99Eurovan144K Samba Member
Joined: February 04, 2018 Posts: 7 Location: Anchorage
Posted: Sun Feb 04, 2018 11:38 pm Post subject: Eurovan stalls on start, Extra gas pedal keeps engine running |
Engine only starts if I give it gas during ignition. Will initially stall on idling out of driveway etc unless gas is maintained. Once van gets some speed, engine maintains, wants to stall at under 5 mph, stops etc.
Alternator? Fuel system?
Battery light stays on initially at start until I rev the engine rpms up.
99 Eurovan 144,000 mi
Thanks for any suggestions! |
mvaska Samba Member
Joined: February 26, 2015 Posts: 135 Location: United States
Posted: Tue Feb 06, 2018 7:39 am Post subject: Re: Eurovan stalls on start, Extra gas pedal keeps engine running |
fix the bat light issue first and see if that clears it up.
unless the alternator has a bearing issue you can just replace the back part for $60 or so. bat light comes on if voltage is really really low. alternator should provide enough power even at idle so... something is up there. it's either the alternator or wiring. because it's fine at higher RPM i'd venture it's not wiring.
and... maybe bat issues is related to stalling or maybe not... either way it needs to be fixed and you might just solve both issues. |
Posted: Tue Feb 06, 2018 10:11 pm Post subject: Re: Eurovan stalls on start, Extra gas pedal keeps engine running |
Good copy on all. Had battery checked, 100% good.
I’ll move on to the alternator and get it checked.
Also of note, at an idle, if I “spike” the rpm’s, when the rpm’s drop back to idle, the engine wants to stall out. Sounds like the alternator is just not keeping up at baseline idle.
Thanks for previous help! |
Posted: Tue Feb 06, 2018 10:15 pm Post subject: Re: Eurovan stalls on start, Extra gas pedal keeps engine running |
Forgot to mention initially, a few weeks before the idle issue, the yellow/orange “transmission” light had been turning on intermittently, as it still continues to do. |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Sat Feb 10, 2018 7:25 am Post subject: Re: Eurovan stalls on start, Extra gas pedal keeps engine running |
transmission light?
check your temp sender for the starting issue. _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
postjosh Samba Member
Posted: Sun Feb 11, 2018 1:43 pm Post subject: Re: Eurovan stalls on start, Extra gas pedal keeps engine running |
i just had my ‘93 fixed for the same issue. it was a leak in one of the vacuum lines. apparently this is a common issue. |
Goliath59 Samba Member
Joined: November 24, 2017 Posts: 3 Location: Minneapolis,MN
Posted: Mon Feb 19, 2018 10:54 am Post subject: Re: Eurovan stalls on start, Extra gas pedal keeps engine running |
Could be map sensor / computer/fuel pressure regulator clogged up catelac converters . I just spent about 5 grand on mine and still does same thing.... |
