plimthing Samba Member
Joined: March 29, 2014 Posts: 278 Location: West Midlands UK
Posted: Sat Feb 03, 2018 2:49 am Post subject: throttle cable repair |
Hi guys
Installed a new throttle cable on my 72 bus and low and behold the darn thing is 6" too short
I need to get the bus out of the garage and spun around, any good tips to temporarily extend a cable?
Will just be a temporary fix until a new cable arrives.
Regards |
nodrenim Samba Member
Joined: October 06, 2006 Posts: 843 Location: Dobson, North Carolina
Posted: Sat Feb 03, 2018 5:47 am Post subject: Re: throttle cable repair |
If you have some extra barrel bolts and some picture hanging cable, you are in business. Sometimes called "Yankee Ingenuity". Good thing to carry in that gadget box, you stashed under the driver's seat, remember? |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Feb 03, 2018 6:16 pm Post subject: Re: throttle cable repair |
An electrical connector called a split bolt and a short piece of control cable will work as well. Wire coat hanger maybe? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Sat Feb 03, 2018 10:32 pm Post subject: Re: throttle cable repair |
I’d steal a barrel clamp off my heater cable. Then Cut the old cable off At about 3 feet from the carb end. Go under the bus and splice the new and the old cables together near the transmission. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Terminatez Samba Member
Joined: June 07, 2015 Posts: 340 Location: Sun Valley, CA
Posted: Sun Feb 04, 2018 1:16 pm Post subject: Re: throttle cable repair |
http://www.busdepot.com/211721555j
I think that is the correct cable length for the 72 bus.saw the information from the early parts manual, but can anyone else confirm this? _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
I don't think I've ever seen an engine in worse shape. |
Posted: Sun Feb 04, 2018 1:28 pm Post subject: Re: throttle cable repair |
good call on the robbery from heater cable! I have 2 new linkeages to install for my heaterbox's so they can be used till a nice cable of correct size comes!
Think I better remove this cable first and measure to ensure I don't get another incorrect length one
Thanks for tips everyone, unbelievably my local motor factors here in UK doesn't sell the barrel nuts! Suprising as its a leading bicycle sales place too!
A nice job for Monday whilst the kids are at school I think! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Sun Feb 04, 2018 9:01 pm Post subject: Re: throttle cable repair |
aeromech wrote: |
I’d steal a barrel clamp off my heater cable. |
Yeah but it was 75° here today………
www.airschooled.com |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Sun Feb 04, 2018 9:50 pm Post subject: Re: throttle cable repair |
plimthing wrote: |
... Think I better remove this cable first and measure to ensure I don't get another incorrect length one ... |
Tie a string to the end before you remove. That will show you the correct routing for the new cable and/or you can use the string to pull the new cable through. BTDT
Aloha
tp |
Posted: Mon Feb 05, 2018 2:01 am Post subject: Re: throttle cable repair |
Tom Powell wrote: |
plimthing wrote: |
Aloha
tp |
If you’re using a string, it might be nice to tie a little strip of a microfiber rag or towel to the end of the string to help clean the tube. Because sooooo many POs love to clean their tubes out...
