tencentlife Samba Member
Posted: Fri Feb 02, 2018 9:15 am Post subject: Re: Vanlife and Wet Suit Drying |
It'd be easy to attach two 12v computer fans to one of the louver's screen panels, or to another panel of ABS or something cut to the same size. You'd have nice crossflow ventilation for drying out your stuff or just keeping the interior cool. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Thu Feb 01, 2018 10:07 pm Post subject: Re: Vanlife and Wet Suit Drying |
Sheesh.. Thought I was more Macho, guess it turns out I get cold too quickly these days. Even in Cozumel in April or May I still pack my thermal undersuit and 3/2. So... IF I were VanLifing it there, I'd need to dry out 2 suits! Well... 3, as my Gal has a 3/2 as well, I suppose I'd ask her to come along.
I guess I would bend a stainless rod into a crime-scene guy outline. Pull the suit(s) over your guy-shape wire and zip it up. Use the top rack bars and some gun-lock cables (can easily find these for free) to secure them at each end. You'd still have to find a way to keep them from sun damage, I guess a taller wire shape to pull a tent fly over? I am a big fan of fiberglass tent poles. Make a dome out of an old tent fly, cut the dome up just corner to corner of your top rack so there's an air gap.
Love the idea of the 12V fans. Sounds like you'd mostly have sun? There are a bunch of inexpensive mini-solar panels out there, thin, easy to toss/stow. 12V out the door jamb from the dash plug would work too. I'd make a fitting for the fan/input at the neck, and plug the hands/feet a bit so its balloons up. A properly sized hole at each exit would let air flow through.
Mostly the problem I'd have would be the water on the roof, especially if you hadn't had a ton of time to rinse the salt off well enough EVERY time. I find hanging a suit to drip dry is a must. At least for a while. Maybe adapt the top rack idea to a vertical one behind the driver door? Make a stainless wire loop on the outside of your ARGs and find a secure spot to zip the gun-lock around down by the LP tank? Door handle should work for one arm's gun-lock. Sun damage minimization would be easier on this, as you'd just park with the slider to the south. In this scenario, I'd want to have my crime-scene guy bowed outward so it would stay off the van. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Thu Feb 01, 2018 6:47 pm Post subject: Re: Vanlife and Wet Suit Drying |
We don't need no stinking wet suits...
When I went for a dip in Carlsbad, someone called the cops on me reporting a suicide attempt - the cops were real nice, and one said "You're from back east , aren't you?"
_________________ .ssS! |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Thu Feb 01, 2018 5:46 pm Post subject: Re: Vanlife and Wet Suit Drying |
Any excuse to buy those Vanistan louvers...they rock! |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Thu Feb 01, 2018 5:24 pm Post subject: Re: Vanlife and Wet Suit Drying |
That's a pretty good idea. And cheap, all things considered. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
zuma Samba Member
Posted: Wed Jan 31, 2018 11:51 pm Post subject: Re: Vanlife and Wet Suit Drying |
Hang it out a south/west facing window at your 9-5. |
Aryana Samba Member
kaalualu Samba Member
Joined: June 09, 2011 Posts: 274 Location: Big Island, Hawaii
Posted: Wed Jan 31, 2018 10:59 am Post subject: Re: Vanlife and Wet Suit Drying |
Keep moving West, you won't need a wetsuit. Sorry, I couldn't resist.. _________________ '84 Transporter 16" CLK's/LED's/ AT's/Mansi injectors
'86 Wolfey Weekender Westfalia AT's/otherwise stock
Sold-'82 TinTop Diesel |
yiucycle Samba Member
Posted: Tue Jan 30, 2018 5:55 pm Post subject: Re: Vanlife and Wet Suit Drying |
I hang(strap it half way point, not on a wetsuit hanger) mine on my bike hitch rack all the time both on the van and my civic. Most ppl don't want to steal or touch damp clothes. I also drive around with it, usually if i get on the freeway, it will be mostly dry on the outside in 30-40min and i flip it inside out and dry that again. But other nice driver always honking at me and let me know i have a wetsuit on my bike rack.
If you have a westy or poptop you can also throw it up at the luggage rack but that is as long you remember to take it down before you drive off. _________________ 1980 2.8LV6 Fiero ASI/Riviera Vanagon
"there is no point in being embarrassed of all the stupid shit i done and will continue to do"
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Tue Jan 30, 2018 5:48 pm Post subject: Re: Vanlife and Wet Suit Drying |
The guy that actually started the #vanlife he surfed and he created a wetsuit drying closet in his van. You need to do some research and find out what he did. For full timers this would be good for towels and laundry. _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4791 Location: Bemidji, MN
Posted: Tue Jan 30, 2018 5:44 pm Post subject: Re: Vanlife and Wet Suit Drying |
i'll take a fading wetsuit over the smell of a continually damp one anyday! they gotta be hung up to dry!
-dan |
montanasurfer Samba Member
Joined: March 06, 2014 Posts: 319 Location: United States
Posted: Tue Jan 30, 2018 5:41 pm Post subject: Re: Vanlife and Wet Suit Drying |
VicVan wrote: |
You wouldn't want the wetsuit exposed to sunlight all day, it would get ruined pretty quickly. Neoprene does not like UV I believe. |
Yeah, I was thinking about that... Here's an idea, what if I get one of those marine powered solar fans and install that on the top of my swing away box I have on the back of the van with a dry rack to drape my suit on? I think we are on to something. That would incorporate the fan idea from earlier... Would seem like a wast of storage though.... |
Posted: Tue Jan 30, 2018 5:40 pm Post subject: Re: Vanlife and Wet Suit Drying |
VicVan wrote: |
VicVan Samba Member
Posted: Tue Jan 30, 2018 5:16 pm Post subject: Re: Vanlife and Wet Suit Drying |
You wouldn't want the wetsuit exposed to sunlight all day, it would get ruined pretty quickly. Neoprene does not like UV I believe. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Tue Jan 30, 2018 4:57 pm Post subject: Re: Vanlife and Wetsuit Drying |
DanHoug wrote: |
run a vinyl coated steel cable thru the arms and lock it to the grab handle inside, cables running out between the door and frame. old motorcycle trick to keep your riding jacket from walking.
people can still cut the suit off the cable, ruining it, just to be mean but there are destroyers everywhere.
-dan |
I like this idea. I think I might give it a go. |
Posted: Tue Jan 30, 2018 4:53 pm Post subject: Re: Vanlife and Wetsuit Drying |
djkeev wrote: |
Surfing in Montana?......
Dave |
I actually live in California now... It is an unorthadox handle . |
Finagon Samba Member
Joined: May 14, 2007 Posts: 53 Location: Portland, OR
Posted: Tue Jan 30, 2018 3:15 pm Post subject: Re: Vanlife and Wetsuit Drying |
If you have a decent, or even medium-sized rack on the roof, I could see some method by which you sandwich the wet suit between some heavy-ish gauge metal screen. Locking said screen to the rack?
Assuming it's a dry or cloudless day, you'd probably have a black wetsuit dry within an hour or two. |
WestyWanter Samba Member
Joined: February 15, 2017 Posts: 459 Location: San Diego
Posted: Tue Jan 30, 2018 12:21 pm Post subject: Re: Vanlife and Wetsuit Drying |
if you have a gym membership can't you leave it in a locker there an have it dry? |
