2type2 Samba Member
Joined: June 02, 2002 Posts: 978 Location: SW Colorado
Posted: Mon Feb 12, 2018 2:17 pm Post subject: Where to keep extra oil quart? |
I am considering using a stainless steel "backpacker fuel bottle" (1ltr.) held in a bicycle type water bottle clamp, to serve as an always -available spare oil storage.These bottles are Coleman fuel safe but the wonder is.... Is it safe to mount this within the engine bay out of the way somewhere? Opposite the battery,behind the battery, or somewhere in there? Any body say nay? Done it already??
This would also make it easy to top off the oil as the bottle needs no funnel. _________________ "A life of peace and happiness depends on your own gratefulness" |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Feb 12, 2018 2:45 pm Post subject: Re: Where to keep extra oil quart? |
I tuck extra quarts between the battery and corner _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Mon Feb 12, 2018 2:48 pm Post subject: Re: Where to keep extra oil quart? |
Why not just keep it in the plastic bottle it comes in?
Plastic does not conduct electricity, stainless steel (metal) does. _________________ Glenn
Member #1009
#BlueSquare |
Stocknazi Samba Member
Posted: Mon Feb 12, 2018 2:53 pm Post subject: Re: Where to keep extra oil quart? |
I keep a gallon jug behind the front bench seat filled with a quart or 2. The gallon jug will not turn over like a quart sized container. My fire extinguisher is in the same place. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Feb 12, 2018 3:17 pm Post subject: Re: Where to keep extra oil quart? |
Five normal 1 quart oil bottles fit in the non-battery tray just fine. The ones closest to the engine are laid down on the narrow side so they can not lean and flip over the mini wall there. Then the ones against the LH outer wall stand up. _________________ In Stereo, Where Available! |
2type2 Samba Member
Posted: Mon Feb 12, 2018 4:05 pm Post subject: Re: Where to keep extra oil quart? |
I figure it will be nice to always have some reserve top off oil even when there isn't any behind the seat.It is an easier pour also! I already have the bottles so yeah! My main concern was the heat,but if some are carrying plastic bottles, no problem then ! _________________ "A life of peace and happiness depends on your own gratefulness" |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Mon Feb 12, 2018 4:43 pm Post subject: Re: Where to keep extra oil quart? |
Ditto on the engine bay... free storage on the battery and opposite side. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Posted: Mon Feb 12, 2018 4:47 pm Post subject: Re: Where to keep extra oil quart? |
Have over 250,000 miles on our 1960 panel camper conversion. In that time have traveled in weather over 100F and as low as -6F. Rotate stock in there will keep from vibration wearing thru the bottles. Even then have one bottle that has been in there much longer than the others. That one bottle that was originally engine oil, that has special gear oil so the transaxle can be topped off. _________________ In Stereo, Where Available! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon Feb 12, 2018 7:20 pm Post subject: Re: Where to keep extra oil quart? |
2type2 wrote: |
This would also make it easy to top off the oil as the bottle needs no funnel. |
I like your idea because it's your idea and nothing wrong with it being a custom feature. It is safe. |
Clara Samba Member
Posted: Mon Feb 12, 2018 7:22 pm Post subject: Re: Where to keep extra oil quart? |
Eric&Barb wrote: |
Five normal 1 quart oil bottles fit in the non-battery tray just fine. |
That's where I keep it too. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Feb 13, 2018 9:08 pm Post subject: Re: Where to keep extra oil quart? |
You guys have me thinking about something other than my 2-1/2 gallon spare gas can in the left side. I'm going to gut an old car battery and make an oil storage box from it. A second battery strap would hold it quite well.
