Whaanga Samba Member
Joined: May 07, 2016 Posts: 630 Location: Rochester, NY
Posted: Wed Jan 31, 2018 11:47 am Post subject: Missing push rod retaining wire clips |
I just keep finding missing parts on my '73 bus.
It looks like the wire retaining clips in the valve compartments are AWOL.
Of course, I'll replace them but what sort of damage or problems can the absence of these parts cause?
Thanks,
Jeff
_________________ Late 1973 Bay w/a transplanted 914 Engine |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed Jan 31, 2018 12:11 pm Post subject: Re: Missing push rod retaining wire clips |
I believe the purpose of the wire is to prevent the pushrod tubes from migrating towards that valve cover. If they did you'd get an oil leak. If you don't have any leaks you're probably ok but I'd still try and find some wire clips. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Samba Member
Posted: Wed Jan 31, 2018 12:25 pm Post subject: Re: Missing push rod retaining wire clips |
what Gary said - they hold the pushrod tubes in place. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Jan 31, 2018 1:49 pm Post subject: Re: Missing push rod retaining wire clips |
Well, I do have a small leak on the 3/4 side eminating from the push rod tubes.
Time to find the missing parts and redo the push rod tube seals. _________________ Late 1973 Bay w/a transplanted 914 Engine |
NoBudgetVWGarage Samba Member
Joined: November 27, 2008 Posts: 755 Location: Quartz Hill,CA
Posted: Wed Jan 31, 2018 3:06 pm Post subject: Re: Missing push rod retaining wire clips |
Best to find the retainers, but you can used something like aviation permatex to glue the outer o-rings in place in the meantime. Note that the retainers do not go down inside the tubes, but push on the ends of the tubes. |
raygreenwood Samba Member
Posted: Wed Jan 31, 2018 10:25 pm Post subject: Re: Missing push rod retaining wire clips |
The type 4 puahrod tube is a "floating" joint. Note that the inner seal end is twice the width of the seal. This lets the inner seal slip back and forth as the engine...case, cylinders and heads....expand.
The outer end....the spring clips....keep the PR tubes in place. So the outer end technically stay fixed to the head under spring pressure while the inner end slips.
Ray |
