montana87 Samba Member
Posted: Thu Feb 15, 2018 2:02 am Post subject: high roof inner dimensions |
Hello everyone!
Gonna buy bus just like on the pic. The question is inner height inside. How many cm?
OrangeZA Samba Member
Joined: January 04, 2016 Posts: 110 Location: Scottish Highlands
Posted: Thu Feb 15, 2018 2:58 am Post subject: Re: high roof inner dimensions |
Hmm, factory high top. You have found yourself an interesting T2. Where in the world are you based?
Click on the image below to enlarge it and see the dimensions in the diagrams. The picture is from a Dutch VW brochure which can be found in the literature section of this website: https://www.thesamba.com/vw/archives/lit/type2_2.php
Good luck with your project! |
Posted: Thu Feb 15, 2018 3:15 am Post subject: Re: high roof inner dimensions |
OrangeZA wrote: |
Russia. I've found fully restored van with standard roof and roof from the other van. It's owner says that he is 180cm height and he can stand inside his van and have about 5cm space above. Maybe there is another versions of high roof exists? Here is the photo of the van which roof i'm going to purchase
Posted: Thu Feb 15, 2018 3:47 am Post subject: Re: high roof inner dimensions |
Privet Montana87!
I found another brochure in the archives, apparently the same roof, but it gives a different dimension, although still not enough room to allow a gentleman of 180cm stature to stand upright…
Again click on the photo to enlarge and read the dimensions.
Are you getting the roof bows too or just the fibreglass? As you can see in the photo above, the factory style highroof uses unique roof bows that raise the height of the roof throughout the length of the vehicle and make it feel much more spacious, whilst retaining the strength of the monocoque shell. There’s quite a bit of work involved in converting a standard roof T2 to a factory style hightop.
Poka! |
Posted: Thu Feb 15, 2018 4:11 am Post subject: Re: high roof inner dimensions |
Here is the roof i'm gonna purchase. As you can see inside 55cm. No roof bows, got to make it by my own
samwise Samba Member
Joined: May 04, 2010 Posts: 611 Location: North Salt Lake, Utah
Posted: Thu Feb 15, 2018 8:46 am Post subject: Re: high roof inner dimensions |
Based on the design of the ribs in the fiberglass, I would say that the 1766mm version if correct.
The brochure showing 1680mm is also for the tall sliding door option, whereas your roof is for the standard sliding door. _________________ Ben
1979 7-passenger bus
Harvee the Wonder Bus' pics |
