neisman Samba Member
Posted: Sun Feb 04, 2018 5:36 pm Post subject: 1500 Beetle Engine CFM |
On my custom Beetle, I must route cooling air from a new location.
Can anybody tell me how mant CFM a 1500 engine needs for cooling?
Also, are there aftermarket fans that deliver more air to the cylinders? |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Sun Feb 04, 2018 6:29 pm Post subject: Re: 1500 Beetle Engine CFM |
Remember, the engine code is a BORN-ON specification, it does not indicate anything that was done after that.
So, are you sure it's really even a 1493cc engine? Really, since the early 1970s, the go-to option at rebuild time was to bolt on 85.5mm pistons and cylinders, resulting in 1584cc. So, if it might have been rebuilt once in the last 45 years.... _________________ Andy T.
gt1953 Samba Member
Posted: Mon Feb 05, 2018 6:42 am Post subject: Re: 1500 Beetle Engine CFM |
Just finally rebuilt my 1493cc engine last week after 50 yrs yes it did have 83 piston and cyl and was the first time ever. All the bearing were stamped with VW logo. So now I have a new born on date.
You should be fine with the 1584cc engine using the 1493cc fan.
Do tell us more about the "custom Beetle". _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Maddel Samba Member
bluebus86 Banned
Posted: Mon Feb 05, 2018 9:59 am Post subject: Re: 1500 Beetle Engine CFM |
of course the graph probably assumes no inlet restriction on the fan. At high rpm, the larger fan draws a vacuum in the engine bay of cars with non louvered deck lids, unless the lid is opened a bit. with that vacuum, the air flow is reduced, even robbing air from the needs of the carb, so engine chokes itself. I know, I put a large fan in an early Bug, solid deck lid and she choked at high speed, under load, until I propped open the deck lid
Good Luck, Bug On, where ever the wind blows you! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Wed Feb 07, 2018 6:30 pm Post subject: Re: 1500 Beetle Engine CFM |
And there you have my conundrum. On my Hebmueller type custom, I do not want to use louvers on the hood or top of the body. I also want to avoid them on the quarter panels.
My thought is to duct engine cooling air from the front of the car through the shifter tunnel. I am wondering if I can get enough air through there to cool the engine. I suppose I will just have to experiment a bit. Thanks everybody! |
AlmostHeavenWV_VW Samba Member
Posted: Wed Feb 07, 2018 7:59 pm Post subject: Re: 1500 Beetle Engine CFM |
If you make your 'shifter tunnel air intake' a "ram-air" style, I bet you could get some serious CFMs back to the fan.
Leave the inspection cover off (or enlarge it) and put some ducting to make the best of the available airflow. Make sure to get you a very good air filter. You don't want all that road debris ending up in the tunnel ( or into the cooling fan)
A note to consider with this design: That will be noisy in the passenger compartment.
Perhaps a 'ram-air' style intake snout that just comes down from the engine compartment and the snout is underneath the car? Maybe terminating around the level of the transaxle? _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Wed Feb 07, 2018 8:17 pm Post subject: Re: 1500 Beetle Engine CFM |
neisman wrote: |
Why not do a custom duct from the tranny area. Install a duct from that area under the luggage shelf, come up through the luggage shelf and put the duct through the firewall right in back of the fan. You could even extend the metal down inside the tranny area to have a scoop, that could grab air as it is moving by at whatever your speed is. Ram air injection to the fan, it would be cool outside air as well!
_________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
airschooled Air-Schooled
Posted: Thu Feb 08, 2018 2:04 am Post subject: Re: 1500 Beetle Engine CFM |
Later model bugs even had louvers behind the license plate. (Of course, they were thermostatically controlled to open only when the engine was hot…)
That chart's a little funky… Anybody have a link to that dude's dissertation that showed around 4,800 engine RPM (8k-9k fan RPM) the belt started to slip and the fan wouldn't go any faster as the engine did?
www.airschooled.com |
Maddel Samba Member
Posted: Thu Feb 08, 2018 5:24 am Post subject: Re: 1500 Beetle Engine CFM |
neisman wrote: |
On my Hebmueller type custom, I do not want to use louvers on the hood or top of the body. I also want to avoid them on the quarter panels. |
Just my two cents...
What's wrong with the Hebmüller style louvers?
Posted: Thu Feb 08, 2018 7:40 am Post subject: Re: 1500 Beetle Engine CFM |
VW_Jimbo wrote: |
Good diagram Jim- that's exactly what I was meaning _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Thu Feb 08, 2018 1:57 pm Post subject: Re: 1500 Beetle Engine CFM |
I don't remember if we talked about this
I ended up putting a couple small fans in it after still having some overheating issues. It cured the problem, but one of these days I need to do a cleaner fan installation. The other thing you want to take into account is getting rid of the hot air from the top of the engine. On the woodie, I opened up the bottom of the tailgate a little to do that. _________________ D-Dubya Manx clone - 63 Short pan,1914.
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Thu Feb 08, 2018 10:54 pm Post subject: Re: 1500 Beetle Engine CFM |
The problem with pulling air from below the car is dust/dirt. You will need some type of filter to avoid pumping dust into the carb intakes. Yes, your carb(s) should have air cleaners but you don’t want to intentionally foul them with dirty air. This is why the engine vents are on the top of the car where the air is cool and relatively clean.
