Posted: Sun Jan 28, 2018 11:01 am Post subject: T3 Technique News |
Welp, since it's now okay to do this now, I figured I would use the opportunity to introduce you to a few new products that we have on the shelves.
First up are the Syncro speedo drive gears. These are made of aluminum bronze to be both durable and friendly to the worm gear that drives it. Unlike the stock plastic and cheap 3D printed parts, these gears will probably outlast the vehicle.
Next up are a set of Projektzwo style fog lamps. These come in clear and yellow. The lamps are a true fog lamp and while they are probably not as refined as the original Hella lamps, they do produce a nice pattern with plenty of light. They use a standard H3 55 watt bulb.
And lastly, for today, we have a set of rear tail lamp "blenders". These are replicas of the original VW parts that were offered on the later model, higher-end vans. These blenders are made from OE-textured ABS and are really easy to install. The make really clean up the rear of the van between the tail lamps.
Here is a link to all of those products and more.
http://www.t3technique.com/new-stuff/
Thank you for taking a look! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Zeitgeist 13 Samba Member
Posted: Sun Jan 28, 2018 11:30 am Post subject: Re: T3 Technique News |
Cool stuff!
What's the latest intell on the rear sway bar development? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Sun Jan 28, 2018 12:00 pm Post subject: Re: T3 Technique News |
Nice! Those lights really look great on the Vanagon. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4097 Location: East Kootenay, British Columbia
Posted: Sun Jan 28, 2018 12:08 pm Post subject: Re: T3 Technique News |
Any replacement bulbs available for the lights?
edit: I should have asked, are replacement lenses available?
I have the original Projektzwo lights and would like a spare set of lenses.
Even better would be LED! The halogen bulbs get pretty hot. _________________ Currently:
Defend democracy, support Ukraine.
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sun Jan 28, 2018 12:11 pm Post subject: Re: T3 Technique News |
Whew...I thought you had sold the business too!
Great to see those yellow fogs...right after I did mine using old vintage CIBIE "Airport" fogs from the '80s. They fit like they were made for the Projektzwo!
Yours are using the H3 bulb where these are using an H2 bulb. Yours will much easier to get spares for I think.
_________________ This free advice is worth exactly what you paid for it.
Posted: Sun Jan 28, 2018 12:17 pm Post subject: Re: T3 Technique News |
I think the best new product you have are the Triple Nozzle Washers for the windshield.
I have them on mine and they are a great improvement,
Your price is great too for them!
http://t3technique.com/new-stuff/triple-nozzle-windshield-squirters/ _________________ This free advice is worth exactly what you paid for it.
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Sun Jan 28, 2018 12:47 pm Post subject: Re: T3 Technique News |
Speedo gears! Excellent!! Do you recall which color/number is for the 4.86 R&P? Does the R&P gearing even matter??
I purchased a front locker imported from Sweden years back and had the original R&P (5.43 to the best of my memory) replaced with a 4.86 R&P by GTA. I'm currently using the light brown speedo gear it came with (094409181J 8/18 Beige/Brown (color of wood) to the best of my recollection) and it causes my speedometer to show 20% slower than I'm actually going. So, my question is what # teeth is the brown and what color do I need now to show the real speed with my 4.86R&P?
Pulling from another thread by derekdrew......
The map to the available gears as far as I am aware is this:
094409181B 8/19 WHITE (standard for all North America, all of which were 4.86)
094409181C 8/20 BLACK
094409181D 8/21 RED (standard for all South Africa, all of which were 5.43) ALSO MAY BE GREY???
094409181E 9/20
094409181F 9/21 GREY (medium to light grey)
094409181G 9/22
094409181H 7/19 Dark BROWN
094409181J 8/18 Beige/Brown (color of wood) _________________ '90 Syncro Westy w/GW2.5L
Jon_slider Samba Member
Posted: Sun Jan 28, 2018 12:52 pm Post subject: Re: T3 Technique News |
Christopher Schimke wrote: |
They use a standard H3 55 watt bulb. |
Outstanding option for a Real Fog light, that uses widely available lamps
I especially like the clear lens option that can optionally be paired with a yellow lamp, or a clear lamp
https://www.amazon.com/HELLA-HLA-H83135061-12V-Yellow-Star/dp/B000COBLG6
for people that want a yellow beam, without having to add a yellow lens to the color combinations on the van..
Fwiw, I have clear lens fogs on my Subaru, I swapped from clear bulbs to selective yellow lamps. The brightness dropped by 20%, but I like the yellow option, without having to use a yellow lens. One of each pictured below, note also that when off the lens does not look yellow (which I did not want on a white car)
_________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Merian Samba Member
Posted: Sun Jan 28, 2018 1:53 pm Post subject: Re: T3 Technique News |
how about making rear tail lamp "blenders" with god LED backup lamps in them?
