robin.richard Samba Member
Joined: February 17, 2012 Posts: 497 Location: V. Beach VA
Posted: Mon Feb 12, 2018 4:38 pm Post subject: Testing a vacuum advance without timing light |
Okay, I guess I'll ask question since I could not readily find the answer.
How can one test, or make sure his vacuum advance is advancing properly without a fancy (expensive) timing light?
I just changed my distributor from a 009 to a proper vacuum advance distributor a week ago. I run a SOLEX 30 PICT 1 carb in my 1600 SP and now use a 113 905 205 K vacuum distributor. Before I installed the distributor I cleaned and lubed it, replaced the points, condenser, rotor, and cap. Gaped the point @.016. Sucked on the vacuum can to make sure the arm would move and it would hold. Static timed @ 7.5 BTDC. The engine runs very good. No issues noticed. No noticeable flat spots or hesitation at takeoff. Something that I would notice occasionally with the 009 on takeoff. So I guess I just assume the distributor is good? Any suggestions to test without timing light?
Thanks.
-Rich _________________ Drive your bus! |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Mon Feb 12, 2018 5:03 pm Post subject: Re: Testing a vacuum advance without timing light |
Sorry for any confusion in my post.
I used a static timing light to set the timing @ 7.5 BTDC, but was not sure how to test to see if the distributor is advancing properly without one of those fancy variable speed timing light guns.
Looking for tricks to see if it's advancing properly @ ~3000 RPMs?
busdaddy Samba Member
Posted: Mon Feb 12, 2018 5:35 pm Post subject: Re: Testing a vacuum advance without timing light |
robin.richard wrote: |
-Rich |
Not a whole lot you can do if you lack X-ray vision, a strobe is the only option for mortals. You could pull off the vacuum line @3K RPM and see if the RPM drops a bit, that will indicate the advance was sucked in some, but running static at 3K there won't be too much (or any) advance, that really only happens under load with throttle openings much higher than you can duplicate in the driveway. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Clara Samba Member
Posted: Mon Feb 12, 2018 7:21 pm Post subject: Re: Testing a vacuum advance without timing light |
busdaddy wrote: |
-Rich |
Not a whole lot you can do if you lack X-ray vision, a strobe is the only option for mortals. You could pull off the vacuum line @3K RPM and see if the RPM drops a bit, that will indicate the advance was sucked in some, but running static at 3K there won't be too much (or any) advance, that really only happens under load with throttle openings much higher than you can duplicate in the driveway. |
You can actually tell by ear if the timing is not advancing, as it will sound retarded. It is like the note is flat. If you don't know what that sounds like I can't explain it. Buy a strobe light timing gun and use it. Good to check the advance is advancing with a mechanical advance as well at every tune up. Those can stick, which you can tell is happening if you know what it sounds like when running retarded. Then you can manually set it so it is where it should be at advanced, and swap it out when you get home. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Feb 12, 2018 7:29 pm Post subject: Re: Testing a vacuum advance without timing light |
Disconnect the hose from the carb. Remove the distributor cap. suck on the hose, the points should move counter clockwise. If they don't, it's not advancing.
BTW... you can test it with a timing light since the engine really needs to be under load and not at idle. _________________ Glenn
Member #1009
#BlueSquare |
AngelBoy Samba Member
Joined: September 02, 2010 Posts: 44 Location: Oceanside, CA
Posted: Tue Feb 13, 2018 6:22 pm Post subject: Re: Testing a vacuum advance without timing light |
If it's running OK, meaning it accelerates like it should, you have to have the spark advancing. It it wasn't working it would accelerate like it was running on three cylinders. Totally dogged out.
However, if I were you, I'd invest in a $30 timing light. Here's why; sometimes those old distributors can advance too much. Which will make you think everything is fine. The car will have a little extra get up and go.
But, I is running hot with the advance going too far. I had an old 205T that was advancing to almost 50 degrees. You need to be able to make sure your distributor isn't advancing too much. Shouldn't go past about 30 degrees???
Not good.
Buy a timing light. You need it anyway. Good luck........
Ray in Temecula |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Feb 13, 2018 7:29 pm Post subject: Re: Testing a vacuum advance without timing light |
On a vacuum only distributor there is no way it should advance to 50 degrees. It either had the wrong vacuum canister or return spring on it. Now an SVDA or a DVDA distributor can deliver some strange results. _________________ Roads Scholar &
wcfvw69 Samba Purist
Posted: Tue Feb 13, 2018 8:02 pm Post subject: Re: Testing a vacuum advance without timing light |
The correct vacuum can on a 205K will advance the timing approx 24* where a 205T correct vacuum canister will advance the timing 30*. There's no mechanical advance obviously with an SVA. _________________ Contact me at [email protected]
The Samba member since 2004.
