scooter trash Samba Member
Joined: June 22, 2015 Posts: 23 Location: North Georgia
Posted: Thu Feb 08, 2018 6:06 pm Post subject: Mounting Dune Buggy Body |
I have been rebuilding a Manx replica buggy over the last 2 1/2 years. I am at the stage of remounting the body. The previous build was pretty bad. This body does not sit flat on the mounting rails. the inside edge is raised. My thoughts have been to try to fabricate a mounting plate out of some angle. The plate would allow me to sandwich the fiberglass between it and the pan rails. The curve at the front of the body will take a little ingenuity. Any thoughts/experience with this scenario? |
cudabear Samba Member
Joined: January 27, 2012 Posts: 65 Location: Lk Mary FL
Posted: Fri Feb 09, 2018 1:45 pm Post subject: Re: Mounting Dune Buggy Body |
Start bolting it down, slowly a little at a time. use a heat gun just warming the flange a little at a time working your way around |
Posted: Fri Feb 09, 2018 1:48 pm Post subject: Re: Mounting Dune Buggy Body |
Also use the vw body to pan seal kit Think i used the EMPI kit worked out good and leaves a finished look |
Posted: Fri Feb 09, 2018 1:53 pm Post subject: Re: Mounting Dune Buggy Body |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Fri Feb 09, 2018 9:48 pm Post subject: Re: Mounting Dune Buggy Body |
Yes. What cudabear said. Fiberglass is very forgiving. You can close up huge gaps by just sneaking it down bit by bit. It may take a few days and heat does help. The plate to spread the load is a good idea as well.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
