Emerson5057 Samba Member
Joined: July 25, 2012 Posts: 82 Location: Pittsburgh, PA
Posted: Sun Feb 11, 2018 4:42 pm Post subject: Tire size for lowering a super beetle |
Hello,
I have read the lowering sticky, was not very helpful. I have purchased new springs and new strut inserts, and adjustable housing. Now I need to know what tires I should go for. I am not going for super slammed, but maybe just a little tuck, or pretty flush with the fenders. Does anyone have pictures of what the 155 looks like compared to the 145 on a beetle?
Any help or insight would be great!
Thanks _________________ 1974 Super beetle-long gone
1972 super - Sold for the Van
1982 Vanagon Westy aircooled auto O.o |
VolkswagenNate Samba Member
Joined: October 08, 2017 Posts: 69 Location: Tennessee
Posted: Sun Feb 11, 2018 6:54 pm Post subject: Re: Tire size for lowering a super beetle |
Im not sure what size i have, i can look tomarrow. But wheel backspacing makes a difference on a super. I had to go back to stock steelies because my 8 spokes stuck out to far. |
Posted: Mon Feb 12, 2018 5:03 pm Post subject: Re: Tire size for lowering a super beetle |
Not sure if this helps at all, but here's what i've tried. 185 65 15, rubs bad while turning (but I'm pretty low) and probably not recommended on 4.5" wheels. I like them in the back though.
And currently i have 125 temps in the front. ( i dont recomend this, i'm barely driving it til i get new tires ). Only reason i bring this up is because they're close to the same height as 155 60's, which is what i think I'm about to go with.
This is all with stock 4.5s which have close to 4" of backspace.
185
125
Posted: Mon Feb 12, 2018 7:35 pm Post subject: Re: Tire size for lowering a super beetle |
Both of you guys are helpful thanks for the reference. I'm thinking about going with the 155. would love if someone could show a pick of that _________________ 1974 Super beetle-long gone
GearHeadKeith Samba Member
Joined: January 14, 2003 Posts: 112 Location: Detroit, MI
Posted: Mon Feb 12, 2018 8:06 pm Post subject: Re: Tire size for lowering a super beetle |
I have 145SR15 in front and 165SR15 in rear on a vintage set of American Eagle 8-spoke with 3.75" backspacing. It just barely works with Topline front struts set at 2.5" of drop.
John at Topline knows what works when lowering a Super Beetle and sells top-quality parts. It is worth talking to him.
_________________ Keith Gilbert - DdK
1971 Super Beetle sedan, Shantung yellow with black interior. Cosmetically unrestored with over 366k miles.
1776cc: 9.2:1 compression, dual Weber 40DCN on Deano intakes, Primo Petrucci 40mm/36mm round-port heads, Crower VW284F cam, Kymco 1.5" exhaust
SSC trans with 3.78/2.25/1.48/1.04 & 4.12 Gleason R&P, Type IV output flanges, Berg Shifter
Topline front struts/springs/sway bar, Sway-a-Way rear bar, 4-wheel disc brakes
Owned since 1994: 3rd owner since new! |
Posted: Thu Feb 15, 2018 2:47 pm Post subject: Re: Tire size for lowering a super beetle |
GearHeadKeith wrote: |
Awesome pics thanks ! Does john at topline have an email or a phone numbeR? _________________ 1974 Super beetle-long gone
vwoldbug Samba Member
Posted: Thu Feb 15, 2018 4:52 pm Post subject: Re: Tire size for lowering a super beetle |
That yellow super beetle is nice . |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Thu Feb 15, 2018 5:37 pm Post subject: Re: Tire size for lowering a super beetle |
Emerson5057 wrote: |
Does john at topline have an email or a phone numbeR? |
here ya go . . . http://toplineparts.com/lower-your.html
Jon has been lowering Super Beetles for over 40 years . . . knows 'em inside & out!!!!! _________________ Jesucristo es mi Señor y Salvador! |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4419 Location: Stuck in Ohio
Posted: Thu Feb 15, 2018 6:54 pm Post subject: Re: Tire size for lowering a super beetle |
Hey Emerson, I went 175/55 up front and I love them. No rubbing and plenty of meat.
Buggeee wrote: |
Whats that you say? Why was I in there anyway? Well... glad you asked.
I was putting on the NEW TIRES and WIDE WHEELS!!!
For the google search engine - Here is the proper size tire for a lowered 1972 Super Beetle with NO RUBBING. For those cruising the threads for tire-size info - I'm running Topline Maxx struts down to the bottom and flipped tie rods up front. One outer spline up from the bump stops on the rear.
My rims are - 5.5 inch rims ET25 (25 mm offset) stock reproductions from Mid America Motorworks
My tire sizes are -
Front 175/55/15
Rear 195/60/15
This took a phone call to Topline and about 7 hours of research for me. What a trip down the tire size/wheel offset rabbit hole! The results are worth it.
Here's the side by side comparison to stock 165/80/15 with 4.5 inch stock rims in the rear:
And here's the comparison with the same stock tire and rim in the front:
For those with a disk brake kit, there is some modification required for this wheel set. Here's where the rim and caliper interfere with each other:
So I ground down the caliper as so:
And I ground off the stamping excess from the inside of the wheel as so:
And then they fit perfectly!!!! Well, not perfectly. My first trip around the block had a banging sound that then resulted in the ball joint nuts knocking off the wheel weights that were installed to the inside lip of the rim. There is veeeery little clearance there. So I'm having the wheels re-balanced today using the weights that stick on the inside circumference of the rim (like they do on aluminum wheels) rather than the ones that clip on the edge. Thank goodness it was just that! It was a dreadful sound to hear at first. So anyway...
