Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Fri Jan 26, 2018 6:08 pm Post subject: Re: New German Brake Booster |
WendyArmbuster wrote: |
Hoody wrote: |
The Bus Depot is showing them in stock. Same price. |
The pictures look different, and the Bus Depot description says I will have to redrill my mounting plate. It could be that the CIP one requires a redrill as well, but they just don't say it, and the photos could just be representational. I don't know. |
the re-drill (I have commented on this before) is a joke.....you need to weld on to the OE bracket about 3/4" then drill that because the spacing of the studs is at the edge of the OE vw bracket on out busses. at least that is what I ran into _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Hoody Samba Member
Posted: Fri Jan 26, 2018 9:44 pm Post subject: Re: New German Brake Booster |
Hoody Samba Member
Posted: Thu Feb 22, 2018 9:06 am Post subject: Re: New German Brake Booster |
I know where there is a NOS German ATE 73 on booster for sale if anyone is still looking for one. |
obx71super Samba Member
Joined: December 16, 2012 Posts: 340 Location: Outer Banks NC
Posted: Thu Mar 22, 2018 12:42 pm Post subject: Re: New German Brake Booster |
Just got the Ate one in the mail from cip1 and it is infact the real deal! Nice of someone to start remaking quality parts instead of discontinuing them for a change!!! Nice work Ate!! _________________ 71 super auto stick basically original minus a couple resprays
73 Westy automatic with a 2 liter gex, soon to be a 1.8 liter Headflow masters
Newest Addition!! Solid straight 74 thing totally disassembled!! YEEEWWWW |
Posted: Thu Mar 22, 2018 12:44 pm Post subject: Re: New German Brake Booster |
Jivermo Samba Member
Posted: Wed Apr 04, 2018 4:55 pm Post subject: Re: New German Brake Booster |
Did the ATE (CIP1)bolt right in, without welding or drilling, and how is the brake pedal? The WW unit seems to throw people through the windshield. |
rusty busty Samba Member
Joined: May 27, 2015 Posts: 310 Location: Vancouver BC
Posted: Wed Apr 04, 2018 5:11 pm Post subject: Re: New German Brake Booster |
Yes it bolted right on and is a direct replacement. The pedal seems fine. Haven't gone through the windshield yet.
_________________ 1978 CEII Get-away hightop |
Hoody Samba Member
Posted: Wed Apr 04, 2018 8:43 pm Post subject: Re: New German Brake Booster |
Where are the new ATE ones made? |
Posted: Thu Apr 12, 2018 6:42 pm Post subject: Re: New German Brake Booster |
I think it was either Germany or Denmark. I remember the booster and the MC were both made in different European countries. _________________ 1978 CEII Get-away hightop |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Thu Apr 12, 2018 10:55 pm Post subject: Re: New German Brake Booster |
Hoody wrote: |
The one I have sez "Made in the Czech Republic". _________________ '67 bug: seized by the authorities
Posted: Fri Apr 13, 2018 12:12 am Post subject: Re: New German Brake Booster |
kreemoweet wrote: |
Hoody wrote: |
The one I have sez "Made in the Czech Republic". |
Actually that sounds a bit familiar now. I'll change my answer to I don't remember. There was so many new parts all at once it's a bit of a blur now. _________________ 1978 CEII Get-away hightop |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Fri Nov 09, 2018 12:16 am Post subject: Re: New German Brake Booster |
Ok....
Looking at this from Busdepot...
http://www.busdepot.com/j18100
The pic shows the vac hose fitting as 90 degree whereas mine (Ate) is straight on.
Does the actual item differ from the pic/s?
Left work to find the pedal somewhat (small travel) firm with very little to no braking assist. Glanced at my LM-2 and sure enough it goes lean (18++) when braking. I've checked the hoses underneath and the check valve (Mighty vac) all hold vac no leak/s. Master cylinder is not leaking (full) and was rebuilt ~15 years ago. Original Ate booster. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Fri Nov 09, 2018 5:51 am Post subject: Re: New German Brake Booster |
I'd go for the ATE booster at CIP linked n the first post. Seems to be back in stock, is $30 cheapness because of a sale, and is a direct bolt-on instead of the "redrilling" needed for the BD unit.
