williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Thu Feb 08, 2018 10:04 am Post subject: Re: engine won't stop. Throttle valve? |
asiab3 wrote: |
Wildthings wrote: |
New S-boots (the big shoddily repaired S shaped hose) are available if yours take the same as used in later years. |
I don't think the '74-only S-boots are available. Apparently the PO didn't either…
Robbie |
if it's just not as tall- will it work with early air cleaner??? _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
vacilador Samba Member
Joined: May 05, 2015 Posts: 21 Location: portland, or
Posted: Fri Feb 09, 2018 10:28 am Post subject: Re: engine won't stop. Throttle valve? |
Back on the road, now sometimes after driving a bit, when I'm coasting to stop the engine depowers below an ideal idle....
the engine shutters, rumbles and wants to stall out.
I don't allow it to stall, and keep a little bit of my foot on the gas pedal to keep the engine power up, even while braking. (The indicator lights on the dash flash a bit at the lowest engine power.)
To fix this, I assume the idle could be adjusted (no idea how) or
this is related to adjusting the bolt on the "throttle kicker" / deceleration valve. (some idea how to do that)
Thoughts? _________________ 1974 VW Bay Window Automatic Fuel Injected
2002 VW Passat V6 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12688 Location: on a bike ride somewhere
Posted: Fri Feb 09, 2018 11:15 am Post subject: Re: engine won't stop. Throttle valve? |
The engine should idle down just fine without the mechanical deceleration valve, or "kicker" valve. (That's a new term for me!)
How judiciously have you checked for vacuum leaks?
Have you ever messed with the CO (mixture) settings on your AFM?
www.airschooled.com |
Posted: Fri Feb 09, 2018 11:56 am Post subject: Re: engine won't stop. Throttle valve? |
I am wondering if this is a 411/412 engine that was transplanted into a Federal model verses it being a California model. Additional pictures of the engine might help. Do the various sticker and tags on the rig say its a Federal model or a California model? |
Posted: Fri Feb 09, 2018 1:37 pm Post subject: Re: engine won't stop. Throttle valve? |
Wildthings wrote: |
Quite possible.....but that throttle kicker part "was" used on some automatic buses. I was surprised to find that out.
You can see the adjusting instructions and pictures in the Haynes #226 Transporter manual 1972-1979.
It is in the supplement section, chapter 13, page 218, 2nd to the last parargraph. They call it "the idle speed regulator".
It has a very specific adjustment and one of the main tell-tale symptoms they list that indicate it is put of adjustment is if the idle speed drops more than 200 rpm when a gear is selected from neutral or park. To me.....that text is vague.
There is a little more detail on adjusting this part in the 411/412 manual....but the specs for idle and pushrod gap are different.
Both texts note that throttle cable and TB plate positively closed and standard idle should be adjusted carefully first. Ray |
Posted: Sat Feb 24, 2018 6:28 pm Post subject: Re: engine won't stop. Throttle valve? (Updated: engine stalls) |
As of this morning, now the engine consistently stalls when I take my foot off the gas pedal (whether in park, neutral or drive) the engine depowers, shutters, and stalls.
If I keep RPM's up, the bus can drive but it's risky. (One foot on the gas, one on the brake on the way home from Lowe's earlier today)
Attaching photos of the engine and the placard on the door frame - evidently the bus is a Federal Model.
2002 VW Passat V6 |
Posted: Wed Feb 28, 2018 7:39 pm Post subject: Re: engine won't stop. Throttle valve? |
Thank you guys for all the feedback, appreciate all the guidance. I love learning about this car and working on it!
This afternoon, I adjusted the idle speed regulator plunger. The Haynes manual says the plunger should be set to between 0.5mm and 1.0mm clearance at the intersection of the end of the plunger and the throttle valve shaft.
This sort of works - the idle is now higher than it was and the engine doesn't stall, which does resolve the issue.
There may still be a vacuum issue, a mixture issue perhaps. If there's an easy or systematic way to approach evaluating those systems, I'm all ears. _________________ 1974 VW Bay Window Automatic Fuel Injected
2002 VW Passat V6 |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Wed Feb 28, 2018 8:49 pm Post subject: Re: engine won't stop. Throttle valve? |
Here's the easiest way I've found to track down vacuum leaks...
https://www.amazon.com/AutoLine-Pro-Automotive-Dia...ke+machine
It requires an air compressor, but will make even the smallest leak easily detected. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