It's also kinder to the engine to introduce new oil that has been acclimated to engine compartment temps. Limits the shock- like putting your new goldfish in the fish tank ten minutes before opening the plastic bag. _________________
EverettB wrote: |
FU#5 |
Posted: Tue Feb 13, 2018 10:11 pm Post subject: Re: Where to keep extra oil quart? |
A battery box would do the same and give you a bit more room for storage. _________________ In Stereo, Where Available! |
Abscate Samba Member
Posted: Wed Feb 14, 2018 7:20 am Post subject: Re: Where to keep extra oil quart? |
I have a quart in all my cars. Put it into a plastic ziplock with a pack of paper towels in the bottom so:
- You can see a leak right away.
- Paper towels useful for pouring/cleaning up
- Rotate them so that the container isnt too ancient. You will find chafe is the danger and eventually will wear a hole in a bottle unless you clamp it up somehow. _________________ .ssS! |
David Raistrick Samba Member
Joined: January 26, 2004 Posts: 539 Location: Geneva, Florida
Posted: Wed Feb 14, 2018 8:24 am Post subject: Re: Where to keep extra oil quart? |
Glenn wrote: |
Why not just keep it in the plastic bottle it comes in? |
today's plastic bottles are not like they used to be. they spring leaks like nothing else - just sitting on my shelf in the shop, brand new 4 and 5qt jugs will start leaking. (I dont buy many 1qt bottles - but the stuff I have had come through aren't any better. I keep old bottles around to cycle through for behind-the-seat oil) _________________ ...david - '66 SO-44 #231 |
hitest Samba Member
Posted: Wed Feb 14, 2018 7:09 pm Post subject: Re: Where to keep extra oil quart? |
Eric&Barb wrote: |
A battery box would do the same and give you a bit more room for storage. |
Yeah, but then it would just look like a battery box. _________________
EverettB wrote: |
FU#5 |
Posted: Wed Feb 14, 2018 7:34 pm Post subject: Re: Where to keep extra oil quart? |
David Raistrick wrote: |
Glenn wrote: |
today's plastic bottles are not like they used to be. they spring leaks like nothing else - just sitting on my shelf in the shop, brand new 4 and 5qt jugs will start leaking. (I dont buy many 1qt bottles - but the stuff I have had come through aren't any better. I keep old bottles around to cycle through for behind-the-seat oil) |
Indeed. They used to be fiberboard and you punched them open with a bottle opener _________________ .ssS! |
guatebus Samba Member
Joined: May 12, 2003 Posts: 393 Location: Oakland, CA
Posted: Wed Feb 14, 2018 8:47 pm Post subject: Re: Where to keep extra oil quart? |
I keep my extra oil in the well behind the front bench seat. But it's interesting to see what other folks do. Maybe I should put it in the engine bay.
Other storage things I do:
Small on-board tool kits and lug wrench (in the back luggage shelf above engine compartment)
Spare parts, tarp, and scissor jack (under the Westy bench seat)
Fire extinguisher (behind front bench seat)
Tire pressure gauge, spare fuses, maintenance notebook, etc. (parcel tray)
Spare tire (in the back passenger area where the middle seat should be) _________________ '64 standard microbus
'69 deluxe microbus |
jason Samba Member
Posted: Wed Feb 14, 2018 9:11 pm Post subject: Re: Where to keep extra oil quart? |
I keep my extra oil in a bigger sump. I'm never more than 3000 miles from home. |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Wed Feb 14, 2018 9:21 pm Post subject: Re: Where to keep extra oil quart? |
I keep all my fluids in a box right up against the rear cargo door and under the rear seat/ bed area with my tool box and road kit parts box so they are easy to get to. I like the battery box in the engine compartment idea though. I pick those up at yard sales all the time for cheap.
I you are worried about the bottles chafing, just put a thin sheet of foam packing sheet between the bottles. |
Posted: Wed Feb 14, 2018 9:25 pm Post subject: Re: Where to keep extra oil quart? |
hitest wrote: |
Eric&Barb wrote: |
Yeah, but then it would just look like a battery box. |
Then build a flux capacitor instead! It will not look like just another battery or battery box. _________________ In Stereo, Where Available! |