Glenn Mr. 010
Posted: Tue Feb 13, 2018 8:08 pm Post subject: Re: Testing a vacuum advance without timing light |
I don't see how the wrong spring can control the total advance, the vacuum canister does. The spring controls the "curve" or rate of advance from none to maximum. _________________ Glenn
Member #1009
#BlueSquare |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Tue Feb 13, 2018 10:37 pm Post subject: Re: Testing a vacuum advance without timing light |
A wrong spring could change the rate of change or the rpm at which full advance is attained, but I don't see how it could expand the advance range. |
Posted: Wed Feb 14, 2018 9:18 am Post subject: Re: Testing a vacuum advance without timing light |
All I'm saying is that robin.richards should get a timing light because he should care about the timing at the bottom side of the rpm curve, and at the top side too. The only way to do that is with a timing light; and those old distributors can get funky. |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Wed Feb 14, 2018 11:55 am Post subject: Re: Testing a vacuum advance without timing light |
I don't know what your definition of expensive or fancy is, but this is the light that I use, and I consider it to be a cheap and essential tool for tuning your VW. The cost is less than an hour of time at most any auto shop.
http://www.sears.com/craftsman-advanced-timing-light/p-00914065000P _________________ .
Wanted:
srfndoc Samba Member
2Pack Samba Member
Joined: September 20, 2005 Posts: 807 Location: Virginia
Posted: Wed Feb 14, 2018 1:19 pm Post subject: Re: Testing a vacuum advance without timing light |
Thanks.
-Rich |
What I've done before to check full advance on a vacuum advance distributor is make marks on the crank pulley corresponding to the upper and lower limit of full advance. Then I verify that the timing mark moves between those two marks at high RPMs using a normal static timing light. You can look the full advance limits up in the VW workshop manual. I have a way to mark the pulley that I like too so post back if you need that info.
Clarification: when I say static timing light I mean a strobe light without the adjustable advance. _________________ Please buy my Treasure
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Wed Feb 14, 2018 1:32 pm Post subject: Re: Testing a vacuum advance without timing light |
Strobe timing lights are neither fancy nor expensive _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Wed Feb 14, 2018 10:05 pm Post subject: Re: Testing a vacuum advance without timing light |
ok, let me clarify my statement earlier that having the wrong spring will cause the distributor to act other than normal but does not effect total advance. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Thu Feb 15, 2018 7:17 am Post subject: Re: Testing a vacuum advance without timing light |
[quote="2Pack"]
Clarification: when I say static timing light I mean a strobe light without the adjustable advance. |
I also do not like adjustable timing lights. First, you can inadvertently turn the knob completely messing up your readings.
Second, I had a Snap-On adjustable light years ago that was faulty and the knob setting was not even close to what the actual timing variation was.
Regular old inductive lights for me.
Sidebar: Don't forget to verify TDC using a piston stop tool. If you're running a stock pulley you probably don't know exactly which pulley it is/what the marks mean because there are so many pulleys. Second, if you're running an aluminum marked pulley, every one I've checked was off by 2° or more. Some were off 4-5°, none were dead on. Whoever is slapping on the decal doesn't give a rat's ass if it's off a little bit. If I'm working on someone's car and they want the timing checked, step 1 is verifying TDC. You're wasting your time if you don't do this. _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Thu Feb 15, 2018 7:34 am Post subject: Re: Testing a vacuum advance without timing light |
Hey Bruce,
Is this "piston stop tool" that you mentioned an actual precision tool for this purpose or just a pencil or dowel inserted thru a removed spark plug resting on the piston? If there is a tool for this purpose that works on our older air-cooled heads/pistons, I'll bet lots of us would be interested in it. Any sources or web links to info/cost? I've tried to verify marking on pulleys before to locate TDC with a dowel, but a real precise tool designed for this chore would be cool to have! Thanks!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Posted: Thu Feb 15, 2018 8:07 am Post subject: Re: Testing a vacuum advance without timing light |
BulliBill wrote: |
Hey Bruce,
Bill Bowman |
I used a homemade tool that the owner of a VW shop made in the 60s.
I will try to explain without confusion. Young dumb 20somthing kid did not take a pic. LOL
Using an old sparkplug dismantle down to the metal treaded part. Devise a springloaded rod similar to a ballpoint pin. I remember two springs.
Insert into sparkplug opening. When piston hits rod, rod would move with piston up and down as an indicator. Worked very well. _________________ .
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807 |
