ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Wed Feb 07, 2018 8:42 pm Post subject: 1st engine drop & doing some maintenance. |
I'll be removing the engine from my 77 westy for the first time due to an oil leak that appeared after my trip home from death valley.
https://www.thesamba.com/vw/forum/viewtopic.php?t=652578&highlight=
In a previous thread the consensus seemed to point to a leaking main shaft seal. I'll be relying on ratwells guide for the actual step by step process.
http://www.ratwell.com/technical/EngineRemoval.html
He has a list of tools (I still need to get a fuel line clamp) and I've got everything on the list including an atv jack.
On the advice of sgkent I plan on tackling a few other bits while the engine and tranny are out such as, replacing the clutch, pilot bearing, input shaft seal, and flywheel o-ring and shifter bearings (?).
This is what I ordered to accomplish all of that (part #'s may be busdepot #'s):
Complete Clutch Kit - Upgraded Quality 028141999
Manual Transmission Main Input Shaft Seal 113311113A
Engine Crankshaft Seal 029105245
Flywheel Bolt N90226801
Shift Bushing Replacement Kit 211711211
Flywheel O-Ring 021105279
Do I have all the necessary parts? What other items might I need, oils, lube, nuts & bolts?
For all intents and purposes, I am a noob. I can follow directions but that in no way means I possess what you guys might call auto mechanic common sense. So if you have any advice or things I have to be aware of please let me know (for example, there may be things that go on a certain way like the shaft seal, or taken off in a certain manner).
My bus was running great and I really just don't want to screw this up.
Thank you! _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
my59 Samba Member
Joined: August 13, 2003 Posts: 3789 Location: connecting the dots
Posted: Thu Feb 08, 2018 4:17 am Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
I made a fuel line clamp by taking a 4" long piece of broomstick, drilled two holes through it, the holes were about 3" apart and then split the piece of broomstick in half lengthwise. Took a couple of bolts, nuts and washers, and put the curved surfaces of the stick together and thread the bolts thru the holes, secure with nuts. Tighten as required around hose.
You might consider adding a gas rated shut off valve right before your fuel filter and on the return line, makes changing the filter a cleaner job. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Thu Feb 08, 2018 5:09 am Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
I found that taking the engine and trans out in a chunk was way easier to re-install and gave you a look at the shift seal and shift rod bushings-was just CV joints and wires away from the original attempt.
That trans jack is golden- made the job so much easier. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Thu Feb 08, 2018 5:35 am Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
ivwshane wrote: |
Thank you! |
I see you missed the flywheel gasket
http://www.busdepot.com/021105275 _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
riverside66 Samba Member
Joined: June 04, 2008 Posts: 218 Location: Sparta, NC
Posted: Thu Feb 08, 2018 8:04 am Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
Might as well eyeball your starter bushing. If you need a new one, it's P/N: 113-301-155 _________________ 1977 Standard Beetle -Sold-
1979 Transporter - "Wheatbread" -Sold- |
Posted: Thu Feb 08, 2018 9:28 am Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
riverside66 wrote: |
Might as well eyeball your starter bushing. If you need a new one, it's P/N: 113-301-155 |
Absolutely! Wicked cheap part and super easy to do when its out _________________ Rebuild your own FI Harness..My Harness
SGKent Samba Member
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Thu Feb 08, 2018 12:15 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
Is your bus an automatic? I am guessing not, since you have a clutch.
This Flywheel Bolt N90226801 is for automatics.
