trektider60 Samba Member
Joined: October 30, 2012 Posts: 73 Location: SE Indiana
Posted: Fri Feb 02, 2018 8:29 pm Post subject: Body-engine seal |
What is the best lubricant to use on the seal when installing it? Are there any tricks to get it installed? I am installing it with the engine in thr car. _________________ 1960 Indiana Red T1 |
bluebus86 Banned
Posted: Fri Feb 02, 2018 10:39 pm Post subject: Re: Body-engine seal |
liquid dish soap works very well. for install, of the rear piece around the engine bay, remove the rearmost tin for seal install. After seal is installed, reinstall the tin.
make sure none of the channel is crushed, difficult to inspect with engine in car, this is important.
Good Luck, Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Fri Feb 02, 2018 10:43 pm Post subject: Re: Body-engine seal |
Egads- I’d pull the engine.
It’d help to make a small tool to run through the channel that the seal slips into, in order to make sure there are no tight spots. And I agree- dish detergent works great. _________________ Plate of shrimp |
Posted: Sat Feb 03, 2018 5:11 am Post subject: Re: Body-engine seal |
Thanks guys; I thought dish soap would work after using it on the windshield. The last time I pulled a VW engine was 30 yrs ago and at 68 I don't want to try it by myself now. The nearest shop thought it would take about 3 hrs ( at $65/hr) to get it done. I have the old seal out and have all the major dents taken care of. A tool would be great; I'll work on that _________________ 1960 Indiana Red T1 |
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Sat Feb 03, 2018 6:01 am Post subject: Re: Body-engine seal |
Search GabFab on the classifieds. He sells the tool for only $15. _________________ '63 Ragtop |
gt1953 Samba Member
Posted: Sat Feb 03, 2018 7:28 am Post subject: Re: Body-engine seal |
Honestly let the shop handle it providing that you can observe. It is a pain to do with engine installed. I am sixty five and just pulled and installed a different engine. Had assistance from friends. Now check out local VW clubs. They may assist. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat Feb 03, 2018 9:00 am Post subject: Re: Body-engine seal |
gt1953 wrote: |
It is a pain to do with engine installed. |
It was a pain to do this with the engine removed, on my 1970 just last year. I had to chisel out those seals and pry open the channels, and use lube (can't remember if I used dishwash liquid or glycerin), then tap the channel down into place. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Sat Feb 03, 2018 11:41 am Post subject: Re: Body-engine seal |
I vote pull the motor. _________________ 2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold |
Jennepher Administrator
Joined: September 10, 2002 Posts: 4767 Location: Arizona
Posted: Sat Feb 03, 2018 4:33 pm Post subject: Re: Body-engine seal |
OP had a dupe thread for this question which was removed. There was one response, quoted below:
smitty24 wrote: |
I have used Dawn soap and hot water, as well as this clear jelly stuff we used at the restoration shop made for installing windows in a car. Can’t remember the name but it is literally like KY jelly and makes it go so smoothly! Probably any good silicone spray would do. I don’t usually do the engine seal with engine in but it is possible. If those compartment seals are stupid tight, you can always remove some of the tin To get the seals in, then reinstall tin. One thing I do is carefully use a brake adjusting tool or large flathead to open metal channel slighly more to allow seal to slide in easier. |
_________________ Donate to TheSamba.com
If your post begins "I know this is against the rules but..." just stop typing. |
Posted: Sat Feb 03, 2018 4:59 pm Post subject: Re: Body-engine seal |
Jennepher wrote: |
smitty24 wrote: |
I would note the last sentence... _________________ '63 Ragtop |
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Sat Feb 03, 2018 10:46 pm Post subject: Re: Body-engine seal |
Thanks Jennepher for the reference! I was wondering where that reply from last night went. |
