andybla Samba Member
Posted: Wed Feb 28, 2018 12:13 pm Post subject: Re: square 66 |
No need fot that, Tram; Thx guys!
Did not do much last weekend as it is freezing here up to -6°C, that would be -43°F... freezing my toes off, even with two pair of socks
Have scanned the templates and working to put it all together, remember, this is merely a guidance as i just created these as how i felt was best to suit my situation |
Posted: Wed Feb 28, 2018 12:39 pm Post subject: Re: square 66 |
first one
Note: templates are scanned in A3 format, sizes in centimeter (CM) or millimeter (MM), i have live measured the template so when you should print it, these measurements should be the same when you measure this. These measurements were made with a thick marker so the side of the marker where the arrow is pointing is the measurement point...
Also note: The "raw" shapes i have, are bent in a metal workshop, really doesn't cost much if you have a good drawing of what you want, all metal i'm letting produced is 1mm thick
Info
http://s000.tinyupload.com/?file_id=06776363229717355495
Template
http://s000.tinyupload.com/?file_id=07492968631968633507 |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
Posted: Wed Feb 28, 2018 12:59 pm Post subject: Re: square 66 |
Wow. Great work! Your metal working skills are remarkable! A great inspiration to get others motivated for sure. Glad to be following your work. _________________ Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807 |
Posted: Sat Mar 03, 2018 2:31 pm Post subject: Re: square 66 |
The backplate bend, outer side + actual shape, i have pleated this because they were to large for the scanner, just print them and stick them together with some tape
A1 left meets A2 left
B1 right meets B2 right
You just place the straight side against the notch and start at the outer point of your piece of metal
A1 right is your start point
B1 left is your start point
Side A is inner, B is outer
I started with a piece of metal
L 65 cm
W 13,5 cm
In the middle a notch
L+R 5,5 cm
notch bottom W 2,5 cm
notch top W 1,5 cm
notch depth 0,75 cm
After shaping you need to straigthen the start and end of your piece because you obviously have still that notch there
At the bottom this is 2 cm
At the top see line on picture and B2, continue that line
http://s000.tinyupload.com/?file_id=21124447426547448943
http://s000.tinyupload.com/?file_id=07314111069342365915
A1
http://s000.tinyupload.com/?file_id=38421942561834860599
A2
http://s000.tinyupload.com/?file_id=99551327468147660999
B1
http://s000.tinyupload.com/?file_id=39818426969464152586
B2
http://s000.tinyupload.com/?file_id=72613935837362986719 |
Posted: Sat Mar 03, 2018 2:44 pm Post subject: Re: square 66 |
Air shape 1, print this out and place against current air shape to get an idea, this template is not complete because i had my old one to look at and measure for further help
left side should be 0,5 cm extra, right side, see info here above, i would advise to cut the 8 blue lines
1 on the left diagonal
2 on the left vertical
2 on the right horizontal
3 on the right, the sort of triangle 1 horizontal and 2 diagonal
Note: i cut off the notch at the right later on as it wasn't needed eg less work
http://s000.tinyupload.com/?file_id=38308850726022070487
Air shape 2 i just had a straight Z piece shape
L 32 cm
W 5,5 cm
Z shape 2 times 1,6 cm
not much of a template, just use the old one as a template and measure |
Posted: Sat Mar 03, 2018 2:48 pm Post subject: Re: square 66 |
Those were all i have.
Questions just ask |
Posted: Sun Mar 04, 2018 2:13 pm Post subject: Re: square 66 |
Got a bit tired of the passenger side, so i did some stuff for driver side this weekend, enjoy
Made the inner corner + exhaust opening, the inner metal has some surface rust, not bad after 52 years
Don't mind the messy cuttings, still figuring out how to proceed
exhaust openings L + R almost ready, looking good me thinks
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Sun Mar 04, 2018 3:13 pm Post subject: Re: square 66 |
You’re doing awesome on your build. I like your detailed so don’t let up as you’ll have that side put back together in no time. I really like how you handled the rear apron as well. Looking forward to your next update and keep the exceptional work! _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Mon Mar 05, 2018 12:46 pm Post subject: Re: square 66 |
andybla wrote: |
eekend, enjoy
Nice job on the dual exhaust outlet tin.
I really like that you're spending the extra time on the details. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Mar 05, 2018 1:50 pm Post subject: Re: square 66 |
Something like my Harley-Davidson mufflers bolted to a stock exhaust would fit good on your car. They are higher than a header exhaust & fairly quiet.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Mar 06, 2018 4:51 am Post subject: Re: square 66 |
Hi guys, thanks again for the good feedback
@Mike, looking good , yes that is the idea, putting a dual exhaust, engine is allready done, stock engine but a bit more bling, good enough for now. Mine has a vintage speed exhaust. |
Posted: Fri Mar 30, 2018 12:26 pm Post subject: Re: square 66 |
And so the story continues
Spring has started, days are getting a tiny bit warmer
So eventually i decided to go all the way like the other side, but first of all needed some extra solidity so redid the corner piece, and also the inner support was gone so restored that one too...
After that i drilled out the holes and removed the sheet metal after taking carefull measurements
Next i made new sheet metal comparing the old
Next up, tighten and weld everything together |
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Posted: Sat Mar 31, 2018 12:57 pm Post subject: Re: square 66 |
This thread is so much fun to watch and follow. Great work!!! I keep going back and looking at the pix you've posted of the work already done. I just bought a welder and i'm nervous about welding in some floor sections and here you are literally rebuilding a car, HAHAHAHA. _________________ 1971 Squareback, fully bagged, 1776.
Build thread here.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
MonT3 Samba Member
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Sat Mar 31, 2018 10:52 pm Post subject: Re: square 66 |
WOW!
How did I miss this one?
Excellent.. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Mon Apr 02, 2018 6:20 am Post subject: Re: square 66 |
Thx again for the positibe feedback, tips are always welcome, i'm willing to learn from mistakes
@oxsign: what i can recommend is using 0,6mm wire, i think it's 0,02inch? With 0,8mm there is more current flowing, creating holes faster.
And the thing i do when doing spotwelds, but without a spot welder, i drill one side in the spot weld with a larger diameter bore, creating a funnel, just enough to not drill through. After that i just filll it up, you will end with a larger spot but backside will be nice and clean if done right
good luck |
Posted: Wed May 02, 2018 12:40 am Post subject: Re: square 66 |
Hi everyone, i haven't got any much time to do this project... every free half hour i got in my life, i try to do something
The plan was to finish this, again, at august for le bug show in Spa, but not gonna make it, again... What makes working on this a pita But am looking into something temporarily that drives and brakes
At the moment, i'm welding together the sill assembly...
bkeith85 Samba Member
Joined: December 21, 2013 Posts: 149 Location: United States
Posted: Wed May 02, 2018 11:27 am Post subject: Re: square 66 |
Geez. I was over here with a big head because I made a new cargo floor for mine.
But this is impressive. Nice work, man. |
