bug1200 Samba Member
Joined: July 07, 2015 Posts: 222 Location: Philippines
Posted: Mon Feb 05, 2018 7:10 am Post subject: The engine |
I always refer to the bugs engine as a boxer engine, some guys call it a flat four.
But i just read an article about the differences of a boxer and a flat engine, which should be called a 180 degree V engine.
quote: "the boxer mill employs one crankpin per cylinder, while the flat (horizontal V) engine uses one crankpin per two horizontally opposed cylinders."
so where does the vw engine fit exactly here? (getting off topic) how bout a subaru engine? they both have different firing orders. and whats their difference? (flat and boxer)
I drove my friends subie today, the vibration at idle was immense (although i believe he has polyuwhatever mounts) compared to my bugs idle which is smooth while virtually not having any form of sophisticated mounts. although a slight wobbly feeling though from time to time.
It might not sound like one but the vw engine is quite a smooth engine compared to the subie that makes my butt numb after a few mins... |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4522 Location: Oklahoma City, OK
Posted: Mon Feb 05, 2018 7:49 am Post subject: Re: The engine |
Boxer Engine defined direct from the web:
"A flat engine is an internal combustion engine with horizontally-opposed cylinders. Typically, the layout has cylinders arranged in two banks on either side of a single crankshaft and is otherwise known as the boxer, or horizontally-opposed engine.
and a Horizontally Opposed Engine
"A flat engine is an internal combustion engine with horizontally-opposed cylinders. Typically, the layout has cylinders arranged in two banks on either side of a single crankshaft and is otherwise known as the boxer, or horizontally-opposed engine." |
kamesama980 Samba Member
Joined: June 22, 2014 Posts: 323 Location: Columbus, IN
Posted: Wed Feb 07, 2018 11:35 am Post subject: Re: The engine |
It's hard to wrap your head around at first. BMW bikes (2 cylinders), VW (4) and subie (4 and 6) are all boxer engines. That means that each pair of cylinders moves in opposite directions cancelling out the inertia of the piston travel with the opposite piston.
Flat engines, by having a common crankpin, move pairs of cylinders together in the same direction so with low cylinder counts would shake like a mofo. you see them occasionally in ferraris and lambos and the like in 8 or 12 cylinder arrangements. Vibrationally, the 12 is basically 2 I6s.
Hold up your arms at your shoulders, then push both out, they cancel out. that's a boxer. Now hold one arm extended to the side, and one at your shoulder. now alternate, feel your torso get pushed side to side. that's a "flat". _________________ -Russell
"You don't get to blame me for how I fix what you break"
1970 VW Beetle
1994 Pontiac Firebird
2001 BMW R1200C
2003 Subaru Baja |
Mid Engine Bug Samba Member
glutamodo The Android
Joined: July 13, 2004 Posts: 26315 Location: Douglas, WY
Posted: Wed Feb 07, 2018 12:44 pm Post subject: Re: The engine |
I would never call a horizontally opposed engine any kind of "V". Boxer, yes. Flat, yes. _________________ Andy T.
Posted: Wed Feb 07, 2018 2:12 pm Post subject: Re: The engine |
So where does that leave the lowly "pancake engine"? |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Wed Feb 07, 2018 3:08 pm Post subject: Re: The engine |
busman78 wrote: |
With VW, Porsche, Continental, BMW, Pratt & Whitney, Curtis Wright, Lycoming, Mitsubishi, Subaru, and others. They all have made them, Google "Pancake engine" and see for yourself. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Feb 07, 2018 8:37 pm Post subject: Re: The engine |
I'm still puzzled by the talk of the "cylinders moving in opposite directions", etc.
I always thought the cylinders stayed put and the pistons did the moving. |
Helfen Samba Member
Posted: Wed Feb 07, 2018 9:18 pm Post subject: Re: The engine |
iowegian wrote: |
Not always, not old WW1 radial fighters. See link below;
Rough Flight in Fokker Triplane.mpg - YouTube
▶ 5:14
https://www.youtube.com/watch?v=0aaf2WnHG_A |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Wed Feb 07, 2018 11:04 pm Post subject: Re: The engine |
Helfen wrote: |
iowegian wrote: |
▶ 5:14
No....not "radial"....ROTARY. Totally different concept.
In a radial....its called "radial" because the cylinders "RADIATE" outward in a circle. The cylinders stay still and the crank rotates. About 90% of ww1 aircraft and about half of ww2 were "radial" engines.
What you are thinking of is "ROTARY" engines....and I do not mean Mazda style.
In the the rotary aircraft engine ....the crank is bolted to basically the firewall....and is fixed....and the block, cylinders and heads spin around it.
Ray |
Posted: Thu Feb 08, 2018 7:48 am Post subject: Re: The engine |
thanks for you replies, perhaps the best way to describe it would be to just say the vw engine...
but im just really curious why the subaru vibrates much more than the bug, considering that the bug virtually has no sort of sophisticated mounting... |
slave1pilot Samba Member
Joined: February 22, 2010 Posts: 943 Location: Tehachapi CA
Posted: Thu Feb 08, 2018 9:31 am Post subject: Re: The engine |
bug1200 wrote: |
wait, I thought it was a motor...
_________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Helfen Samba Member
Posted: Thu Feb 08, 2018 3:44 pm Post subject: Re: The engine |
raygreenwood wrote: |
Helfen wrote: |
iowegian wrote: |
▶ 5:14
Ray |
The rotary engine is often called the stationary radial. |
chickengeorge Samba Member
Joined: August 18, 2004 Posts: 5634 Location: Spokompton Warshington
Posted: Thu Feb 08, 2018 4:34 pm Post subject: Re: The engine |
bug1200 wrote: |
I like to refer to either one as a boat anchor. |
Posted: Thu Feb 08, 2018 5:30 pm Post subject: Re: The engine |
Helfen wrote: |
Helfen wrote: |
iowegian wrote: |
▶ 5:14
Ray |
Whadda ya got if'n the propeller remains horizontal and the aeroplane fuselage rotates --------then wot? |
Helfen Samba Member
Posted: Thu Feb 08, 2018 8:17 pm Post subject: Re: The engine |
iowegian wrote: |
Helfen wrote: |
Helfen wrote: |
iowegian wrote: |
▶ 5:14
Ray |
Torque steer. |
Posted: Fri Feb 09, 2018 5:45 am Post subject: Re: The engine |
slave1pilot wrote: |
bug1200 wrote: |
lol, haha. now that you think about it the words "motor" and "engine" are both interchangeable and can be used to describe "the thing that makes your car vroom vroom! and makes it move" so i dont think flat or boxer would really matter now... |
Helfen Samba Member
Posted: Fri Feb 09, 2018 8:40 am Post subject: Re: The engine |
bug1200 wrote: |
bug1200 wrote: |
Never heard a steam engine being called a steam motor. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Fri Feb 09, 2018 8:58 am Post subject: Re: The engine |
busman78 wrote: |
Pancake simply refers to peripheral configuration (i.e. carbs, cooling, etc). Engine block is essentially the same. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Helfen Samba Member
Posted: Fri Feb 09, 2018 9:10 am Post subject: Re: The engine |
Toyota had a van called Previa in 84 and it had a water cooled I4 engine laying over on it's side positioned in the middle of the van under the passenger/ cargo floor pancake style.
https://www.toyoland.com/photos/1987/van.jpg |
