anthracitedub Samba Member
Posted: Mon Feb 05, 2018 6:35 pm Post subject: Re: 62 Transaxle disassembly/inspection |
Alright, I have all the parts now.... I’ll start getting this put back together throughout the weeks to come.
Im gonna start with the main shaft assembly. I’ve alread discovered a small concern.
The slider hub I have is NOS, Brazil... it’s slightly different than the original.
My question is, which direction in the stack does the chamfer go? The cogs on the hub are dubbed over a little, one side a little more than the other. Does it really matter? The side with he most chamfer has a thin ring around the hub as well.
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Mon Feb 05, 2018 7:05 pm Post subject: Re: 62 Transaxle disassembly/inspection |
Line on the hub goes toward third, line on slider goes toward fourth. What no line on the slider??? The slider is back cut on all 4 sides so that part doesn't matter. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Mon Feb 05, 2018 7:33 pm Post subject: Re: 62 Transaxle disassembly/inspection |
Yeah, I was looking the slider over... it appears to be the same either way.
I pressed the pinion bearing off today... thanks for the heads up on changing it to the tapered bearing. The original bearing leaves a bit to be desired.
I should be able to get the M/S put together tomorrow with no problems, I’ve been reading a little about the pinion shaft... I’m going to have to make a tool for the round nut to get that thing tight and there are a few things I’m not clear on, but I’m sure they’ll clear up as I move forward. |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Mon Feb 05, 2018 9:18 pm Post subject: Re: 62 Transaxle disassembly/inspection |
From your last pic on page 2, it looks like you have an early narrow 4mm 3/4 fork. The pics at the beginning of page 3 looks like your slider is a late 002 one for a wide late 5mm 3/4 fork. |
Posted: Tue Feb 06, 2018 2:09 am Post subject: Re: 62 Transaxle disassembly/inspection |
Well, I hope I have the right stuff. I have a new fork too and while it looks just like the early fork, it fits the new slider perfectly.
I’ll reveiw what I have when I get things around to reassemble... thanks for the heads up. |
Posted: Tue Feb 06, 2018 2:35 am Post subject: Re: 62 Transaxle disassembly/inspection |
Ok, got pix of the new slider vs the old...
Here are the forks, old original worn out and used replacement.
Posted: Tue Feb 06, 2018 7:01 am Post subject: Re: 62 Transaxle disassembly/inspection |
The replacement slider is 4mm. It is an oe replacement that has deeper engagement teeth much like that of a 002, it is correct and a nice upgrade. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Tue Feb 06, 2018 7:34 am Post subject: Re: 62 Transaxle disassembly/inspection |
Thank you sir, your knowledge is very appreciated.
I thought I was taking a step back there for a short moment. |
Posted: Fri Feb 09, 2018 11:19 am Post subject: Re: 62 Transaxle disassembly/inspection |
Alright, I’m checking out the assembly of the pinion shaft... I’m at a bit of a hang up because the elusive 1st gear synchro I have just doesn’t seem to have much life left in it.
I bought, what I thought was a decent used one ... I can measure about .030 on it. I don’t think I should use it, so I’m held up on that until I get a new one.
I’m having a hard time holding it flat to get a precise measurment, .030 was the average... I even check the ring to make sure it’s flat.
The other things I’m struggling with is getting the round nut tight.
I made a tool to be able to put a wrench on, but holding the other end is tough.
I clamped it with some thick rubber to protect it and got it real tight, but not where it needs to be. Does anyone have a home remedy for doing this?
I’m welcoming some advice/tips on this part, I’ve got a few other things I can do while trying to get a 247a synchro and put my rails/detents together.
The other area I’m concerned with is pressing the 4th gear on and getting the proper tension on the concave washer.
I changed the pinion bearing to the double taper and now I’m thinking that using the original shim set up won’t be spec.
I’ve read over the procedure in Bentley and have a vague understanding.
But with out the special tooling, I’m a bit unsure of a good at home procedure to continue on with.
Can I just press this gear on until it seats and check how things move and check for endplay/backlash... I just need tips on what to look for. |
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Fri Feb 09, 2018 2:52 pm Post subject: Re: 62 Transaxle disassembly/inspection |
The Bentley sets the diff using measurements and math, the alternative is setting it with "grease" and looking at the pattern. I like to do both, set close with the book tooling and then double check and fine tune with the grease.