Plus, being on the west coast it's always taken over a week for orders from BD to get to me. |
Posted: Fri Nov 09, 2018 6:17 am Post subject: Re: New German Brake Booster |
tristessa wrote: |
Says 73-79...type O? Listed under 1972
Original German (quality or equivalent) ???
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-211-611-905 _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Fri Nov 09, 2018 7:24 am Post subject: Re: New German Brake Booster |
The ATE booster is a direct replacement (i.e. virtually identical) to 73-79 original units, but it will work fine on
71-72 bus, except the slightly larger size may require a tiny bit of clearancing on the axle beam flange
(I had to file one spot down about 1/16 or less), and the parking brake cable on 71 bus may rub slightly when
tightened (so don't go driving around with the P.B. on, I guess). Also, the makeup air connection
on the front of the ATE booster is slightly smaller than on the 71-72 version, but can easily be sleeved
with a short length of viny tubing or whatever if you wish to use the original hose.
The cheaper one from CIP1 is chinese, sometimes branded "AirTec", and seems to be identical to the
one sold by Wolfsburg West. Some have reported using those with no problems, others not so much. _________________ '67 bug: seized by the authorities
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1882 Location: N.W. Georgia
Posted: Sun Nov 11, 2018 9:26 am Post subject: Re: New German Brake Booster |
I used an AirTech booster on my rig and have had no issues. I buy them locally and pay $150 outright and the ones I have bought bolt right up. I received 2 last week.
I don’t take the time to source German or NOS parts for client’s buses I repair in my shop. If they bring specific parts of higher quality and price for me to install I will. Most of my customers don’t daily drive so as long as the repair is solid and functional they are good with the parts and service I provide. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun Nov 11, 2018 10:43 am Post subject: Re: New German Brake Booster |
I put an Airtec booster on my bus a little over a year ago, I drive my bus quite a bit and the booster is still functioning well. However, the boot on it has already deteriorated. Kind of like all boots seem to nowadays. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Wed Nov 14, 2018 2:42 pm Post subject: Re: New German Brake Booster |
rusty busty wrote: |
Got mine (German ATE booster) the other day. Curious did you need to remove the washer under the nub on the end of the pump rod? I rebuilt the MC ~ 12-15 years ago and it's fine (not leaking). But can't remember if there is enough movement once unhooked from the booster to get the vac booster out. I'd like to avoid having to bleed the system. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Wed Nov 14, 2018 6:25 pm Post subject: Re: New German Brake Booster |
udidwht wrote: |
Got mine (German ATE booster) the other day. Curious did you need to remove the washer under the nub on the end of the pump rod? I rebuilt the MC ~ 12-15 years ago and it's fine (not leaking). But can't remember if there is enough movement once unhooked from the booster to get the vac booster out. I'd like to avoid having to bleed the system. |
I just installed one of those recently ( https://www.thesamba.com/vw/forum/viewtopic.php?t=704213&highlight= ), and there was no washer under the pushrod tip, but unfortunately
the pushrod was too long.
If anyone has any movement at all in the m/c, they are using brake lines that are VERY different from mine. Maybe 1/2" of stiff springy action. Seems to be a severe risk of kinking the hardlines if you try to
do it with them still attached to m/c. _________________ '67 bug: seized by the authorities
Posted: Thu Nov 15, 2018 5:53 am Post subject: Re: New German Brake Booster |
I have almost always gotten a booster in w/o opening fluid lines. I loosen the casting for the rear compensator from the frame since it’ll allow the master some upward/rearward movement. Be careful of that fragile plastic under the boot as you move it through the mounting bracket. _________________ I Corinthians 4: 1 thru 5