_________________ .... |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
E1 Samba Member
Joined: January 21, 2013 Posts: 6563 Location: Westfalia, Earth
Posted: Sun Jan 28, 2018 2:58 pm Post subject: Re: T3 Technique News |
Syncronoid wrote: |
Does the R&P gearing even matter?? |
Yes.
I realize you have a 4.86 now, but… our speedometer and odometer read about 10% high when all was stock, which is pretty standard for gauges to read.
When we went from 14" to 16" wheels, our tire diameter grew by about 6%, so now we were covering more ground despite the gauge speed. But we also went from a 4.86 to a 5.43 Ring and Pinion, so…
Now when I pass a speed checker on the road, our speedometer matches the quoted speed almost dead-on — though it now errs on the side of reading a bit low if anything.
Chris: I see you list speedo gears as for Syncro, do they work on a 2WD? _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sun Jan 28, 2018 3:06 pm Post subject: Re: T3 Technique News |
Zeitgeist 13 wrote: |
What's the latest intell on the rear sway bar development? |
The basic design is finalized, but still needs a few refinements. I'm picking away at it slowly.
MsTaboo wrote: |
Even better would be LED! The halogen bulbs get pretty hot. |
I'm working on having some replacement lenses in stock, but none as of today.
Since they use a standard H3 bulb arrangement, it may be possible to change to and LED bulb. The only issue that I can see is that the entire system is really shallow and many LED bulbs protrude out the backside by more than the standard LED bulb does. But as long as there is enough clearance, then no problem.
Steve M. wrote: |
No sir! Thanks for the concern, but in fact, we are doing better than we ever have and still growing.
Yeah, those are a great upgrade too. The only complaint I have heard about their performance is that they put out so much volume of fluid that the reservoir empties sooner. But, that seems like a small price to pay to have a clear windscreen.
Thanks for pointing that out, Jon. That does look like a great option. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sun Jan 28, 2018 3:14 pm Post subject: Re: T3 Technique News |
Syncronoid wrote: |
094409181E 9/20
094409181G 9/22
094409181J 8/18 Beige/Brown (color of wood) |
Thank you for listing all of those options.
What matters is that the speedo drive gear matches the worm gear on the pinion. That worm gear is pressed on to the pinion so it's possible to switch those around, but you have to be sure that the worm gear and the speedo drive gear match. In other words, if you change to taller tires and now your speedometer is off, it's not as simple as changing just the speedo drive gear. You would have to change the speedo drive gear and the worm gear at the same time.
If the worm gear and speedo drive gear are mismatched, the speedo drive gear will get torn up eventually. If you pull out a white (8/19) speedo drive gear, you need to put the equivalent of a white (8/19) gear back in it. Unless, that is, you also change the worm gear to match.
Now, I am not a gearbox/differential expert so I am simply relaying things as I understand them. If someone has correct information that is contrary to what I stated above, please let me know so I can make the necessary corrections. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Posted: Sun Jan 28, 2018 4:32 pm Post subject: Re: T3 Technique News |
LOVE them, but I hate it when something comes out that's better than what I already have! LOL
Any new development on front brakes? It's still on my to do list, I still have OEM ones (in good shape)...
tam
Jon_slider wrote: |
_________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Sun Jan 28, 2018 6:36 pm Post subject: Re: T3 Technique News |
Excellent Chris to all this new stuff and the service to the vanagon community. |
Mike Robinson Samba Member
Joined: June 18, 2010 Posts: 386 Location: Nanaimo BC Canada
Posted: Sun Jan 28, 2018 7:04 pm Post subject: Re: T3 Technique News |
Just wondering when the front 2wd anti sway bar will be back in stock.
No hurry, probably an April thing.
Mike
82 Westy Diesel AAZ |
jimf909 Samba Member
Posted: Sun Jan 28, 2018 10:37 pm Post subject: Re: T3 Technique News |
I hope to be buying it quickly when it becomes available. I appreciate all that you're doing for these old vans. _________________ - Jim
Abscate wrote: |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Sun Jan 28, 2018 10:40 pm Post subject: Re: T3 Technique News |
Christopher, a rear sway bar would be so awesome...can’t wait.
I’m tempted on the tail light blenders! Ah screw it, I might as well order a set just because. |
Posted: Mon Jan 29, 2018 4:44 am Post subject: Re: T3 Technique News |
p.s. I like these vendor updates threads. They keep me up-to-date on the latest news from Vanagon vendors and support engagement with them as well. _________________ - Jim
Abscate wrote: |
SteveVanB Samba Member
Joined: June 01, 2008 Posts: 1645 Location: This side of Daytona
Posted: Mon Jan 29, 2018 6:50 am Post subject: Re: T3 Technique News |
Merian wrote: |
I bet one of them new fangled flush mount led cube lights would fit pretty well. Thats if theyre not to deep on the back side. _________________ 91 CARAT |