Another option is to add filtered openings in the rear wheel wells. I know I saw a thread where someone created a custom box in each rear wheel well that allowed air to flow into the engine compartment thru filters. I couldn’t find that thread but I found a classified add for access panels at the same spots. Maybe you could start from there. Panels in the wheel wells would be well hidden from the exterior but allow a larger volume of air flow into the engine compartment. Coming from the wheel wells the air would bea little less likely to recirculate hot air from under the engine.
https://www.thesamba.com/vw/classifieds/detail.php?id=989492 _________________ AshMan40
bluebus86 Banned
Posted: Fri Feb 09, 2018 5:52 am Post subject: Re: 1500 Beetle Engine CFM |
AlmostHeavenWV_VW wrote: |
VW_Jimbo wrote: |
Good diagram Jim- that's exactly what I was meaning |
Having a kit car, I have found that a design such as above is prone to vacuuming the street. Leafs, paper, gum wrappers, dirt. etc... can be sucked up i to the fan, blocking fan blabes, cylinder and head cooling fins, a real mess to clean out Even dust will rapidly build up on the fins, reducing heat flow.
Consider that VW picked up its air from up high on the car, not under it near the dirty road.
I knew someone that made a ran inlet for a 914 track car, big fat maybe 8 inch diameter pipe hooked to a duct on the nose, right thru the car to the motor fan inlet. Worked like a charm on his track car. but that was for racing, on a clean track, not daily driving on dirty streets. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Fri Feb 09, 2018 6:28 am Post subject: Re: 1500 Beetle Engine CFM |
Dirt being drawn up is an issue with my set up....But then, I have a mile long dirt and gravel lane. But if going to a show, I leave early so there is still a little dew on the lane, so, little dust. Even after a couple hour drive, the engine is still pretty clean. I have a 1/2" wire mesh at the air box entrance to prevent large stuff from getting in. So, overall, it works.
However, as mentioned, there were problems initially. Highway speeds were no issue, but low speed cruising or coming in my lane (20 MPH) elevated engine temps. Pretty sure I used two 8" Derale fans that are about 500 cfm each.
This process was all trial and error. My tailgate had a a bit of a gap at the bottom to help draw air through the engine compartment (negative pressure), but I opened that up a bit more after adding the fans. Don't remember the the exact square inches, but I am pretty sure that I calculated the actual vent size of the stock VW louvers and came close.
And I had also gone through a lot of iterations for other cooling designs (inner fenders, etc) before settling on what I did.
Now here is something interesting though, I have a second VW Woodie built around 40 years ago that is completely different. Based on a type 3 engine compartment and engine, the car draws cooling air from behind the rear wheels. This car has traveled over 100,000 miles (many of those hauling a tear drop trailer) without an engine rebuild.
Just a some stuff to ponder. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Fri Feb 09, 2018 10:06 am Post subject: Re: 1500 Beetle Engine CFM |
neisman wrote: |
... Also, are there aftermarket fans that deliver more air to the cylinders? |
Just a comment on this initial question...
Many years ago, after reading the above write up on the airflow of the VW fan I went looking for electric blower fans that could replace the stock fan shroud. Thinking that improvements in fan technology might allow an electric fan to flow more than the stock fan. I noted that many race engines used electric blowers in place of the fan shroud like this:
Unfortunately, what I discovered was that these race motor blowers were only used to cool the engine BETWEEN runs. They didn't provide enough cooling for use on street engines that continuously generated heat. The blowers could not keep up with the heat generated over more than a short run (1/4-mile).
Using the chart from the thread:
The largest 12v blowers I could find were capable of no more than around 250cfm. Even using two blowers (500cfm) the stock fan produces more airflow above around 1500rpm (engine speed).
Going to 115VAC/4A blowers you could get as much as 2000cfm from two blowers. This would give you the equivalent flow of around 5000rpm (engine) with the stock fan. But you would need to produce more than 80A at the alternator (460W) just to power the two blowers!
At which point I gave up on the idea of using an electric motor as a fan replacement. _________________ AshMan40
Posted: Fri Feb 09, 2018 2:51 pm Post subject: Re: 1500 Beetle Engine CFM |
[quote="Maddel"]
I don't know that anything is wrong with them. |
Posted: Sun Feb 11, 2018 1:47 pm Post subject: Re: 1500 Beetle Engine CFM |
I want to keep as much storage space behind the seats as possible so I will avoid an air box that large. |
Posted: Sun Feb 11, 2018 2:29 pm Post subject: Re: 1500 Beetle Engine CFM |
Here is something to do, and I am sure that I can't find my data. The air input to the engine is the louvers above the deck lid and the louvers on the deck lid for later cars. The actual area is not that large... In particular the louvers above the deck lid....The actual openings are quite a bit smaller. I thinking it was under 100 sg'? Any way, I folks have used cut outs behind the license plate and other places to get an opening that is not obvious.
AND you can use multiple locations to get the air. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Mar 13, 2018 9:54 am Post subject: Re: 1500 Beetle Engine CFM |
I am dieing to get the body back from the body shop. I really cannot do much till then except research and plan. The body man is not too keen on me working on the car in his shop.
That is a great idea. I will measure the OEM grill openings and start from there. |
