bmarkle Samba Member
Posted: Fri Mar 02, 2018 3:26 pm Post subject: Re: 15x8+ 5x205 5 spoke wheels |
I purchased torq thrust D wheels. I am using adapters. There was a me tion that older than 67 adapters are the only choice. I have seen blank drums...I presume to be drilled as I like. I live in so cal, where do you recommend to get them drilled?
Thanks for the advice. I am looking forward to my new wheels.
Cheers |
chickengeorge Samba Member
Joined: August 18, 2004 Posts: 5634 Location: Spokompton Warshington
Posted: Thu Feb 15, 2018 12:56 pm Post subject: Re: 15x8+ 5x205 5 spoke wheels |
bmarkle wrote: |
Thank you very much. I like the wheels and I will be ordering some. What is your preference between adapters vs drilled drums? |
Drums for sure. You might be stuck with adapters though. If you're working on a 66 or 67, I think you can get drums with Chevy or Ford pattern. Older than that and you'll probably have to do adapters. |
Posted: Wed Feb 14, 2018 2:05 pm Post subject: Re: 15x8+ 5x205 5 spoke wheels |
Posted: Sun Feb 11, 2018 9:12 am Post subject: Re: 15x8+ 5x205 5 spoke wheels |
If you're not against an adapter or even using drilled drums (almost as cheap), then you could purchase any torque thrust look alike. I run Coys C5 wheels.
Posted: Sat Feb 10, 2018 9:37 am Post subject: 15x8+ 5x205 5 spoke wheels |
I really like the look of the empi 5 spoke wheels however I am looking for 15x8 and a smaller 15" matching rim for my wannabe Manx buggy. I have seen the DWT rims and the empi star but was hoping to find a wheel closer to the 5 spoke.
Any advice on where to look would be appreciated. Thanks in advance.
My bolt pattern is 5x205...I am not entirely against using an adapter plate. |
