ourv12 Samba Member
Joined: November 30, 2006 Posts: 492 Location: Great SouthWest Michigan
Posted: Sat Jan 27, 2018 6:29 pm Post subject: Are new Syncro fuel tank sender units factory calibrated? |
Im replacing my Syncro fuel sending unit and was wondering if they are factory calibrated ? I dont want to run out of fuel when the gauge reads at the beginning of the red which is "reserve". If its calibrated correctly shouldnt there be 2 or 3 gals reserve? |
vanagonjon Samba Member
Posted: Sun Jan 28, 2018 5:19 am Post subject: Re: Are new Syncro fuel tank sender units factory calibrated? |
I don't think they need or can be calibrated. After install ad fuel one gallon at a time and see where the gauge reads each time. That should do it. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6798 Location: Fort Lauderdale, Fl.
Posted: Sun Jan 28, 2018 7:51 am Post subject: Re: Are new Syncro fuel tank sender units factory calibrated? |
vanagonjon wrote: |
Of course you need to run out of gas at a gas station...which I'm planning...sigh! _________________ This free advice is worth exactly what you paid for it.
Jon_slider Samba Member
Posted: Sun Jan 28, 2018 10:54 am Post subject: Re: Are new Syncro fuel tank sender units factory calibrated? |
ourv12 wrote: |
should is a troublesome word
I suggest you fill a 5 gallon spare gas can and carry it in the van until it runs out of gas, and learn what your gauge does.
Why do you think you need a new fuel sender?
fwiw, some fuel gauges are not accurate due to problems with the blue foil in the instrument cluster.
If you are replacing your fuel sender because your gauge does not read correctly, make sure you do a proper diagnosis of your instrument cluster first. Proper diagnosis as in, swap in a working instrument cluster and see if the gas and temperature gauges still read the same levels they do with your cluster.
It could also be the gauge itself, but the most overlooked, and last detected issue is the blue foil develops a failure that is intermittent, erratic, and inconsistent. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3039 Location: Vancouver Island, B.C.
Posted: Sun Jan 28, 2018 12:13 pm Post subject: Re: Are new Syncro fuel tank sender units factory calibrated? |
When the sender is out of the tank it can be fine tuned by lightly bending the stop tab and the rod that holds the float.
You can hook up a jumper wire and watch the gauge move as you do this to set the max empty and full settings.
I literally did this yesterday. _________________ 89 Syncro GL Westfalia 2.1 WBX/WBXaustSS
My Westy Movies:
photogdave On Vimeo
photogdave On YouTube
