Driver side front sits lower than passenger
74superTN
74superTN is offline
PostPosted: Mon Feb 12, 2018 7:59 am    Post subject: Driver side front sits lower than passenger Reply with quote
Any ideas why my drivers side front end sits lower than the other side? My frame is straight, meaning I can measure the beam on both ends and it's the same height...
73 Thing
80 Vanagon Westy
2016 Golf Sportwagen
Wildthings
Wildthings is offline
PostPosted: Mon Feb 12, 2018 11:26 am    Post subject: Re: Driver side front sits lower than passenger Reply with quote
You may need to adjust your rear spring plate angle.
74superTN
PostPosted: Thu Feb 15, 2018 6:41 am    Post subject: Re: Driver side front sits lower than passenger Reply with quote
Its not the rear, that sits perfectly level...My beam up front is level to the ground but the front end of the body sits a little lower on the drivers side.
73 Thing
80 Vanagon Westy
Wildthings
PostPosted: Thu Feb 15, 2018 9:03 am    Post subject: Re: Driver side front sits lower than passenger Reply with quote
No expert on body mounting, but there are rubber mounts that sit above the beam that split and fall out. They are only about a 1/2" thick though.
74superTN
PostPosted: Thu Feb 15, 2018 11:04 am    Post subject: Re: Driver side front sits lower than passenger Reply with quote
Ok thanks, might be what it is..I wasn't around when my buddy reinstalled my beam.
73 Thing
80 Vanagon Westy
iltis74
iltis74 is offline
PostPosted: Sat Feb 17, 2018 11:50 pm    Post subject: Re: Driver side front sits lower than passenger Reply with quote
If the beam is level, is the body not in line with it? Could it just be the fender installed off a bit, or the bumper drooping from installation/standing on it?
65 Beetle
73 & 74 Things
87 Syncro
74superTN
PostPosted: Thu Apr 26, 2018 7:09 am    Post subject: Re: Driver side front sits lower than passenger Reply with quote
UPDATE and FIX:
It ended up being my bumper...It was bent down on the drivers side, so a carefully placed jack under the lower side and some patience put it back into place!
73 Thing
80 Vanagon Westy
