Goach2 Samba Member
Joined: November 20, 2017 Posts: 522 Location: Niagara Region, Ontario
Posted: Fri Feb 02, 2018 9:17 am Post subject: '77 Evap System |
Hello all,
I just received my Evap hose kit from German Supply, and I am unable to find any good diagrams for this system. The manual doesn't have one for my year, nor does Ratwell. I've seen a few related posts, but no good overviews. This is a firewall-mounted charcoal canister, if that helps.
Thanks! _________________ 1977 FI Westfalia |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Feb 02, 2018 9:58 am Post subject: Re: '77 Evap System |
Seems to be thoroughly covered here: http://www.ratwell.com/technical/FuelHoses.html
This diagram applies to the 77 fine, the location of the canister is the only difference, the plumbing is the same (canister goes where #27 is).
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Goach2 Samba Member
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Fri Feb 02, 2018 3:58 pm Post subject: Re: '77 Evap System |
Now add a 12mm hose from the left side of the fan housing nipple to the left side nipple on the firewall mounted canister. Add another 12mm hose from the right side canister nipple to the EEC valve on the air cleaner. And #27 fuel vapor hose goes to the little nipple on the right side of the canister on the 1977 model year bus.
Colin _________________ www.itinerant-air-cooled.com |
Goach2 Samba Member
Posted: Tue Feb 06, 2018 8:12 am Post subject: Re: '77 Evap System |
Thanks for this, I am working my way through reassembly and this will help a lot. _________________ 1977 FI Westfalia |
