Engine cleaner?
dennis 356
dennis 356 is offline
PostPosted: Sat Jan 27, 2018 9:31 am    Post subject: Engine cleaner? Reply with quote
What would be the consensus on prefered engine cleaner? I normally resort to either kerosene or diesel but this 60 year old goo is tough to get rid off.
Don´t have access to pro motor bath. Never tried steam though, is it effective enough to invest in some kind of a steaming gadget for amateur use?
Dennis
captcory
captcory is offline
PostPosted: Sun Jan 28, 2018 8:32 am    Post subject: Re: Engine cleaner? Reply with quote
I just used brake cleaner and a wire brush to clean the goo, then soda blasted the case. Don't forget to pull the oil galley plugs and clean the oil passages too.
see: https://www.thesamba.com/vw/forum/viewtopic.php?t=546621&highlight=
Cory Cotherman
dennis 356
PostPosted: Mon Jan 29, 2018 12:43 pm    Post subject: Re: Engine cleaner? Reply with quote
I have a big spray can of "regular brake cleaner" but it´s not much effective, dries too quickly as well.
Seems like both the kerosene and diesel are more effective cleaners than that.
Dennis
Jonathan Thomas
Jonathan Thomas is offline
PostPosted: Mon Jun 04, 2018 8:15 am    Post subject: Re: Engine cleaner? Reply with quote
I used kerosene and then 3 different kinds of “wire brushes”. Wiped it off, sprayed it with WD40 and polished it a microfiber rag. Looks like new. Well, almost.
RolandD
RolandD is offline
PostPosted: Tue Jun 05, 2018 7:26 pm    Post subject: Re: Engine cleaner? Reply with quote
Wurth makes a good engine cleaner in a spray can. Not a miracle worker, but does work on softened dirt. It might help to pre soak with a solvent.
Crazy Roland
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Thu Jun 07, 2018 8:58 am    Post subject: Re: Engine cleaner? Reply with quote
Kerosene and diesel are rather dangerous both from sparks, odor and your skin absorbs. Varsol is a preferred cleaning solvent. Before removing from vehicle - visit a wand DIY car wash, spray engine with engine degreaser, and then spray with the wand's high pressure water.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
356pre-a
356pre-a is offline
PostPosted: Thu Jun 07, 2018 9:23 am    Post subject: Re: Engine cleaner? Reply with quote
I highly doubt they still have engine degreasers at the car wash in Sweden. I believe those have been outlawed for at least 20 years out of environmental concerns.
Wolfgangdieter
PostPosted: Thu Jun 07, 2018 10:29 am    Post subject: Re: Engine cleaner? Reply with quote
Buy the engine degreaser at a local auto store. There are petroleum and environmentally friendly ones available. GUNK is the most familiar one. Even Simple Green/Purple Power will dissolve some grease aided by the high pressure wand.
Starbucket
Starbucket is offline
PostPosted: Thu Jun 07, 2018 2:39 pm    Post subject: Re: Engine cleaner? Reply with quote
Are you cleaning a case that you are rebuilding or just cleaning the motor in the car? A 50-50 mix of auto trans fluid and acetone will dissolve all greasy gunk and loosen any frozen nut. Brush or spray on gunk, let sit 15 min.s and scrape/wire brush off gunk.
wheel607
wheel607 is offline
PostPosted: Fri Jul 06, 2018 1:09 pm    Post subject: Re: Engine cleaner? Reply with quote
Used gunk for years....formula changed but still works good
dennis 356
PostPosted: Thu Oct 25, 2018 8:44 am    Post subject: Re: Engine cleaner? Reply with quote
Guys, don´t know how it works in the rest of the world, but most of the engine degreasers, brake cleaners etc here in Sweden are completely worthless, instead it seems like being completely freed from all the effective substances as it once was, although still costing the same horrendous money and I just can´t get it what an idiot, state or organisation came up with this completely stupid idea, as now people are still polluting, if not more as the stuff doesn´t work so they are using yet more of it hopping it will, except for no purpose at all !!!
And yepp, no engine degreasers at the car wash in Sweden as 356 pre-A stated....
Anyone have experiance with steam?
Dennis
dennis 356
PostPosted: Thu Oct 25, 2018 8:47 am    Post subject: Re: Engine cleaner? Reply with quote
Starbucket, I´m going to try your formula soon, thanks.....
Dennis
Starbucket
PostPosted: Thu Oct 25, 2018 10:34 am    Post subject: Re: Engine cleaner? Reply with quote
Steam works really well but remember to coat all steel fasteners with a light film of oil (WD40 repels water) to prevent rust.
donco735
donco735 is offline
PostPosted: Thu Dec 13, 2018 2:15 pm    Post subject: Re: Engine cleaner? Reply with quote
CRC Pro-Duty degreaser works really well for cleaning, rinses with tap water and leaves no residue and has no lingering odor:
Starbucket
PostPosted: Thu Dec 13, 2018 2:27 pm    Post subject: Re: Engine cleaner? Reply with quote
If you have "Simple Green" soak it in that undeluted, it takes a while but also works well.
