need anyone's help on cooling idea
Page: Previous  1, 2
VOLKSWAGNUT
Fastest VW Belt Changer
VOLKSWAGNUT is offline
PostPosted: Wed May 16, 2018 7:27 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
vaughn bros. wrote:
^ Am I missing how that would cool Anxious
Maybe is a work in plumbing progress. Laughing
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
vaughn bros.
vaughn bros. is offline
PostPosted: Wed May 16, 2018 8:06 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
I'm with you too. It looks like a work in progress. I'm looking forward to more myself.😀
PostPosted: Wed May 16, 2018 10:18 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
It took me a second to realize the top of that "shroud" was still open so I'd say they are mocking something up.
nshaddox
nshaddox is offline
PostPosted: Thu May 24, 2018 12:00 pm    Post subject: Re: need anyone's help on cooling idea Reply with quote
there was a T bucket at autorama this year in detroit that had all the normal FEAD stuff driven off of a line shaft that ran between the frame rails. Alternator, power steering pump, AC, etc. Got me thinking that maybe you could set up a line shaft running under either cyl bank 1-2 or 3-4, going back to somewhere far enough up front on the frame where you could then run a belt to the normal T1 alternator/fan set up and just do some custom fab work to make a shroud that would dump into something like the pics above show. it makes sense in my head, hopefully it makes sense here too. then maybe you could do some renault dauphine style side scoops to feed air into the quarter panels. that would look pretty cool.
vwuberalles
vwuberalles is offline
PostPosted: Fri May 25, 2018 6:40 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
Toyota Previas have a similar setup. The engine is an inline 4 cylinder laying on it's side under the front seats, but it has a driveshaft coming off the front of the engine to drive the alternator, AC compressor, water pump, etc, which is all under the front hood. The shaft even drives a supercharger on some models!
1973 Superbeetle: 1st car, owned since age 12.
1966 Beetle: My new project. Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040
vwjetboat
vwjetboat is offline
PostPosted: Fri May 25, 2018 7:00 am    Post subject: Re: need anyone's help on cooling idea Reply with quote
have to follow along on this.. love the look..
WD-40
WD-40 is offline
PostPosted: Sun Jun 03, 2018 10:17 pm    Post subject: Re: need anyone's help on cooling idea Reply with quote
I have a couple thoughts, maybe it will help... Question
First, I'll second the idea of a remote oil cooler. Flexible placement + bigger surface area + larger oil quantity are all good things.
Second, since head cooling is the most critical problem, have you considered liquid-cooled heads? Question There have been both production heads (aviation-focused) as well as converted air-cooled heads made by several folks over the years, so there is a reasonable amount of information out there on using water-cooled heads on air-cooled engines.
Third, and I may catch flak for this - I would take the prior discussions on electric cooling with a large grain of salt. Wink Many people have calculated the pressure and air volume of the factory belt-driven fan with the engine at speed/load, and simply worked backwards from that to determine the "required" equivalent power for electric fans to match, and consequently proclaimed it unworkable.
You, however, have a different car and a different set of needs. To start off, you can deduct the amount of air that the factory fan allocates and bleeds off continuously through the heater boxes for interior heat. You also have an open car with many more options for scoops and ducts to collect and direct air while the car is in motion, reducing the amount of electric air required at times the engine is under load. So really, you don't need the electric fans to provide anywhere near that calculated peak volume/pressure... just an electric cooling "assist" to provide the lesser amount required to keep the engine temps in check while stationary. Cool
I also don't believe an "energy debt" is a deal breaker. Say it truly does take more electricity to cool things than the engine makes. So what? Toss in a secondary deep-cycle battery or two to draw from when necessary, and either charge them when at speed (when there is an energy surplus), or plug in at home at the end of the day. Problem solved, not a big deal.
Lastly, you have plenty of options to get creative. Drop the bore size and run thick-wall cylinders with more fin surface area. Decouple or disconnect the generator/alternator when idling to reduce the engine load when full cooling isn't available. Tweak the compression ratio and drop the engine power output to reduce the heat load. Re-route the exhaust so it doesn't hold heat near the heads. Blow air from the bottom up to leverage convection. Pull the rockers on two cylinders and swap a smaller carb on the manifold to convert the engine into a stealthy two-cylinder. Or heck, you could even install a water tank in the car and using fine misting nozzles to atomize small amounts of water vapor into the cooling air to increase its heat transfer and heat carrying capacity.
Think outside the envelope, come up with some ideas, put some thermocouples on key places, and experiment. Cool
"The new Volkswagen 1303. We've made so many improvements, they're beginning to show."
Page: Previous  1, 2
Page 2 of 2