Start with the pinion shims you have, most of the variance comes from the gear set and not the case and bearing. If all the variance came from the case fork jigs would have to be set to the case depth.
On tighteneing the nut, most use an old 1-2 clutch hub or third gear to hold the shaft. You can make a home made tool, or grind a flat and hold the gear in a vise, or hold the clutch hub in a vise.
On 091's a beetle splined fourth works, so if you are going to get into it a bit that something to keep in the back of your mind.
I'd have to check notes as I don;t really do early boxes on setting the shims for the pinion shaft spacer. Weddle sells a HD one that doesn't need shimmed, I think I've used that once before. I've read one guy that does away with the shims and just puts two compression washers there. Also something sticks in my head about someone machining the ID on the compression washer for the end of the mainshaft for this location. I can't remember why they were doing that, maybe a gear conversion?
Shoptalkforums had a topic Bruce started about springs vs spacers on teh pinion shafts, be a good topic to search out on there for reading.
If you'll pay for shipping I have a 1-2 clutch hub with a burned face, perfect for turning into a pinion shaft tool. You might be able to make a similar tool to hook the splines of the pinion shaft yourself to hold it still though. |
Posted: Fri Feb 09, 2018 3:17 pm Post subject: Re: 62 Transaxle disassembly/inspection |
https://www.thesamba.com/vw/gallery/pix/1643553.jpg _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Sun Feb 11, 2018 6:40 pm Post subject: Re: 62 Transaxle disassembly/inspection |
While waiting for the last few parts, I decided to get things around and go over small details.
I found reverse shift rail was a little bent, a bent stud for the nose cone and some rust on the pinion needle bearings.
Here is the aluminum bus nose cone that I got because this trans is going in a 57... only a few more details before the build starts.
I also started cutting an old case to use as a jig for setting shift forks. It will also be used for starting some of my 40hp builds.
Posted: Mon Feb 12, 2018 3:37 pm Post subject: Re: 62 Transaxle disassembly/inspection |
You have a package coming. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Tue Feb 13, 2018 8:01 am Post subject: Re: 62 Transaxle disassembly/inspection |
Awesome! Thanks. I’ll be moving along on assembly this weekend.
I’m sure a few questions will arise😐 |
rodeking Samba Member
Joined: October 09, 2017 Posts: 369 Location: near Buffalo NY
Posted: Tue Feb 13, 2018 1:57 pm Post subject: Re: 62 Transaxle disassembly/inspection |
Great thread. I will be doing mine eventually on my pickup after I get the engine done. Today I'm cleaning up the engine bay and bell housing and I wiggle the input shaft and it has a good 1/4" up and down play at the end. |
Posted: Tue Feb 13, 2018 2:50 pm Post subject: Re: 62 Transaxle disassembly/inspection |
rodeking wrote: |
That is normal. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Tue Feb 13, 2018 6:11 pm Post subject: Re: 62 Transaxle disassembly/inspection |
Yes, the end of the input shaft actually gains support by the gland nut on your engines flywheel/crankshaft assembly. |
Posted: Tue Feb 13, 2018 9:51 pm Post subject: Re: 62 Transaxle disassembly/inspection |
OK, I see it now, that input shaft is splined to the main shaft, that explains it. Carry on.. |
Posted: Sat Feb 17, 2018 8:36 am Post subject: Re: 62 Transaxle disassembly/inspection |
Many thanks to Scott for helping me out with the last of the few parts I needed to get assembly on the way...one of which being the elusive 247a synchro.
No need to check the specs on this... clear to be seen that it is well within spec.
I have to swing by work to use the press to put the pinion assembly together.
Kinda th last place I want to be on my day off, but I was unable to press 4th gear on with my small press at home.
I was amazed at how easy everything came apart, just using an arbor press and an assortment of steel plate/tubing to support everything... still wish I had the VW 401 plate.
Should be some better updates in the days to come. |
Posted: Sat Feb 17, 2018 8:47 am Post subject: Re: 62 Transaxle disassembly/inspection |
You can also heat parts to assemble, much like the crank gears in an engine. Glad you got the package! _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
