Posted: Sun Feb 04, 2018 12:08 pm Post subject: Seal for FI-FP relay box, 83-85 |
Opened the relay box on my 83 1/2 today to get at the relays and the seal around the rim might as well have been a roll of dried up clay. Wondering what others have done to fix this? |
B.O.B.Wanders Samba Member
Joined: July 22, 2014 Posts: 351 Location: Atlanta, GA USA
Posted: Sun Feb 04, 2018 12:33 pm Post subject: Re: Seal for FI-FP relay box, 83-85 |
Interested also. Mine has no seal at all. _________________ 83.5 WBX 2WD Assuan Brown Westy, B.O.B.
"It feels good to be lost in the right direction” - unknown |
Vanagon Nut Samba Member
Posted: Sun Feb 04, 2018 4:15 pm Post subject: Re: Seal for FI-FP relay box, 83-85 |
I recently, "ahem", misplaced that seal for one of my relay boxes.
Haven't tried but is there a large O ring that could be used here? Cut and spot glue?
1988 West DIY 50º ABA
VE7TBN |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Zeitgeist 13 Samba Member
Posted: Sun Feb 04, 2018 4:23 pm Post subject: Re: Seal for FI-FP relay box, 83-85 |
Clean the groove real well with rubbing alcohol and then run a thin bead of RTV in there while in the open position. Let set overnight and Bob's yer Auntie. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sun Feb 04, 2018 4:54 pm Post subject: Re: Seal for FI-FP relay box, 83-85 |
Zeitgeist 13 wrote: |
Clean the groove real well with rubbing alcohol and then run a thin bead of RTV in there while in the open position. Let set overnight and Bob's yer Auntie. |
I was figuring I might go that route. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Sun Feb 04, 2018 8:40 pm Post subject: Re: Seal for FI-FP relay box, 83-85 |
the original seal is a high compliance rubber. o ring might be too hard to gt the lid to snap down. just wipe a piece of string or yarn with rubber cement and push it in the groove. it'll keep enough dust and water out for whats in there..
dan |
Posted: Mon Feb 05, 2018 12:28 pm Post subject: Re: Seal for FI-FP relay box, 83-85 |
DanHoug wrote: |
the original seal is a high compliance rubber. o ring might be too hard to gt the lid to snap down. .....
dan |
Right. I see what you mean. Agreed.
As a side note, that OE seal must really work well. I'm re-assigning wires an '85 box. The connections and wire strands look very clean.
VE7TBN |
Posted: Mon Feb 05, 2018 12:33 pm Post subject: Re: Seal for FI-FP relay box, 83-85 |
mine had shrunk, come loose and drooped down, allowing dust into the box. glued it back into place and filled in the gap between the ends with RTV.
EVERYTHING has shrunk on my van... trim, engine lid seals, pop top seal, skylight seal, etc. life with antiques.
-dan |
