JaimeH Samba Member
Joined: April 24, 2012 Posts: 265 Location: Canterbury, NH
Posted: Tue Feb 13, 2018 3:06 pm Post subject: Re: Exhaust/Heater Box holes |
That is an EGR pipe. It was used on some '74 and possibly earlier models. It would only connect to a late model EGR with a custom fabricated pipe. Seems like there might be more heat from a connection that close to the head. I don't know how this would affect the diaphram in a late model EGR valve. _________________ 1978 Transporter 2.0 FI, BA6
Special Thanks to Razor's Customs, Boscawen, NH |
Goach2 Samba Member
Joined: November 20, 2017 Posts: 518 Location: Niagara Region, Ontario
Posted: Tue Feb 13, 2018 6:42 pm Post subject: Re: Exhaust/Heater Box holes |
Does and adapter exist to go from the '77 EGR to this one? _________________ 1977 FI Westfalia |
JaimeH Samba Member
Posted: Wed Feb 14, 2018 4:38 am Post subject: Re: Exhaust/Heater Box holes |
No. You would have to make one. _________________ 1978 Transporter 2.0 FI, BA6
Goach2 Samba Member
Posted: Wed Feb 14, 2018 6:05 am Post subject: Re: Exhaust/Heater Box holes |
JimmieH - Did you eliminate yours? _________________ 1977 FI Westfalia |
Goach2 Samba Member
Posted: Wed Feb 14, 2018 8:28 am Post subject: Re: Exhaust/Heater Box holes |
Looking at the tins I need to replace to swap the exhaust, I can't seem to find these two in the manual:
Can anyone confirm where these go? There's a reference to having to remove the heads to put some in, in this forum:
https://www.thesamba.com/vw/forum/viewtopic.php?t=375847
I hope that's not the case! _________________ 1977 FI Westfalia |
Posted: Wed Feb 14, 2018 10:27 am Post subject: Re: Exhaust/Heater Box holes |
I the first tin you show is the lower front left tin for a 75-78 FI'd rig, while the second tin you show is the lower front right tin for a 72-74 carbureted rig. For the lower front right tin, you can get the equivalent tin for a FI'd 411/412 (and maybe a '79) which will not have the hole in it.
Either of these tins can be easily removed and replaced with the engine in place. |
Goach2 Samba Member
Posted: Wed Feb 14, 2018 11:15 am Post subject: Re: Exhaust/Heater Box holes |
So it sounds like my '77 might already have the first tin on it? These pics are from the kit that GS offers to convert late bays to the '72-'74 ones. For the second, I'm assuming the hole isn't necessary then?
Any chance anyone has seen a pic or diagram of these in place? I can't seem to find them anywhere. you'd think they would be in the manual... _________________ 1977 FI Westfalia |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Wed Feb 14, 2018 11:51 am Post subject: Re: Exhaust/Heater Box holes |
The lower front left tin shown may be correct, not easy to tell with the stamp over it. This is another view.
Goach2 Samba Member
Posted: Wed Feb 14, 2018 1:44 pm Post subject: Re: Exhaust/Heater Box holes |
Well, I just picked these up. I'll have to circle-back once I get them all cleaned up and ready to install. On that note, do tins require high-heat paint? Or will Rustoleum suffice? _________________ 1977 FI Westfalia |
Posted: Wed Feb 14, 2018 1:52 pm Post subject: Re: Exhaust/Heater Box holes |
Rustoleum seems to work. I had a set powder coated but have never gone through the hassle of installing them. Look nice in their box full of tissue paper and bubble wrap though. |
Goach2 Samba Member
Posted: Fri Feb 16, 2018 8:55 am Post subject: Re: Exhaust/Heater Box holes |
One more piece of tin to remove. Is it just me, or are these Phillip's-head screws the worst? I've already drilled out 4 and have one more to go... _________________ 1977 FI Westfalia |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Fri Feb 16, 2018 10:25 am Post subject: Re: Exhaust/Heater Box holes |
Goach2 wrote: |
Is it just me, or are these Phillip's-head screws the worst? |
It's just you.
This is your friend.
https://i.redditmedia.com/rHqPgkzgEntt_yhkdyzGAJSQ...282ddfa27b _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Posted: Fri Feb 16, 2018 10:44 am Post subject: Re: Exhaust/Heater Box holes |
I have replaced many of the screws in my tin with washer head hex screws, which makes removal of a rusty screw much easier. You can even get washer head hex screws which will also accept a Phillips screwdriver. |
Goach2 Samba Member
Posted: Mon Feb 26, 2018 9:22 am Post subject: Re: Exhaust/Heater Box holes |
Making good progress. One thing that was recently suggested to me, which I hadn't heard before, was that the copper gaskets for the exhaust ports have to be heat-treated before installation.
Is everyone in agreement on this?
Thanks! _________________ 1977 FI Westfalia |
Posted: Mon Feb 26, 2018 10:58 am Post subject: Re: Exhaust/Heater Box holes |
Yes. Annealed!
Read more here:
http://www.ratwell.com/technical/Exhaust.html _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
Hoody Samba Member
Posted: Mon Feb 26, 2018 10:42 pm Post subject: Re: Exhaust/Heater Box holes |
Are Phillips head screws the worst? Well you need to consider they have been in there for 40 years, you have dissimilar metals, and the heads are probably rusted. I went with Ratwell’s suggestion of black anodized stainless Phillips head screws. The part number is on his website. Finding the correct anodized stainless washer was a chore. Had to buy a box of 100. So if you go this route let me know. I have extras. Stainless reacts less than regular steel does with aluminum. I anti-seized every screw for future removal. Most people use the cheese head screws. But they were not my choice. Before you attempt to secure the heater boxes you should check out Clatter’s “cheap junk” engine build. Around the middle of it he addresses a very important aspect of the sealing process. He’s the only person that I have seen document this. And it’s extremely important. However you choose to make the tops of the pipes flat...you will be taking off material. You need to then remove material from the mounting flanges. Get a micrometer and make sure that that the distance is equal. Other wise they will not seal properly. And mock it up several times to make sure. Hope this helps. |
Goach2 Samba Member
Posted: Wed Feb 28, 2018 11:17 am Post subject: Re: Exhaust/Heater Box holes |
Thanks Hoody/BUSBOSS,
So much for bolt-on and go! _________________ 1977 FI Westfalia |
