3 fold ragtop install!
55 3fold
55 3fold is offline
PostPosted: Sun Feb 11, 2018 9:13 am    Post subject: 3 fold ragtop install! Reply with quote
Hey guys just thought I would share my experience with the installation of my ragtop mechanism and canvas on my 55' in hope this can help anybody else doing the same.
I purchased the vehicle with the roof in pieces so I didn't have the opportunity to disassemble it.
Finding out info on the net was limited.
I new I had all the pieces for the mechanism from pictures on Grumpys metal website.
I did searches on the samba for 3 fold ragtops and found a thread in the 38-53 forum.
This gave me the much needed info on starting the install of the tension straps with proper spacing and to have the canvas have its correct 3 folds.
The bow nearest the back of the car is 324mm from the finishing screw to the middle of the tension strap where the screw goes through.
The Next bow forward is 376mm from the finishing screw on the middle bow to finishing screw on the rear bow.
Thanks to Rich with these measurements I was able to fasten the tension straps with this correct spacing and get the mechanism all installed and sliding.
Next was the canvas! This was another thing that I couldn't find too much info on. One thing I did realize was that I was missing the seal that runs along the front and sides of the front header bow. It wasn't listed in the parts on Grumpys for the bug but is in the Bus parts section.
I attached the seal with spray glue and then proceeded to install the canvas.
In the rear I lined the tension bar up at the back and punched some elongated holes so I could create more tension on the canvas if need be.
I'm pretty happy with how it turned out, aside from some slight wrinkles in places. I'm hoping maybe with it out in the sun it will flatten. If not I will loosen the tension strap screws at the back and pull it tighter.
I will post some more pics with it folded back! Cheers! Laughing
aa390392
aa390392 is offline
PostPosted: Sun Feb 11, 2018 10:18 am    Post subject: Re: 3 fold ragtop install! Reply with quote
Thanks for that detailed information , I know it will help in the future to all of those that will attempt the task.
Cheers Thomas
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
greek_tony
greek_tony is offline
PostPosted: Sun Feb 11, 2018 3:43 pm    Post subject: Re: 3 fold ragtop install! Reply with quote
Thanks very much for the info. It'll come in handy in the next few months!
How did you attach the canvas to the header bow? Glue? Rivets?
What about the headliner? How do you fit it?
1963 Karmann Ghia - Sold
May 53 Ragtop - Resto started
October 65 Fastback - Almost there.
55 3fold
55 3fold is offline
PostPosted: Sun Feb 11, 2018 5:24 pm    Post subject: Re: 3 fold ragtop install! Reply with quote
I used 3M spray glue on both sides, decided to not use the rivets as I don't think they are needed.
I haven't installed the headliner yet so sorry no info on that yet.
lovethatconvertible
lovethatconvertible is offline
PostPosted: Sun Feb 11, 2018 8:18 pm    Post subject: Re: 3 fold ragtop install! Reply with quote
55 3fold, you really should upload your pic's on The Samba. Otherwise this thread in the future will probably turn into dead links. Making it useless. Which would be a bummer.
1960 Convertible
Erik G
Erik G is offline
PostPosted: Mon Feb 12, 2018 9:00 am    Post subject: Re: 3 fold ragtop install! Reply with quote
yep - already dead on my screen, lots of places block imgr
greek_tony
PostPosted: Mon Feb 12, 2018 2:26 pm    Post subject: Re: 3 fold ragtop install! Reply with quote
Thanks for that Very Happy
55 3fold
55 3fold is offline
PostPosted: Mon Feb 12, 2018 4:16 pm    Post subject: Re: 3 fold ragtop install! Reply with quote
Ok pictures are back up, thanks guys for letting me know about posting them on Samba! Laughing No more imgur!!
PostPosted: Mon Feb 12, 2018 10:10 pm    Post subject: Re: 3 fold ragtop install! Reply with quote
Added this thread to the FAQ, thanks for doing it!
Splitdog
Samba Split Personality
Splitdog is offline
PostPosted: Sun Feb 18, 2018 8:18 pm    Post subject: Re: 3 fold ragtop install! Reply with quote
The 3M spray adhesive you can buy at the stores is nowhere near robust enough to glue that canvas for any length of time. Lenny's shop uses this when they're out of regular bulk spray adhesive.
This stuff is awesome. ~$15
CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker
mcvw
mcvw is offline
PostPosted: Wed Nov 04, 2020 11:09 am    Post subject: Re: 3 fold ragtop install! Reply with quote
Hi, would you be able to share where you got the new sunroof mechanism parts (the plastics etc that fit on the ends oof the bows, and also the runners/sliders). Thank you, Mike
jitbba
jitbba is offline
PostPosted: Wed Nov 04, 2020 11:20 am    Post subject: Re: 3 fold ragtop install! Reply with quote
If Gumpy's Metal doesn't have it, use Wolfsburg West
https://www.wolfsburgwest.com/wolfsburg_new/sunroof/sunroof_bug/bug_sunroof.cfm?type=1
My other ride is a Zildjian
tmdenis
tmdenis is offline
PostPosted: Sat Oct 05, 2024 1:23 am    Post subject: Re: 3 fold ragtop install! Reply with quote
Hello I’ve installed mine with a bit of your help from what you’ve posted. I’m wonder is there any adjustments to the front header bow. Mine is a little high and it needs to tuck down a bit tighter to the body. Let me know if you could assist with my questions. I’ve checked all over and there is not info on adjustments to the front bow, thanks in advanced.
-54 VW bug ragtop
