tencentlife Samba Member
Joined: May 02, 2006 Posts: 10067 Location: Abiquiu, NM, USA
Posted: Sat Feb 10, 2018 11:28 am Post subject: Transaxle tip: inspect your ring gear thru drain hole |
Transaxle tip: inspect your ring gear thru the drain hole
I was just servicing my 100k mi. on rebuild Syncro transaxle, and mildly concerned about hearing a very faint R&P whine on overrun recently. I found I had let my oil level get low due to leaky side seals, so I figured that was probably the main reason, but I realised something when I had it drained: You can do a good visual inspection of the ring gear thru the drain hole.
If all the ring gear teeth are free of chips and show even wear patterns, it's a pretty good bet the pinion gear and bearing are also in good shape. All the teeth on my ring gear looked really nice, wear patterns high on the tooth flanks the full length of each, and the same all the way around. No chips at all and not even the slightest pitting, so I feel good about the condition of mine.
If you see any chipped or pitted teeth you can be pretty sure the pinion is also similarly damaged.
If you have a Syncro with diff lock you can rotate the ring gear with a rear wheel. I have an on-board air compressor and use positive air pressure for my diff lock servo (you'll be hearing more about this soon) so I just ran my compressor to maintain the lock. A standard Syncro with a tight vac system should be able to hold it locked without idling the engine.
If no diff lock then you'd need to engage a gear and turn the engine crankshaft to turn the ring gear. An assistant to do so, or careful use of a remote starter switch, would make this job easier.
It's always nice to find a way you can gather some useful data on a major system so easily. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12103 Location: Port Manteau
Posted: Sat Feb 10, 2018 11:37 am Post subject: Re: Transaxle tip: inspect your ring gear thru drain hole |
I imagine you might be able to snake an inspection camera up there to see the R&P mesh, but that probably precludes using the starter to turn over the assembly, for obvious reasons. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Sat Feb 10, 2018 12:02 pm Post subject: Re: Transaxle tip: inspect your ring gear thru drain hole |
A couple comments:
It's almost always true that wear will show up first on the pinion, which sees 4X the wear of the ring gear. Quite often, a toasted pinion has a ring gear that looks OK.
It's quite difficult to closely inspect an oil-coated gear tooth. The magnet (or filter) is still our best indicator of R&P wear. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4715 Location: Bemidji, MN
Posted: Sat Feb 10, 2018 7:44 pm Post subject: Re: Transaxle tip: inspect your ring gear thru drain hole |
throw some sawdust in the filler hole and that whine will quiet down right nice...
my Dad talked about that being a ploy for selling high mile cars in the 1950s, but i've never seen evidence of it myself. i have however seen the engine filled with essentially pure STP to stop it smoking long enough to get out the driveway.
-dan |
E1 Samba Member
Joined: January 21, 2013 Posts: 6369 Location: Westfalia, Earth
Posted: Sat Feb 10, 2018 11:35 pm Post subject: Re: Transaxle tip: inspect your ring gear thru drain hole |
Very good info Chris and Paul, Thanks for posting it. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
