chrisklinger Samba Member
Posted: Tue Oct 25, 2022 2:36 pm Post subject: Spring Plate Angle |
Hi guys,
I'm replacing (finally) the spring plate/torsion bar bushings.
I'm wondering, however...
The workshop manual gives me the angle, but my right side is sagging about 4cm more than the left.
If I just follow the manual, i should theoretically be good, as spring steel - supposedly - as long as never reaching an excessive load, will remain as original (Shigley et al., 2003
Reference: https://www.physicsforums.com/threads/what-causes-springs-to-wear-out.519055/ )
Yay science. But, it wasn't sagging before.
Of course, it could be just the bushings LOL
Do I set it to factory spec, and hope for the best?
Should I add an extra degree down on the right, and go by trial-and-error?
Should I search for new torsion bars?
Should I give up on my beloved VWs and get a modern car? (Yeah... no. Not a real consideration)
Any opinions appreciated
TIA,
Chris |
slayer61 Samba Member
Posted: Tue Oct 25, 2022 2:45 pm Post subject: Re: Spring Plate Angle |
IF it was me, I would get the car up on jack stands & level, drop the spring plates off the bottom stop and get out the protractor before you remove them entirely. If there is a difference between them you will see it on the protractor. Adjust accordingly. _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Tue Oct 25, 2022 3:50 pm Post subject: Re: Spring Plate Angle |
I'm a little confused....you say "it wasn't sagging before".....before what? Have you already installed the new bushings and set the angle at stock, but one side is lower than the other? _________________ '65 Sunroof Bug |
Posted: Tue Oct 25, 2022 4:19 pm Post subject: Re: Spring Plate Angle |
Before, as in, I bought the car on 1987. Sagging only started in the last couple of years, and I haven't had the spring plate covers off. |
Posted: Tue Oct 25, 2022 4:25 pm Post subject: Re: Spring Plate Angle |
I'll measure the angles when I replace the bushings, before pulling the plate from the splines. But it hasn't been altered (I've had the car since 1987).
And I suspect that even a weak spring will return to its original, no-load position when unladen. But, I could be wrong.
I'm just trying to line my ducks up before attacking this.
I'm smart. Smart enough to know that I can't know everything
I appreciate the input; every bit is valuable |
Posted: Tue Oct 25, 2022 4:29 pm Post subject: Re: Spring Plate Angle |
chrisklinger wrote: |
Got it. If it were me, I would start by setting both sides at the stock angle and go from there. If one side is a little off after this, I would drive it for awhile (~500 miles) to see if it settles in. If not, adjust as needed. It usually does take a couple of tries to get it just right. _________________ '65 Sunroof Bug |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34018 Location: Conejo Valley, CA
Posted: Tue Oct 25, 2022 4:40 pm Post subject: Re: Spring Plate Angle |
Plan on 2-3 iterations before you get it right after settling the suspension by driving a mile or so. |
Posted: Tue Oct 25, 2022 4:42 pm Post subject: Re: Spring Plate Angle |
KTPhil wrote: |
I guess my 500 mile break in period recommendation was a little excessive! _________________ '65 Sunroof Bug |
Posted: Wed Oct 26, 2022 2:44 am Post subject: Re: Spring Plate Angle |
Thanks a million guys
I'm looking forward to slowly getting her perfect again. |
