73 vw bus automatic
1971 viv
1971 viv is offline
PostPosted: Fri Oct 23, 2020 2:53 pm    Post subject: 73 vw bus automatic Reply with quote
Hi, so I found a 73 vw bus with an automatic. How rare are these? It does not have an engine or title, but I found a type 4 engine to go in it. If they are rare then I would like to scoop it up.
TheFonz
TheFonz is offline
PostPosted: Fri Oct 23, 2020 2:58 pm    Post subject: Re: 73 vw bus automatic Reply with quote
Rare- not really. Less common- yep.
-73' Westfalia
-76' Westfalia
-72' Westfalia (parts bus)
-76' Westfalia (project for my dad as a thanks)
http://www.thesamba.com/vw/forum/viewtopic.php?t=452223&highlight=
^Check out my restoration thread
orwell84
orwell84 is offline
PostPosted: Fri Oct 23, 2020 3:02 pm    Post subject: Re: 73 vw bus automatic Reply with quote
They are much less common but not rare. The automatic transmissions are quite sturdy and work quite well though much less refined than on modern cars. I like mine though I prefer standard in general. Mine is original to my bus and it works so I have stuck with it. Buy it if you want to drive an automatic bus.
germansupplyscott
germansupplyscott is offline
PostPosted: Fri Oct 23, 2020 3:38 pm    Post subject: Re: 73 vw bus automatic Reply with quote
Have to disagree a bit:
Buses before 1976 with automatic transmissions are quite rare. Very few sold, especially the ones with dual carbs - so that means '73-'74. ('74 Cali automatic got fuel injection).
SL
1971 viv
1971 viv is offline
PostPosted: Fri Oct 23, 2020 4:13 pm    Post subject: Re: 73 vw bus automatic Reply with quote
Well if it is not super duper rare, then i think i will pass. It has no engine or title, so it will be a lot of work.
alman72
alman72 is offline
PostPosted: Fri Oct 23, 2020 4:24 pm    Post subject: Re: 73 vw bus automatic Reply with quote
hows the body? a solid one is something you should think hard about passing up.
less work in metal repair is a HUGE plus
JimmieH Premium Member
JimmieH is offline
PostPosted: Fri Oct 23, 2020 5:55 pm    Post subject: Re: 73 vw bus automatic Reply with quote
X2. With buses these days value is all about rust. Or lack of.
1978 Transporter 2.0 FI, BA6
Special Thanks to Razor's Customs, Boscawen, NH
orwell84
orwell84 is offline
PostPosted: Fri Oct 23, 2020 6:46 pm    Post subject: Re: 73 vw bus automatic Reply with quote
Yes, I think rust is really the first consideration. I donít know how many of the early automatics were produced, but I never thought of them as rare enough to be sought after.
Wildthings
Wildthings is offline
PostPosted: Fri Oct 23, 2020 7:15 pm    Post subject: Re: 73 vw bus automatic Reply with quote
1973 is kind of the first year of the more modern buses. It has good crash protection and a hatch over the engine on top of the improvement introduced in the '72 model year. The auto is fine and nice to have if you are driving in city traffic a lot.
1971 viv
1971 viv is offline
PostPosted: Sat Oct 24, 2020 8:16 am    Post subject: Re: 73 vw bus automatic Reply with quote
The body does look good. But I think I need to finish my squareback first as I dont really have space for another project. Maybe if it is still available when Iím done I look more into it. Thanks for all the information about it.
