joebus Samba Member
Joined: February 07, 2018 Posts: 29 Location: Windhoek, Namibia
Posted: Sat Feb 10, 2018 4:52 pm Post subject: Bought but no start, help? |
Hi,
I bought recently a van (2 weeks ago) and was told by previous owner it overheated, tried starting it but discovered no FP sound, fixed that, when cranking, discovered water running out from above pushrod tubes (Welsh plug rusted a hole in it), pulled the tops to sort that, but before than, tried cranking it, it sort of started, but does not run and dies immediately! I went ahead and replaced rings since all was well and fixed leak.
Now tried to start, but still same, did wire tool breach, still no luck! Where else can I look for causes?
Really eager to get it running in order to diagnose other issues.
Thanks, any advice will be valued!
Cheers |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sat Feb 10, 2018 5:26 pm Post subject: Re: Bought but no start, help? |
Are you really in beautiful Namibia and the Garnet Coast?
I would start by confirming you have fuel (look at injector spray) and spark (at he plugs).
If yes, I would then be checking timing as there are several ways to go wrong here including something as basic as spark plug wires (which are not intuitive on a VW as the number scheme for the cylinders is a bit unusual). |
joebus Samba Member
Posted: Sun Feb 11, 2018 12:39 am Post subject: Re: Bought but no start, help? |
Morning, yes I am, will try to add some pics to illustrate, the recovery the fixing and some pics of the fault I discovered which I need advice for connection! I think I am in over my head, not very mechanical savy, budget force me to DIY!!
Checked earth wiring
Connected the bridge tool!!
Discovered this, where should it connect?
They come from these harness wires! Round connection comes from where idle control valve comes out of harness! Hope it is clear!!
I have done the initial checks, please if anyone can identify where these should be connected to!!
Please ask for other images if needed!!
Thank you in advance!! Want to see her idling soon!!!
Some images from around!!
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sun Feb 11, 2018 1:12 am Post subject: Re: Bought but no start, help? |
So by the looks of your pictures you have a Digijet injection system? I would find someone with the same van and look at them side by side.
Having loose wires and questionable grounds is a bad place to start. That Brown/Green and Brown/Yellow are ugly.
Have you checked the Hall sensor for Powewr and ground? Maybe a better picture of the top of the engine is in order here.
I would start by getting all the wires back in the box as well as making sure there are no wires left disconnected.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sun Feb 11, 2018 8:34 am Post subject: Re: Bought but no start, help? |
It does appear to be a Digijet system (hard to tell in close-up photos). A photo showing the whole engine would identify it well.
I do see non-stock wiring -- for which your only solution is to track down what each was added for and decide how to proceed.
For the correct stock wiring you will need to get familiar with the wiring diagram for the van. Perhaps not easy to follow at first but once you get the hang of reading 'current tracks' it is a very useful tool.
If it is Digijet - I have now put the wiring diagrams from the usual manual into my gallery:
https://www.thesamba.com/vw/forum/album_search.php?search_author=Ahwahnee
There is also a photo someone else here did that might help in sorting out that black box:
It is for an 86 (Digifant) but close if not the same as yours. Sometimes a photo is simpler to deal with than a diagram when trying to separate original wiring from changes or additions. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Sun Feb 11, 2018 10:53 am Post subject: Re: Bought but no start, help? |
It looks like a late model from another market, possibly a DJ code 2.1 with a version of Digijet. More photos and the vin# might help.
Mark |
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
Paulbeard Samba Member
Posted: Sun Feb 11, 2018 12:31 pm Post subject: Re: Bought but no start, help? |
ajdenette wrote: |
I didn't realize, but it looks like a big window South African fan with a Wasser boxer engine. |
Considering his locale, that is likely. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
16CVs Samba Member
Posted: Sun Feb 11, 2018 9:47 pm Post subject: Re: Bought but no start, help? |
All DJ's are Digijet, I was surprised to see that as well, as I thought the SA vans all had in lines in them.
Interesting that the DJ's are Digijet, my understanding was that the wanted the ignition to be stand alone for some reason. The other curious thing about a DJ is that our MV ICR are " B&D" the DJ units are "A&C".
