Beetle engine swap for rear mounted Mini Cooper engine?
BlakeNewToBugs
BlakeNewToBugs is offline
PostPosted: Fri Feb 02, 2018 8:23 am    Post subject: Beetle engine swap for rear mounted Mini Cooper engine? Reply with quote
Hi all, Iím new to the samba and am looking forward to askin many questions! My first is that I have been looking around my area and noticing a lot of older bugs that are mostly bodies with not much else to them. Im an engineering student at the university of Tennessee Knoxville and love to build unique things from near scratch and was wondering if anyone has ever heard about throwing a Mini Cooper engine in the back of a beetle. I know itís a pretty compact engine and tranny set up. My concerns if I were to attempt this would be if it may be just a hair too wide to keep the bug looking vintage? Iím a stickler for letting things stay old looking and would want to try and keep it original on the outside. Any suggestions or better ideas would be appreciated!
vwuberalles
vwuberalles is online now
PostPosted: Fri Feb 02, 2018 9:13 am    Post subject: Re: Beetle engine swap for rear mounted Mini Cooper engine? Reply with quote
Why Mini Cooper engine? do you happen to have one sitting in the garage or something? Engine swaps aren't unheard of, but a lot of people go with a Subaru since it's already a flat 4 and packaged fairly similarly to the VW engine. Rotary engines have been done too, again because they don't take up much room in the small engine bay.
1973 Superbeetle: 1st car, owned since age 12.
1966 Beetle: My new project. Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040
BlakeNewToBugs
PostPosted: Fri Feb 02, 2018 10:28 am    Post subject: Re: Beetle engine swap for rear mounted Mini Cooper engine? Reply with quote
The reason Iím looking at a mini is because Iíve seen a few recked ones that have been just rear ended. Not sure if they have the motor and tranny, but Iím sure I can find some scrapped somewhere if not. Iím trying to stay relatively cheap since i am in college, and have a small budget. Looking to start this and finish it up by the time I graduate, so gradually work on it but still stay cheap. the mini engine seems pretty tight but Iím scared if I tried to fit it that it could possibly bump into the exterior to where Iíd have to modify outside the engine compartment space. Iíve seen the Subaru flat 4s but just donít know if I could afford one. Not thought about rotary but Iím not too familiar with them so not sure how comfortable Iíd be swapping for one ya know?
Letterman7
Letterman7 is offline
PostPosted: Fri Feb 02, 2018 2:14 pm    Post subject: Re: Beetle engine swap for rear mounted Mini Cooper engine? Reply with quote
I haven't heard of anyone swapping a Cooper engine into anything. There's reasons for that. First and foremost is that every-f'n-thing is computerized and tied to every system in the car. Unless you're really good at electronics I'd steer clear.
BlakeNewToBugs
PostPosted: Fri Feb 02, 2018 2:17 pm    Post subject: Re: Beetle engine swap for rear mounted Mini Cooper engine? Reply with quote
Being a college engineer student right now makes me have to learn a lot about computers and electronics right now, but that is definetly something I will take into consideration. Thanks for letting me know that. Any other suggestions for small engines that would be a good fit?
TDCTDI
Samba Advocatus Diaboli
TDCTDI is online now
PostPosted: Fri Feb 02, 2018 4:48 pm    Post subject: Re: Beetle engine swap for rear mounted Mini Cooper engine? Reply with quote
To keep it somewhat simple, stay with an engine that you can get an adapter plate & flywheel for. Try looking at Kennedy Engineering Products for their list of available adapters & then look for a cheap donor.
BlakeNewToBugs
PostPosted: Fri Feb 02, 2018 9:28 pm    Post subject: Re: Beetle engine swap for rear mounted Mini Cooper engine? Reply with quote
Thanks for all the good advice!
Letterman7
PostPosted: Sat Feb 03, 2018 9:20 am    Post subject: Re: Beetle engine swap for rear mounted Mini Cooper engine? Reply with quote
Anything can be done.. look at http://www.shoptalkforums.com/viewforum.php?f=19&sid=9bd7cd44bd7edc684da04a2da278ba49 for engines that others have installed. Keep in mind weight when you're doing a conversion - the more weight in the rear, the worse the handling will be, even to the point of being dangerous. Subaru is the common swap now, with stand-alone wiring harnesses and computers readily available.
