Clatter Samba Member
Joined: September 24, 2003 Posts: 7549 Location: Santa Cruz
Posted: Sun Feb 04, 2018 9:34 am Post subject: Nybody Know the Free Length of Pressure Relief Valve Springs? |
Dual port relief valve springs..
It says how many pounds at what installed height and all in the Bentley,
But,
Is there a free/open measurement anywhere,
Just to make sure it's ball-park?
Have too many springs here in a box, and can't remember which is which..
_________________ Bus Motor Build
What’s That Noise?!? |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sun Feb 04, 2018 9:40 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
last time I searched, there were a few comparisons in the gallery. One had lengths listed. _________________ modok wrote:
esde Samba Member
Posted: Sun Feb 04, 2018 9:43 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun Feb 04, 2018 9:45 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
The set I have measure,
1.485" for the forward (flywheel end) spring
and,
3.607 for the rearward spring.
The above are from a new set of OEM springs.
God Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Feb 04, 2018 9:55 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
Esde,
Yeah, I searched,
And got the same conundrum:
A few springs that I don't know what they came from,
And the 'Compressed load' table from the Bentley..
Those pics coulda been taken from my bench right now!
Rustavenger - Thanks!
Those new springs came from ac.net, or..?
Did they come in a 'blister pack' from one of the big names?
Because they are quite a good bit longer than both of the ones i 'guessed was it' in my pic,
I'm wondering if they aren't from a 'booster' set?
Used to be, that the only springs you would see for sale were the booster kind.
And stock springs were already available from all of the stock cases, so why sell any, if y'know what i mean...
Sure are a LOT of different lengths here in this drawer o'mine.
Single and dual-relief, both type 1 and type 4, booster style.. and some probably from a garden hose or something..
Guess it gives a guy a chance to fine tune... _________________ Bus Motor Build
Posted: Sun Feb 04, 2018 9:59 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
Also notice that the biggest one in Esde's pic is just over 3"?
Seems to be the same with most other pics n the gallery.. _________________ Bus Motor Build
Posted: Sun Feb 04, 2018 10:11 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
Jake, and others, will add the grooved "1500 S" plunger as an upgrade..? _________________ Bus Motor Build
Posted: Sun Feb 04, 2018 10:16 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
I got the springs in a universal hardware kit from a local well respected supply house.
I specifically asked for an OEM set. Not the booster kit that blew out two oil coolers and my 1776 I built 20 years ago.
They get their parts from among other places, Pacific Parts International.
Sadly I have discarded the package that they came in.
The P/N is 113 198 033.
If I have mislead you. I apologize.
EDIT: The parts were not in a blister pack. _________________ I have learned over the years.
Buy Once, Cry Once!
Last edited by 67rustavenger on Sun Feb 04, 2018 10:19 am; edited 1 time in total |
Posted: Sun Feb 04, 2018 10:18 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
Posted: Sun Feb 04, 2018 10:21 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
67rustavenger wrote: |
If I have mislead you. I apologize. |
Not at all, brother, much much appreciated!
There are a TON of pics and discussion in the gallery,
But,
Not a one was "Here's the free length measurement on a new spring" like you just gave me.
Thanks, and thanks again!
I'm just snooping out the details here, and that's exactly what kind of things need known.. _________________ Bus Motor Build
Posted: Sun Feb 04, 2018 10:23 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
Wouldn't the 311 in the P/N you posted be for a type 3? Since type 1's were never, to my knowledge delivered with twin carbs. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sun Feb 04, 2018 10:26 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
Wouldn't the 311 in the P/N you posted be for a type 3? Since type 1's were never, to my knowledge delivered with twin carbs. |
Yes, sir. Hence it's "1500S" moniker..
Here's a good one..
esde Samba Member
Posted: Sun Feb 04, 2018 11:12 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
Clatter, I have a pile of stock springs that I've removed from core engines, but they're at my shop. I remember checking them a while ago, and observing that there is variation in the length of both the short and long springs. It could be that some have lost tension, or be how they were made. I'm just guessing, maybe someone actually knows? My recollection is there was maybe 3-4mm difference in length, in a pile of 10-12 springs. I think the point I'm trying to make is, the length might not be exact and that probably is ok. Finding one with the correct rate is what's important. _________________ modok wrote:
mr. lang Samba Member
Posted: Tue Feb 27, 2018 4:50 am Post subject: Re: Nybody Know the Free Length of Pressure Relief Valve Springs? |
NOS set of valve springs, bought directly from VW:
single relief:
113 115 421: 63mm (2.48") and compressed 23.6mm (0.93")
dual relief:
111 115 421 A (long spring): 81mm (3.19") and compressed 26.9mm (1.06")
111 115 425 A (short spring): 32mm (1.26") and compressed 9.5mm (0.37") _________________ 1966 Bus | 1969 Bug | 1976 Passat LX two-door | 1984 Golf 2 C (daily driver)
There are three kinds of people: those who can count and those who can't
Und läuft ... |