Something tells me that this van is question has had an interesting life.
joebus Samba Member
Posted: Mon Feb 12, 2018 2:51 am Post subject: Re: Bought but no start, help? |
Hi,
Will implement all suggestions,
Can anyone tell me which plug this one below is?
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
Posted: Mon Feb 12, 2018 5:08 am Post subject: Re: Bought but no start, help? |
Yes, RHD, DJ, Syncro bits, wonder how much is original.
Mark
16CV's wrote: |
Stacy |
Mark Lewalski Samba Member
Joined: June 19, 2010 Posts: 406 Location: Safety Harbor, FL (Tampa Bay)
Posted: Mon Feb 12, 2018 7:06 am Post subject: Re: Bought but no start, help? |
I'd ensure that the wires to the Hall Sensor and the sensor itself are good. My exact experience when I bought my Bluestar was the same: wanted to start, fired once or twice but never ran.
If you look on the side of the distributor, you should see a black plastic "box" with a plug attached. See if that "box" is loose on the side of the distributor or if the wires going to the plug are cracked and possibly shorting or without continuity. That "box" is the connection point for the wiring plug to the inside of the distributor sensor piece. If that sensor has faulty wiring, your van will not run correctly. It is a show stopper that will need to be fixed.
Good luck. Please make sure to post your findings so we all know what you found.
Mark _________________ '89 Vanagon GL Wolfsburg "Bluestar" (given to and owned by my son now)
'87 Vanagon Weekender
'74 Thing |
joebus Samba Member
Posted: Mon Feb 12, 2018 7:28 am Post subject: Re: Bought but no start, help? |
Hi, thanks for all the advice, will do my homework tonight and report back! Here is pic of engine bay as requested!
Cheers for now!
Posted: Mon Feb 12, 2018 8:28 am Post subject: Re: Bought but no start, help? |
That photo shows the temp sensor wires for the fuel injection are not plugged in.
Look at the left side for the light blue plastic 2 pin connector.
Mark |
Posted: Mon Feb 12, 2018 8:37 am Post subject: Re: Bought but no start, help? |
I know it's not essential for "starting" but also doesn't look like the accelerator cable is hooked up the throttle body. You might start but it ain't going to go anywhere without that. I'm going to let Mark keep giving you electrical system guidance because he is 98.02% more knowledgeable than me, but thought I'd point that out. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Mon Feb 12, 2018 11:15 am Post subject: Re: Bought but no start, help? |
Vacuum system is compromised... The evap. system lines (small diameter plastic ones, one blue and one white) to and from the Charcoal can are not hooked up at all, and the brake booster hose looks like a sawed dog probably full of holes. I would guess that with holes in the vacuum system like that, no wonder....
Good luck _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
joebus Samba Member
Posted: Tue Feb 13, 2018 4:08 am Post subject: Re: Bought but no start, help? |
Bobbyblack,
I have no clue where those lines should go, any direction please?r |
Posted: Tue Feb 13, 2018 8:03 am Post subject: Re: Bought but no start, help? |
The situation at hand is probably more that there are hoses disconnected, or that have holes in them than that you'll have much success just hooking them back up in the engine compartment... The way they look, there has been and additional disconnection to the other end of those lines, especially the white one on your right that hangs out as far as the belts.
Here is a shamelessly stolen pic of the same kind of engine, I have circled where the charcoal can lines go into the intake manifold. IF the person who was removing the lines actually plugged the locations on the intake with something, perhaps its OK for now to leave them off.
The big red arrow points to the start of the brake booster line, yours looks like a shaggy dog's tail. I have seen these look as bad and not be trouble, however, I have also been fooled by ones that look less bad and do have holes.
I also might be wrong on the brake booster line, depending where your vacuum check valve for the brake booster line is. If it is at the red arrow, then its possible the the engine is not having vacuum issue from the shaggy dog line. Mine is at the far end of that line, so that is why I mentioned it.
Mainly, I was hopeful that you'd just plug the vacuum system adequately to be relatively sure that the engine can even sputter to a start. The charcoal can and the brake booster are not, in themselves, reasons it wouldn't start, but the holes in the intake manifold where those lines go into would, perhaps.
