dennis 356 Samba Member
Joined: January 09, 2009 Posts: 100 Location: Malmö, Sweden
Posted: Tue Jan 23, 2018 4:54 am Post subject: Excessive wear on oil pump gear ends, what to do? |
Discovered a pretty excessive wear on oil pump gear ends where they slot in the cam gear grooves on three of my engines, is this normal wear or is there any other reason for that?
Except of changing them out for new ones, can new material be welded on and grinded to original shape again, will that be durable?
What would be the prefered welding option in order to ensure durability, MIG, classic gas weld or others?
Dennis
Posted: Fri Feb 02, 2018 4:33 am Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
Nada ??? No one knows ???
szorti Samba Member
Posted: Fri Feb 02, 2018 7:59 am Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
With oil pump gear wear in our engine, my mechanics checked camshaft and found excessive wear on it as well: https://photos.app.goo.gl/kmuq9akPHIZMdUXs1
We just bought new oil gears and gave the camshaft to people who know how to weld and grind things like camshafts and heads.
There is quite big free play between oil gear seat in camshaft and oil gear (like from stock) and I think this may be the reason of excessive wear of those. _________________ 1974 Bug - RIP
1967 Bug
1980 BMW R45 |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sun Feb 04, 2018 7:21 am Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
if you're gonna try this yourself best bet is to tig it...walt from competition engineering 760 379 3879 in california fixes these....got this info from another site, so i have never used them for anything so this is not a recomendation and i have no idea of the price...here on the vw side new pumps are so cheap this is a non issue... |
Posted: Thu Feb 08, 2018 9:46 am Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
Thanks for replying guys, but new oil pump gears are so expensive I rather want to avoid that expence, and especially if there exists some kind of remedy for this. The wear is serious, sure, but again so small on both sides it has to be possible to fix instead of spending maybe $300-$400 plus overseas shipping for a new gear, that in my opinion is madness.
And I also have three of them (three engines) !!!
Dennis |
alanhall Samba Member
Joined: February 18, 2006 Posts: 115 Location: Northern California
Posted: Thu Feb 08, 2018 4:22 pm Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
I think there is an item called an Oldham coupling which can be used here, one of the parts places in the U.K. sells them as I recall. https://prs356.co.uk/porsche-parts/all/1/oldham-coupling |
Posted: Fri Feb 09, 2018 1:31 am Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
Great tips alanhall thanks, but geee, the price again for that little gizmo is a killer !!!
Anyhow, better than $300-400.....
Dennis |
Posted: Fri Feb 09, 2018 1:39 am Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
Did no one really ever attempt welding on the oil pump gear end?
Dennis |
Posted: Fri Feb 09, 2018 4:36 am Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
szorti wrote: |
There is quite big free play between oil gear seat in camshaft and oil gear (like from stock) and I think this may be the reason of excessive wear of those. |
Ops, just noticed the same kind of wear on all three of my camshafts, thanks so much for the heads up. Did check the cam slots earlier after spotting the wear on the oil pump gears, but guess never beeing aware of this issue before, I was too inattentive and just plainly missed it with my untrained eye.
Dennis |
Posted: Fri Feb 09, 2018 6:30 am Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
I´m of course mostly interested of whether this "bush repair" by welding on extra material on the oil pump gear and than grinding it down, has the potential to hold over a foreseable time period or if its totally nuts and meaningless?
Appreciate of course all the other suggestions and options, but ay, so costly.....
Dennis
Posted: Fri Feb 09, 2018 6:36 am Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
volksworld wrote: |
Thanks for the heads up volksworld, but I´m on the other side of the pond, in Europe, thus best bet for me would be to leave it to someone locally.
Nice to know though there might be an option of fixing this by welding. |
roy mawbey Samba Member
Joined: May 21, 2012 Posts: 397 Location: Sussex England
Danwvw Samba Member
Posted: Sat Feb 10, 2018 12:51 pm Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
I would leave it alone until a full rebuild with a new cam and new tang gear drive etc..
Stop running that 20W50! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Mon Feb 12, 2018 9:18 am Post subject: Re: Excessive wear on oil pump gear ends, what to do? |
[quote="Danwvw"]I would leave it alone until a full rebuild with a new cam and new tang gear drive etc..
Stop running that 20W50![/quote
This is a full rebuilt and the cams are still good, except these tiny irritating hickups on them....
I never run these engines, someone else did a long, long time ago before I bought them a couple of years ago..... |
