alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Thu Jul 26, 2018 1:19 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
daithi wrote: |
nilza wrote: |
Thanks again Alman,
That kind of feed back is what makes projects like this work for everyone.
I have changed the number 1 dimension to 9.4mm. I would still suggest to anyone to polish these surfaces just a bit to aid movement.
The thousand monkeys and I have been busy at the computer this week and I think I have the internal part nutted out. I have one on order to test, but if anyone is game to give it a try untested here it is at what it costs me.
https://www.shapeways.com/product/KUBMTGV2K/indicator-internal-72-74-vw-bus
Hi Nilza I need the black block the 7 wires attach to as mine melted a bit and isn't usable any more, any chance of you doing one of those? (I've the SWF HLS 69 but I think it's the same size if I've read what Alman said above right) |
Daithi-
in the above pic, on the left hand side that is not really shown (typical!) the spring has a little hole that it lives in. the copper barrel shoves the spring down, and slips halfway into the hole. If you don't believe me, take out the spring and observe how it fits oh-so perfectly.
as I have said, I nip a tiny bit off the spring, and put the cut end in the hole. the spring is so damn tight otherwise, and puts stress on the part that breaks. I still get great action on the switch.
I do have a spare of the part you need....
edit- I think the HLS 69 came in a 7 wire and a 5 wire. OR someone swapped housings years ago on my strange part. |
daithi Samba Member
Posted: Thu Jul 26, 2018 2:58 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
Many thanks for that information Alman, it did seem the obvious place for it but the spring really didn't want to share the space ! Now that I know it's definitely there I'll make it fit. If you'd be willing to let me have that spare part, and to post it to Ireland, I'd be happy to pay you for it. |
nilza Samba Member
Joined: May 21, 2007 Posts: 342 Location: brisbane australia
Posted: Sat Sep 01, 2018 2:25 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
daithi wrote: |
Hi Daithi, sorry for the late reply.
The base piece looks pretty simple to draw up. I will do it and add it to the parts on shapeways for you to try next time I get a chance.
The central part pictured above has had a bit of testing now and will need a few modifcations from my end. Mostly the printed plastic is not as stiff as the original and the indicator doesn't spring back as nice as it should, so will need to beef up the arms a little to work around that.
I believe there are 2 other people that bought one though shapeways that have not made contact with me. If they would like to make contact I will send them the updated one free of charge once I am happy for it to go out to testing again. _________________ still floating around the web somewhere |
daithi Samba Member
Posted: Mon Sep 17, 2018 2:24 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
Ah that'd be brilliant Nilza ! I've put the indicator back together in the meantime as the high beam will work. I look forward to taking it apart again, this time on a very clean bench that nothing can run off. I'd been unable to find this thread so I actually messaged you on shapeways a few days ago |
nilza Samba Member
Posted: Sat Oct 27, 2018 7:47 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
daithi wrote: |
Hey Daithi, I got a little time to draw this up while resting a busted ankle.
I have just loaded it to shapeways a cost until someone can confirm whether it is indeed correct.
https://www.shapeways.com/product/NYBBFBKE3/plastic-base-v1-1
As per usual the mating surfaces may need a little polishing up and some grease as the sintered parts are a little grainy. _________________ still floating around the web somewhere |
nilza Samba Member
Posted: Fri Nov 16, 2018 1:55 am Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
After a bit of testing and correcting the internal part is best I can tell finished.
The original material chosen has been replaced with a cheaper version due to the first version just not being necessary.
As always anybody taking the plunge finding anything wrong with the part, let me know and I will correct that and send you an updated replacement.
https://www.shapeways.com/product/KUBMTGV2K/indica...d=65605359 _________________ still floating around the web somewhere |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Mon Nov 19, 2018 4:12 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
Thanks for working this up! My turn signal just broke this morning. Now I only get Left turn; Right turn won't engage. Probably a broken piece of plastic blocking the action.
