door Reply with quote
Cool! Get it.
Thanks, will look into it.
23 window mike
23 window mike is offline
PostPosted: Tue Jan 23, 2018 4:31 am    Post subject: Re: So I found a barn door Reply with quote
Hi great find that’s right for a barndoor later busses have much bigger recess for the wipers
56samba
56samba is offline
PostPosted: Tue Jan 23, 2018 4:37 am    Post subject: Re: So I found a barn door Reply with quote
Cool! Get it.
That was also my first thought Very Happy
Scotty
Scotty is offline
PostPosted: Tue Jan 23, 2018 6:27 am    Post subject: Re: So I found a barn door Reply with quote
Be sure to check the chassis number
mandraks
mandraks is offline
PostPosted: Tue Jan 23, 2018 8:20 am    Post subject: Re: So I found a barn door Reply with quote
Cool! Get it.
teh nose might be clipped all the way up to the roof? windows look too tall
regards
Uli
ALLWAGONS
PostPosted: Tue Jan 23, 2018 11:22 pm    Post subject: Re: So I found a barn door Reply with quote
At this point, not very worried about incorrect parts. I’ve see worse. But thanks for the good advice as I will need it.
Scotty
Scotty is offline
PostPosted: Wed Jan 24, 2018 3:03 am    Post subject: Re: So I found a barn door Reply with quote
My concern is that this bus didn't start life as barndoor at all. I don't know why, but the front of the roof just appears odd to me. Then factor in the incorrect bits on the front, and the fact you weren't allowed to take photos, it just makes me very suspicious. Just make sure it really is a barndoor before you hand over your cash
Lowdown Dirty Rat
Lowdown Dirty Rat is offline
PostPosted: Wed Jan 24, 2018 10:49 am    Post subject: Re: So I found a barn door Reply with quote
Agreed.
The steering wheel doesn’t look Barndoor. And maybe the bulkhead as well?
1951 Samba 20-017894
1952 Samba 20-028952
Joe Leroux
Joe Leroux is offline
PostPosted: Wed Jan 24, 2018 12:17 pm    Post subject: Re: So I found a barn door Reply with quote
I also don’t see the screw holes for the mirror
Jacks
Jacks is offline
PostPosted: Wed Jan 24, 2018 9:12 pm    Post subject: Re: So I found a barn door Reply with quote
The rear window doesn't look barndoor. Confused
Jack Staggs
Actual name
ALLWAGONS
PostPosted: Wed Jan 24, 2018 9:35 pm    Post subject: Re: So I found a barn door Reply with quote
Well, I've seen monstruosities and the rear rusty license plate holder of a barndoor be brought back into a full barndoor bus and no one has a problem with it. So this does not scare me, it is cheap and comes with a few parts. Yes it may not be correct but for the price, it will do. What ever happened to "Wow! another one saved?"
I'll keep you posted and I'll be back for advice, if it gets too complicated, then It will be sold.
PostPosted: Wed Jan 24, 2018 9:56 pm    Post subject: Re: So I found a barn door Reply with quote
FWIW, I'll assume it's legit but with a few repairs over the years until you know otherwise.
Not uncommon...
Let us know what happens.
Check for a VIN # out back or see if it at least has a round transmission carrier:
This is not Barndoor only but at least it's Wolfsburg Bus so you know it's early.
Lowdown Dirty Rat
PostPosted: Thu Jan 25, 2018 5:37 am    Post subject: Re: So I found a barn door Reply with quote
We all want to say "Wow! another one saved?" And you are right any Barndoor, rusty or bodged is a save. The comments above aren’t about that. It’s people concerned that you might not be buying a Barndoor at all! But a latter bus edited to look Barndoor. We are just trying to help know what your buying.
Scotty
Scotty is offline
PostPosted: Thu Jan 25, 2018 6:26 am    Post subject: Re: So I found a barn door Reply with quote
Sorry for being negative, I just wanted you to be sure that you knew if it was a genuine barndoor bus or not. I would hate for someone to be thinking they were buying a barndoor for it to turn out to be a modified later bus, especially if you had paid a genuine barndoor price for it.
ALLWAGONS
PostPosted: Thu Jan 25, 2018 2:44 pm    Post subject: Re: So I found a barn door Reply with quote
Not uncommon...
Thanks! anything else I may need to look for?
Brian_1952
Brian_1952 is offline
PostPosted: Thu Jan 25, 2018 4:16 pm    Post subject: Re: So I found a barn door Reply with quote
MORE pictures
(20-024785)Ambulance (20-037784)truck (20-035850)panel
(20-035778)kombi
WANTED 52 parts and NOS sheet-metal
PostPosted: Thu Jan 25, 2018 9:29 pm    Post subject: Re: So I found a barn door Reply with quote
I was thinking about easy stuff to spot and:
- Huge Barndoor decklid (obviously)
- Barndoor back window someone mentioned above - It's a trapezoid instead of a rectangle
- Dash is a little pod for Kombis and Standards
- 3-spoke steering wheel
- Front floor is totally flat, not like a later Bus where it swoops up near the nose and has a foot rest on the passenger side
- Cargo doors
Outside has a handle with the key hole underneath
Inside rear cargo latch is different than a later Bus
- The front seat bulkhead is flat all the way across - there is no spare tire well there.
Deluxe but see how it goes straight across
16" wheels that look like slightly larger Bug smoothie wheel
No slots like a later Bus 15" or 14" wheel
There is more stuff of course but that is some easy stuff to id
ryans65
ryans65 is offline
PostPosted: Fri Jan 26, 2018 10:57 am    Post subject: Re: So I found a barn door Reply with quote
Maybe it's just me but the rear window is visible in this pic and looks pretty darn square.
