Exhaust/Heater Box holes
Wildthings
Wildthings is offline
PostPosted: Wed Feb 07, 2018 12:07 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Goach2 wrote:
Sorry to hear that Hoody, I'm sure it was wise advice you were trying to share Wink
Wildthings, I've read that my ports are square where earlier are round, does this mean new manifolds as well? ie everything after the heads?
edit: sorry I guess it was confirmed to be oval not square ports above...
Only the '79 engines used the square ports, so if you engine matches your '77 model year then you need oval port exhausts. However with a bit of butcher work the square port heat exchangers can be made to work. FWIW, I have been able to come up with square port heat exchangers that were in very good shape for little more than pocket change as there is little demand for them.
orwell84
orwell84 is offline
PostPosted: Wed Feb 07, 2018 12:13 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
The conversion kit you are referencing refers to just the engine tin. The heater boxes with the square ports are the important part, then you have a choice of mufflers. Many have used the one on the right:
https://www.justkampers.com.au/vw-t2-bay-window-parts/t2-bay-exhaust-parts.html
It is widely available and there is also a stainless version. Both systems pictured bolt directly to the heater boxes. I have used both but prefer the quiet pack version.
Goach2
Goach2 is offline
PostPosted: Wed Feb 07, 2018 12:57 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
I'm going to go with oval ports, as the engine is a '77.
So to recap, '72-'74 exchangers, tin swap kit from GS and then the full exhaust setup from those same years.
1977 FI Westfalia
Wildthings
PostPosted: Wed Feb 07, 2018 1:15 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
You don't need to big squarish hole that is in the lower right front 72-74 tin. I think the tin for either a FI'd 411/412 or a '79 bus would be better for your application. A phone call to Scott should get you what you want. Note, that there have been a lot of complaints about Scott over the past few years. You might want to choose Busted Bus, Avery's or some other supplier if you don't want endless aggravation.
THall
THall is offline
PostPosted: Wed Feb 07, 2018 2:06 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Yep, plus it's currently listed as out of stock. I suspect Scott sources that used tin from the same places that Wildthings lists.
The kit also says, "Good used parts from the southern USA." So, maybe add Blair & Sons to the list. I've gotten many good used parts from Jan over the years.
'78 Westy - 2.0 FI
Goach2
Goach2 is offline
Yes, I've already received a response from Scott, that's the list of items I've referred to. I will use GS again, as my last order went fairly well. Communication could be better, but I don't think he's in the business of ripping people off.
1977 FI Westfalia
lil-jinx
lil-jinx is offline
PostPosted: Wed Feb 07, 2018 3:30 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
those heat exchangers may be worth a look,
https://www.kijiji.ca/v-other-auto-parts-and-acces...nFlag=true
1968 Dune Buggy
1974 parts bus
Wildthings
PostPosted: Wed Feb 07, 2018 4:15 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Those aren't bus heat exchangers.
Goach2
Goach2 is offline
PostPosted: Wed Feb 07, 2018 4:27 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Plus, aren't these for square ports?
1977 FI Westfalia
JimmieH Premium Member
JimmieH is offline
PostPosted: Wed Feb 07, 2018 5:20 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Your pictures show the 75-78 exhuast system which requires an oval port at the heads. If you have to replace most of your system a simpler solution may be to convert to the 72-74 set up as already suggested. I did that on my '78. The link to Samba Classifieds (BusOK) shows the differnt types of heat exchangers the first is 72-74 and shows the oval exaust port, 2nd is Vanagon with square port, and 3rd is '79 bus with square port. You would need the 1st one for the driver's side and the correct passenger's side would look like the '79 bus but with oval exhaust ports. The Bus Depot link show a muffler that would attach to both heat exchangers and eliminate the elbows and crossover pipe.
https://www.thesamba.com/vw/classifieds/detail.php?id=2108629[url]
http://www.busdepot.com/071251053ek[/url]
[img][/img]
1978 Transporter 2.0 FI
JimmieH is offline
PostPosted: Wed Feb 07, 2018 5:27 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Sorry, don't know why the Bus Depot link doesn't work. The part # is 071251053EK
Wildthings
PostPosted: Wed Feb 07, 2018 6:53 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
I believe they are federal '80-83 Vanagon heat exchangers. The Vanagons use the same heads as the '79 Bays.
Goach2
Goach2 is offline
PostPosted: Wed Feb 07, 2018 7:31 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Thanks JimmieH, looks like I'll be following in your footsteps Wink Any chance you documented any of your work?
1977 FI Westfalia
Goach2
Goach2 is offline
PostPosted: Thu Feb 08, 2018 11:35 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Also, my EGR filter is shot. How does this earlier setup change the EGR for this model year?
1977 FI Westfalia
JimmieH is offline
PostPosted: Thu Feb 08, 2018 1:29 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
My muffler has an EGR port. It requires a '79-83 EGR filter though. The filter is missing in that photo. I got that muffler from Bus Depot over 10 years ago. It seems like they don't have one with an EGR port listed any more. You could call them. Unless you need an EGR for inspection you could save a lot of time & money just going without it. It took me several years to find all the parts to make a '79 EGR.
Goach2
Goach2 is offline
PostPosted: Thu Feb 08, 2018 1:34 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
I'm assuming one will be required to pass inspection in Ontario, but I will ask around.
For the Heat Exchangers, I've been looking at a number of private sales, but find it difficult to tell which are the correct '72-'74 ones I need. Is there something on them that will make identification a sure thing?
1977 FI Westfalia
Wildthings
PostPosted: Thu Feb 08, 2018 3:36 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
These are what you are looking for:
orwell84
orwell84 is offline
PostPosted: Thu Feb 08, 2018 5:10 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Sorry to have misled you about the square ports. I mistakenly thought that these were used on all late bays with that style heat exchanger.
Goach2
Goach2 is offline
PostPosted: Thu Feb 08, 2018 6:59 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
All good, that's why we're here.
Thanks Wildthing, I will use these as reference.
1977 FI Westfalia
Goach2
Goach2 is offline
PostPosted: Fri Feb 09, 2018 6:13 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
So while the hunt is on for parts, I have a question about installation:
For someone with access to generic tools (regular floor jack, no eng stand, etc...) is there a benefit in dropping the engine to do the exhaust transition? Keep in mind that I have yet to do one. I'm afraid I won't be able to stop once I start stripping it down and I do have a time frame to meet!
1977 FI Westfalia
Page 2 of 4