I have not had Cancel action ever, but managed just fine. Guess it's time to get into this! |
Posted: Mon Apr 29, 2019 1:06 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
Any updates on this repair and parts availability? |
Posted: Mon Apr 29, 2019 2:12 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
Wasted youth wrote: |
this guy just ordered some
https://www.thesamba.com/vw/forum/viewtopic.php?p=9055764&highlight=#9055764
just bend the tabs back to get access, and SLOWLY take apart so you can see whats what. it you get the SPROING! when you open it up, I can talk u thru it. I have a partial write up in the linked thread. very partial |
nilza Samba Member
SGKent Samba Member
Posted: Tue Sep 17, 2019 8:26 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
I wish someone could make viton or rubber parts that easy. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Sep 18, 2019 5:47 am Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
this is a great pic for those that have had the content spill all over the table/floor, HOWEVER, the bearing should be between the spring and the cylinder/roller
kaiisons Samba Member
Joined: January 07, 2012 Posts: 77 Location: Sydney, Australia
Posted: Wed Sep 18, 2019 3:30 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
alman72 wrote: |
How Nils has shown is correct. I've taken maybe 20 apart now, from completely trashed with barely anything being reusable to a pristine one that looked barely used. The ball bearing fits as shown as there is a little ramp on the inside on the center piece, used for the return on the high beam action.
The 72 model is slightly different where the brass contacts are and their associated spring. |
cheftaylor74 Samba Member
Joined: November 18, 2007 Posts: 45 Location: Encinitas, Ca
Posted: Wed Sep 18, 2019 4:42 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
If I order these parts and install them, is it a safe bet that my signal cancel will work? It worked when I first got the bus and stopped after I had to man handle the steering column to reattach the horn at the base. Would be super excited to get this working again. Any thoughts would be appreciated. _________________ 1974 Westfalia Camper
1959 Ragtop |
Posted: Wed Sep 18, 2019 4:55 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
cheftaylor74 wrote: |
If I order these parts and install them, is it a safe bet that my signal cancel will work? It worked when I first got the bus and stopped after I had to man handle the steering column to reattach the horn at the base. Would be super excited to get this working again. Any thoughts would be appreciated. |
if it is your unit, then yes. if it is your canceling ring, no.
you can take off the 2 screws (maybe 4?) on the signal/washer housing and test by hand. when you remove the screws on the metal housing, the 2 separate metal halves should come apart. then you activate the signal(bus can be off) and reach in and flick the return tab coming out of the signal housing. I believe it is opposite. if you flick the signal arm up, you would reach in and flick down. this should cancel and return the unit to the unsignaled position. it is also possible that old age has gummed up your unit, and just needs some white lithium grease to get the return tab working again. hope this makes sense. PM me and I can send u a vid if needed. there is one on here somewhere. I will look for it
edit-see below
Posted: Wed Sep 18, 2019 4:57 pm Post subject: Re: '72-74 Turn signal switch repair |
^ in regards to hand testing the cancel tab.
nilza Samba Member
Posted: Thu Sep 19, 2019 3:25 am Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
Thanks Alman.
Chef, I can't really give you a yes or no answer from your description, Best is to establish what the problem is and work from there.
Rest assured though if it is a broken plastic part, we have you covered. _________________ still floating around the web somewhere |
Posted: Thu Sep 19, 2019 10:38 am Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
Thanks nilza and alman72...
I'm going to take it all apart this weekend and do the flick test.
Curious though - how often does the metal ring fail on these? Is there a replacement made? I can't seem to find one. _________________ 1974 Westfalia Camper
1959 Ragtop |
Posted: Thu Sep 19, 2019 2:08 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
So I took it apart...surprisingly easy. I flicked it. Can’t get it to reset manually. The piece is all chewed up. Photos below.
The metal ring on the column looks great and doesn’t seem bent at all. So I guess I’m rebuilding the switch. Ordering parts tonight...thanks for this thread! Wasn’t sure how I’d ever have it fixed.
1959 Ragtop |
2dubs Samba Member
Posted: Sun Sep 22, 2019 4:01 pm Post subject: Re: '72-74 Turn signal repair Plastic indicator cancel part vendor |
just ordered - THANK YOU for putting all your R&D into this one. Looking forward to the new bits. |
