Braukuche Samba Member
Posted: Mon Jan 29, 2018 3:08 pm Post subject: Source for 80mm barrel shims? |
I can find nearly every other size,but not these for my 36hp big bore kit. I know the 356 1500 barrels use these, but none of the Porsche parts places carry them that I have seen so far. Anyone know of a source? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Tue Jan 30, 2018 9:35 am Post subject: Re: Source for 80mm barrel shims? |
stoddard perhaps ? _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Tue Jan 30, 2018 1:49 pm Post subject: Re: Source for 80mm barrel shims? |
sgmalt46 wrote: |
stoddard perhaps ? |
Looks like they only sell them for the stock 1600 jugs.
NLA might have what I need, but it's not clear I need to call. Plus they are the copper shims not sure of that matters? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
J A Red Samba Member
Joined: July 12, 2008 Posts: 86 Location: Peachland, BC, Canada
Posted: Thu Feb 01, 2018 1:48 pm Post subject: Re: Source for 80mm barrel shims? |
I contacted Fat Performance and they can make them any size, but they are not cheap. was quoted $150 for a set. |
Posted: Thu Feb 01, 2018 3:19 pm Post subject: Re: Source for 80mm barrel shims? |
Reed Green wrote: |
Good grief, better make sure you measure twice!! _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sat Feb 03, 2018 1:09 pm Post subject: Re: Source for 80mm barrel shims? |
you can try rimco. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
Posted: Sat Feb 03, 2018 2:05 pm Post subject: Re: Source for 80mm barrel shims? |
Rimco is fat performance |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 726 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Fri Feb 09, 2018 8:30 pm Post subject: Re: Source for 80mm barrel shims? |
I've made up several sets of barrel spacers for those who are building their engine with a 69mm stroker crankshaft using the AA 80mm VW P/C's in their 36hp engine.
I don't remember what sizes I have left though. I have to check. This was the customers engine. Cheers! Mr. Okrasa
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat Feb 10, 2018 12:15 pm Post subject: Re: Source for 80mm barrel shims? |
You can have them waterjet or laser cut, I used to make them all the time when I ran the waterjet at the last job I had, If they were still open I would make a set for you cheap.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
HBH72 Samba Member
Posted: Sun Nov 04, 2018 1:43 am Post subject: Re: Source for 80mm barrel shims? |
Do anyone know the size/height of the cylinder shims (barrel spacers), that were included in the original Okrasa TSV-1300 kits, containing the 69,5 crankshaft..?
Is it fair to assume, that these old Okrasa kits were made, using the same TDC (TopDeadCenter) as the standard VW engine - which then require shims of 2,75 mm. (69,5 mm vs 64 mm crankshaft). |
anthracitedub Samba Member
Posted: Sun Nov 04, 2018 5:34 am Post subject: Re: Source for 80mm barrel shims? |
Might try a local machine shop... they’re easy to make... I made my last set for my stroked 40 out of aluminum. |
FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Mon Nov 05, 2018 2:07 pm Post subject: Re: Source for 80mm barrel shims? |
what are the ID and OD dimensions for the 80mm AA cylinder spacers? _________________ Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller |
