need anyone's help on cooling idea
dcavy
dcavy is offline
PostPosted: Mon Feb 05, 2018 12:11 pm    Post subject: need anyone's help on cooling idea Reply with quote
So Im hoping someone here can help me out with an idea for alternate cooling for my volksrod project. Im going at this with a different approach where I would like to not run the doghouse just due to it sticking up thru the window area. The idea on the build was to try and keep as much of the motor unexposed other than the area where the rear decklid would be. Ive re indexed where the rear torsion housing sits moving it about 10 inches forward and at least 8" higher to run a tall tire as you can see by the profile pic. Ive looked high and low for the horizontal fan setup but no one seems to make it anymore, and an electric setup I've heard cannot support the cfm needed for good cooling. Ive even tried the type 3 setup but it hangs out so far that it looks like I have a jet engine hanging off the back and have no way to hide it. Any help?
vwuberalles
vwuberalles is offline
PostPosted: Mon Feb 05, 2018 12:56 pm    Post subject: Re: need anyone's help on cooling idea Reply with quote
Run a Corvair engine.
1973 Superbeetle: 1st car, owned since age 12.
1966 Beetle: My new project. Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040
VOLKSWAGNUT
Fastest VW Belt Changer
VOLKSWAGNUT is offline
PostPosted: Mon Feb 05, 2018 1:36 pm    Post subject: Re: need anyone's help on cooling idea Reply with quote
dcavy wrote:
S. Ive even tried the type 3 setup but it hangs out so far that it looks like I have a jet engine hanging off the back and have no way to hide it. ]
Why hide it.. Anxious Embrace it.. It goes with the raw mechanical look..
The Corvair engine is longer than the Type 3 set up.. and a horizontal fan set up.. sucks..
A fan kit could be ceated... using some corvair parts . but the fan mount itself would be the kicker.. Corvair set up is similar.. but very different..
You cant find the Vw Horizontal fan kit anymore.. cause it didn't work well.. fried alot of engines..
Plus there is the whole carb issue and intake if you want to use stockish parts there...
Id convert it to Type 3 fan and roll .
If you dont like the rear fan look... build a louvered/mesh cover for it..
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
vaughn bros.
vaughn bros. is offline
PostPosted: Mon Feb 05, 2018 5:53 pm    Post subject: Re: need anyone's help on cooling idea Reply with quote
If that's a carb and velocity stack location in the back window, then I'm sold. Very Happy Wild looking ride.
eyetzr Premium Member
eyetzr is offline
PostPosted: Tue Feb 06, 2018 5:09 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
You may start with a remote oil cooler to free up space on the motor, and pull some heat away. Creating a fan & housing my be the option to go with if you are not a lover of the type 3 look. ( you may want to look at Neil's bubble top build) You could just run some duct work & do the same as a BMW bike, drive fast, engine stays cool. Keep us posted. Cool looking ride.
I think he meant "rare", as in "not well-done"
Bashr52
Bashr52 is offline
PostPosted: Tue Feb 06, 2018 6:29 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
IF you managed to get enough ducting around the engine to drive air over the rights spots when the car was moving, you will still overheat quickly when stopped.....
If you do not want the height and look of the Type 1 setup, type 3 or 4 are really the only other options.
nshaddox
nshaddox is offline
PostPosted: Tue Feb 06, 2018 8:26 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
looks like even t3 cooling would be a tight fit unless you move the vent section up a bit and 'chop' the rear window opening some more. probably the easiest route. what is your plan for generator/alternator mounting? looks like that will be tricky too.
it almost looks like you have room to create some custom duct work to blow up from the bottom rather than from the top down. maybe if you run a pair of mini alternators you will have the power you need to run fans and do it that way? also mounting them under the crank case? not sure...post up a few more pics from the rear.
dcavy
dcavy is offline
PostPosted: Tue Feb 06, 2018 11:19 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
I had tried the type 3 cooling fan set up but it looked more like I strapped a jet onto the back.
dcavy
dcavy is offline
PostPosted: Tue Feb 06, 2018 11:22 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
I would have no problem using small fans with ducting but I believe they cannot support the cfm air volume to cool the heads when at a traffic light but if someone has has success please let me know.
andk5591 Premium Member
andk5591 is offline
PostPosted: Tue Feb 06, 2018 12:35 pm    Post subject: Re: need anyone's help on cooling idea Reply with quote
I think there is data on here as far as CFMs a stock fan puts out. Was a pretty large number. Found it - Rob and Daves
Note: Air flow for the non-doghouse 1300/1500/1600cc engines is 20 cubic feet per second at 4000 rpm. The doghouse cooling fan is wider and blows around 25cf/sec @ 4000rpm, which is why cars with this cooling set-up NEED a slotted engine lid - the slots under the rear window are simply not large enough to provide the doghouse fan running with enough air at higher speeds.
So - looking at 1200 CFM....AND there is a little more to it because of the load. And there are pusher and puller type fans. Probably need at least a 10" or maybe a pair of 8 or 9". Assuming you took care of oil coiling separately, it would not be that difficult as long as you used stock cylinder tins. You just need to fab ductwork to give a nice transition from the fans (I would try to do 2 smaller ones) into the top of the cylinder tins. Why not.....
But pancake coolling with the extra ports for cabin heat cut off could be kind of cool and put a fan guard over the fan and paint the fan black. You will loose the jet engine effect.
D-Dubya Manx clone - 63 Short pan,1914.
Max - 73 standard Beetle hearse project
There's more, but not keeping them...
eyetzr is offline
PostPosted: Wed Feb 07, 2018 5:35 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
I remember seeing a kit car of sorts with 2 squirrel cage fans on top of the factory VW tins. They had some ducting running under the car. Not sure on the operation, but that may work.
Bashr52
Bashr52 is offline
PostPosted: Wed Feb 07, 2018 7:58 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
Do a search in the performance section on electric cooling, it's been covered MANY times. The power required to run the fans the size you need is more than the engine can produce. Drag cars run squirrel fans on top of the cylinders to run between runs down the track, but they are not enough to run at all times.
What about a subie conversion?
eyetzr is offline
PostPosted: Wed Feb 07, 2018 9:44 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
Something like this
dcavy
dcavy is offline
PostPosted: Thu Feb 08, 2018 3:59 pm    Post subject: Re: need anyone's help on cooling idea Reply with quote
When this project started I wanted to go more into the direction of a motorcycle engine in the front and run a rear wheel drive set up but didnít have the knowledge, resources, or the finances to build an all out tube chassis. Iíve seen many do the s-10 conversion but everything to me is so bulky then your crammed into the rear of the car just to sit. My other option idea was I saw someone used a v twin before but never could find the resource for an adaptor plate. Donít know if it would have the same cooling issues considering it has air passing around it with no fans at all. I guess my big concern is the heating up at a traffic light. Iíve also brainstormed on one of the ideas mentioned earlier that I could blow 2 600 cfm 8Ē fans over the top of the motor in a custom panel like parcel tray blowing down on the heads and I already have a remote cooler on order. As far as airflow While moving I was thinking naca ducts in the side windows to deliver fresh air in. Any thoughts?
andk5591 is offline
PostPosted: Thu Feb 08, 2018 4:11 pm    Post subject: Re: need anyone's help on cooling idea Reply with quote
Problem with naca ducts is not knowing how the air is actually going to flow...Placement is real important and I know enough about this kind of thing to realize that I don't know much at all.... Confused
eyetzr is offline
PostPosted: Fri Feb 09, 2018 5:02 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
Google Emerson Fittipaldi's double engine beetle.
Mid engine set up, but I think the routing of the air into the engine is an interesting thought. It used to push so much air in the car the top of the doors would start to open up.
Jacks
Jacks is offline
PostPosted: Sun Feb 18, 2018 2:27 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
How about a Puma fan shroud? Several inches lower than type 1 Idea
https://www.thesamba.com/vw/classifieds/search.php?submit=yes&type=text&keywords=puma+fan
Jack Staggs
Actual name
Petfisheric
Petfisheric is offline
PostPosted: Sun Feb 25, 2018 7:04 pm    Post subject: Re: need anyone's help on cooling idea Reply with quote
The Fittipaldi setup had the windshield canted back to make a ram air setup forcing the air through the ducting while moving. I have seen some corvair systems for type1 motors here is a link. https://www.speedsterowners.com/topic/std-vw-cooli...5770318909
eyetzr is offline
PostPosted: Wed Apr 18, 2018 12:34 pm    Post subject: Re: need anyone's help on cooling idea Reply with quote
This may be a bit shiny for you, but....
vaughn bros.
PostPosted: Wed May 16, 2018 6:41 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
From Facebook.