What you want is 5 of these:
http://www.busdepot.com/n0143351
and one of the special 5-hole washers that goes with those,
and the pilot bearing and the felt washer that goes with it. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Thu Feb 08, 2018 12:18 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
Awesome! That's what I'm talking about! Thanks guys! _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Thu Feb 08, 2018 1:42 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
Shane you should drop by and talk with me about what you want to do. Park on the street if you are dumping oil
If you and a friend can get it out and haul it over in a pickup we can put a cherry picker on it, set it on some blocks, or lift it onto an engine stand to work on it. I am hesitant to make suggestions as to parts because sometimes all someone needs is sand paper, a couple new seals, and a new disk. Other times you may need some shims, new felt ring, pilot bearing, new pushrod tube seals, new starter bearing bushing, new pressure plate. If the flywheel is glazed it has to go to the machine shop. If it has heat and stress cracks it has to be replaced. You just won't know exactly what you need until you get it apart. Also if you haven't been in to the trans, now is a good time to change the trans gear lube, nose cone seal, input shaft seal and also add a metal plate to hold the mainshaft bearing in. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Feb 08, 2018 2:17 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
SGKent wrote: |
If you and a friend can get it out and haul it over in a pickup we can put a cherry picker on it, set it on some blocks, or lift it onto an engine stand to work on it. I am hesitant to make suggestions as to parts because sometimes all someone needs is sand paper, a couple new seals, and a new disk. Other times you may need some shims, new felt ring, pilot bearing, new pushrod tube seals, new starter bearing bushing, new pressure plate. If the flywheel is glazed it has to go to the machine shop. If it has heat and stress cracks it has to be replaced. You just won't know exactly what you need until you get it apart. Also if you haven't been in to the trans, now is a good time to change the trans gear lube, nose cone seal, input shaft seal and also add a metal plate to hold the mainshaft bearing in. |
Thanks for the offer but I'm hesitant to drive it that far. When it comes to ordering stuff I may not need, I'd rather have it than not especially if we are talking about parts that are under $20. I ordered a new clutch because I'd rather know what's in my bus and when it was changed than to wonder what I have and figuring out when it needs to be replaced. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Thu Feb 08, 2018 2:19 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
jtauxe wrote: |
and the pilot bearing and the felt washer that goes with it. |
Damn! Thanks for the heads up! I would have felt so defeated had I got that far and not have had the right bolts.
Which pilot bearing do I need?
http://www.busdepot.com/catalogsearch/result/?q=Pi...sort_order
Is this the felt washer you are referring to?
http://www.busdepot.com/111105311 _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Thu Feb 08, 2018 3:33 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
ivwshane wrote: |
SGKent wrote: |
Thanks for the offer but I'm hesitant to drive it that far. When it comes to ordering stuff I may not need, I'd rather have it than not especially if we are talking about parts that are under $20. I ordered a new clutch because I'd rather know what's in my bus and when it was changed than to wonder what I have and figuring out when it needs to be replaced. |
That’s a hell of an offer to pass up. _________________ Rebuild your own FI Harness..My Harness
my59 Samba Member
Posted: Thu Feb 08, 2018 4:41 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
aerosurfer wrote: |
ivwshane wrote: |
SGKent wrote: |
Shane you should drop by and talk with me about what you want to do. Park on the street if you are dumping oil :)
That’s a hell of an offer to pass up. |
I'd pull the engine and transmission as a unit and rent a truck to take that up. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Thu Feb 08, 2018 4:54 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
my59 wrote: |
aerosurfer wrote: |
ivwshane wrote: |
SGKent wrote: |
I'd pull the engine and transmission as a unit and rent a truck to take that up. |
I'd buy AAA, wait out the no grace period and then tow it over filled with beer and pupus.
Aloha
tp |
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
Posted: Thu Feb 08, 2018 7:40 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
When replacing the pilot bearing, do not forget to replace the felt washer and it’s spacer ring that go into the flywheel hole or you may be pulling the engine again to replace the pilot bearing that has been ruined by clutch dust.
The voice of experience has spoken. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Fri Feb 09, 2018 11:12 am Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
Slide some fuel line on the jaws of needle nosed locking pliers as a fuel line clamp. But don't over tighten them. |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun Feb 11, 2018 3:52 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
ToolBox wrote: |
I’ve used these for years. I like them because you can apply them with one hand in if you can’t get 2 hands into the work space. https://www.harborfreight.com/3-piece-line-clamp-set-97578.html _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Thu Mar 15, 2018 5:33 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
So I started the engine drop today but due to weather I won't be able to finish.
Reading ratwells guide I do have a question which I hope you guys can answer. I plan on pulling both the engine and transmission, in ratwells guide he talks about doing both with and without the transmission, however in his pictures I only see him pulling the engine and transmission separately.
Will the engine and transmission be coming out at the same time as a single unit? If so how and where should I be supporting the whole thing? I'll be using an atv jack.
A little off topic. In his guide ratwell recommend replacing the according heater tubes with some silicone ones from a vanogan, does anyone have a link to a source for these? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51117 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Mar 15, 2018 6:04 pm Post subject: Re: First engine drop & doing some other maintenance, help welcome! |
Drop it as a unit, it's much less of a battle, put the jack at the front of the sump with a little bit of it on the engine/trans seam.
Ratwell is referring to the silicone sleeves where the accordian tubes connect to the body and heater valves, your bus likely has crumbly asbestos ones now. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