Here are the most important views you have been waiting for... the Stance
Then I did donuts in front of the house at full lock - and NO RUBBING!!!
Then I took it on the open road and the highway. This is a different car. These modern tire sizes and ratios are what make cars drive the way they do as far as I can tell. This thing is much quieter. It rolls smoothly over bumps and road defects. It handles ridiculously stable when pushed unreasonably around corners. Fun, Fun, Fun. Lots of body noises disappear! Run out and get some. |
_________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Thu Feb 15, 2018 7:19 pm Post subject: Re: Tire size for lowering a super beetle |
I’ve got 185/60 on front with the 914 sport wheel 5.5” with ET40.
No problems, no rubbing. Looks great. Imnsho _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
VERTED71 Samba Member
Posted: Thu Feb 22, 2018 11:15 pm Post subject: Re: Tire size for lowering a super beetle |
_________________ Aloha'z and have a great day!
71 Super Beetle Vert
15x4.5 Front
15x6.5 Rear
155/60R15 74T tires FRONT
205/65/15 tires REAR
1600 Dual Port
Progessive Carb
Electronic Ignition
Tri Mil "hotdog" exhaust |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Fri Feb 23, 2018 6:41 am Post subject: Re: Tire size for lowering a super beetle |
73, and earlier Supers have different requirements than the 74, and later ones. It's great you've gotten some feedback, but it looks like most of the cars are early. Some combos work with both, and there are combos that don't, so look for combos to fit the later cars. I personally run the "Cal Look" 145 80 15's on a stock style 4 1/2 chromie on my 74 that's lowered about 2 inches. If I'm taking a sharp off camber corner, or diagonally entering a parking lot with a huge curb when one wheel would receive a lot of weight while almost at full lock, they will rub the fenders a little. There have been a lot of wheels come out, and a lot of different tire sizes in the last 10 years, or so. If you're thinking about going the stock painted route, there are 2 widths, and 4 different offsets of stock 4 bolt "slot" VW wheels. Another thing to consider is if you have an OEM VW drum, or disc with the center hub/ring used to center the stock wheel. A lot of aftermarket wheels won't clear this, and you need to either have it machined off, or get drums/discs that don't have it. I'd talk with Topline as well, and keep doing research. I'll see if I can post some old pics I have later today. |
Posted: Fri Feb 23, 2018 8:15 am Post subject: Re: Tire size for lowering a super beetle |
Here is a link to a web site that I found very useful when I was trying to size my tires, wheels, and offset.
https://tiresize.com/wheel-offset-calculator/
That link opens to the wheel offset tab and the web page also has tabs for tire sizes and other things related to the project. The calculator provides before and after comparisons so you can play around with different size rubber, wheels, etc. and visualize how any of the changes impacts the presence of the tire. It also provides speedometer information so you see what the new speed calculations are after you change tire sizes. I plan to print a new face for my speedo at some point with the numbers in the correct place for tire size I am now using.
Have fun. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Posted: Fri Feb 23, 2018 4:32 pm Post subject: Re: Tire size for lowering a super beetle |
Last edited by [email protected] on Sat Feb 24, 2018 8:00 pm; edited 1 time in total |
volksnhousin Samba Member
Joined: July 18, 2006 Posts: 326 Location: Ellerslie, GA
Posted: Sat Feb 24, 2018 12:15 am Post subject: Re: Tire size for lowering a super beetle |
145/80/15, 165/65/15, 165/50/15, and 175/55/15 are some lowered VW tire sizes that come to my mind at the moment. 165/80/15 is considered original size for your VW.
Type what ever tire size you want into this thing and it will tell you what you might want to know about them. https://www.tacomaworld.com/tirecalc?tires=145-80r15-175-55r15 |
house of dubs Samba Member
Joined: January 17, 2021 Posts: 7 Location: Vancouver, WA
Posted: Mon Mar 07, 2022 9:31 am Post subject: Re: Tire size for lowering a super beetle |
Its been 4 years since anyone has posted here and I was wondering if there has been any new info around lowering a super beelte and what tires/wheels everyone is using. |
boxer74 Samba Member
Joined: July 03, 2011 Posts: 709 Location: Ontario, Canada
Posted: Thu Mar 30, 2023 7:56 pm Post subject: Re: Tire size for lowering a super beetle |
I've got a 74 super and am about to try:
155/60/15 on et41 4.5" sport wheels in front
185/65/15 on et40 5.5" sport wheels in rear
This is with adjustable struts on highest setting and tapered red springs. _________________ 74 Super
84 Westy |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1293 Location: Modesto, CA
Posted: Thu Mar 30, 2023 8:19 pm Post subject: Re: Tire size for lowering a super beetle |
This is 185 65r 15 front, 205 60r 15 rear _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
Epilog79 Samba Member
Joined: June 04, 2009 Posts: 218 Location: Tigard,Oregon
Posted: Fri Mar 31, 2023 9:54 am Post subject: Re: Tire size for lowering a super beetle |
House of Dubs, there hasn't been any new "break throughs" in lowering and tire sizes. It is always an adventure trying to cram as much tire under the front and rear as possible. Backspacing is the key, especially the front.
I have a 79 with the Topline tapered springs and adjustable strut. With 914 wheels with the ET40 offset I had 195/60/15 stuffed under the front and 205/60/15 in the rear.
